Question about Garmin Nuvi 660 GPS Receiver
How to unlock maps in Garmin 680
Whenever I start my Garmin 680 , I get message saying , Can't unlock the maps.
can help in unlocking it
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    The only reason this would come up is if you tried to update your map and don't have the unlock code. Please see this link:
    http://www.sharc.net/gps_lost_map.htm
    Please explain what you did prior to this happening. It would not happen on its own unless you deleted the unlock code file.
    - Jim
SOURCE: Cant unlock maps
What is the Garmin 510 that can't unlock maps stating exactly? And to Nici07 who said, "Need to unlock device", are you referring to a PIN lock or locked maps?
Posted on Jan 21, 2008
SOURCE: Garmin nuvi 260
My 260 does not say the street names
Posted on Mar 31, 2008
SOURCE: My garmin says it can't
If you are getting a Can't Unlock Maps message, you have a problem with the map unlock code on your unit. If your Garmin is not a preloaded device, you may need to verify that you are using the correct unlock code and re-install your mapping software.
If your GPS is a preloaded device, such as a nüvi, or if you cannot get this issue fixed with this information, please call Garmin at 1-800-800-1020 for further troubleshooting.
Posted on Apr 18, 2008
  • 2920 Answers
SOURCE: Garmin Nuvi 360 Won't Load Maps
go buy a tom tom you dont havve to do any downloads to keep it up to date.garmin has to many issues
Posted on Aug 25, 2008
sharcnet
  • 2130 Answers
SOURCE: unlocking a garmin nuvi 680
Here's your options:
1. Enter the correct PIN.
2. Go to the secure location where the PIN was set and it won't ask you for a PIN.
3. Send the unit back to Garmin to be unlocked.
Sorry but there is no master reset. The PIN is written into memory that can not be erased. I have had success in unlocking Nuvi's but I will only do it for people who have a valid purchase receipt from a major retail chain and if they can provide me with their Garmin registration info so I can verify that they are the rightful owner.
There are too many of these units out there that are stolen and the culprits are looking for a way to bypass the PIN. This is why Garmin added this feature to their GPS's.
- Jim
Posted on Sep 11, 2008
Cannot unlock the maps in my garminedge 705. When i turn unit on message comes up cannot unlock maps
Information on unlocking garmin maps can be found at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
There's more information there than you need since the article is about garmin nuvi satnavs that display a message "No detailed maps found that support routing" but part of the article deals with locked maps. The principle is the same for the garmin Edge but you'll need to skip to the part that deals with unlocking maps.
Jan 02, 2011 | Garmin Edge 705 Handheld GPS Receiver
Gps has lost its maps, screen says can't unlock maps
There several reasons you may receive the message Can't Unlock Maps on your nuvi or zumo device.
  • Can you press OK and get to the Where To/View map screen?
  • Did you load maps to the unit using the MapSource or MapInstall program?
  • Did you load maps to an SD data card?
If one of the points above applies to you, please follow the steps below to clear the Can't Unlock Maps message:
  1. Remove SD card from unit, if applicable.
  2. Plug the unit into your computer with a compatible USB cable.
  3. Open MyComputer/Computer icon. (Mac users skip this step.)
  4. Right-Click on the Garmin drive and select Open. (Mac users can locate the Garmin drive mounted on the Desktop.)
  5. Open the Garmin folder.1
  6. Locate a file named gmapsupp.img
  7. Right-Click and delete file named gmapsupp.img
  8. Safely disconnect your unit from your computer to see if the Can't Unlock Maps message is gone.
1. Nuvi 1100/1200/1300/1400/1600/3700 and Zumo 665 users will open the Map folder instead.
*If the gmapsupp.img file does not appear in the Garmin folder, please create an unlock file for device.
Nov 28, 2010 | Garmin Nuvi 265W GPS Receiver
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin NUVI 205 when turned on says can't unlock maps!?!
Whenever Garmin Nuvis have map problems, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device.
I hope that helps.
Oct 24, 2009 | Garmin nuvi 205 GPS Receiver
I get the message "no detailed maps can be found that support routing. The nuvi cannot be used without them." and I can not get to anything else on the garmin.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  2. Select myMaps
  3. Select Manage Maps
  4. Select the device from the drop down menu
  5. The unlock code is located under the "Maps installed on this device" section
Jul 18, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
GARMIN NUVI 200 SAYS NO DETAILED MAPS FOUND THAT SUPPORT ROUTING
I had the same issue..what a pain in the ****.
I came up with a solution that worked for me.
After the update i deleted gmapprom.img and then created my own map using the garmin MapInstall program. start>programs>garmin>mapinstall
Apr 11, 2009 | Garmin nuvi 200W GPS Receiver
My Garmin nuvi says ''maps unavailable''
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear for the following reasons:
  2. Select myMaps
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Enabling maps on the GPS device:
    1. Touch the wrench icon on the Where to/View map screen
    2. Touch Settings
    3. Touch Map
    4. Touch Map Info
    5. Select the checkbox next to the maps to be enabled on the device
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
Garmin 205w: Can't unlock maps
If you purchased the maps from Garmin, contact Garmin for an unlock code.
Mar 21, 2009 | Magellan Roadmate 1200 Car GPS Receiver
I have loaded Garmin Trip & Waypoint Manager plus downloaded the latest ver of Garmin Mapsource for vista. I am attempting to unlock OZtopo & contours maps Ver 2 onto a PC running Windows Vista home...
Open C:\garmin directory then right click on the .exe file "Unlock wizard". Open this file as administrator and behoild it works. Even though you may already have full administrative rights as I did.
Jun 29, 2008 | Garmin GPS
My garmin says it can't unlock the maps
Apr 17, 2008 | GPS
Garmin Nuvi 660 GPS Receiver Logo
140 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
