Question about Panasonic DVD-F85 Multi-disc DVD Player
The tray on my Panasonic DVD-F85 DVD/CD player won't close
The 5 disc tray on my Panasonic DVD-F85 DVD/CD player is stuck in the open position. It rotates - but won't close.
The Marv
  • 72 Answers
SOURCE: vcd/mp3 player always says "no disc"
First try and clean the laser with a Q-tip with rubbing alchol on it. gently wipe the lens with the Q-tip. Then allow to dry for a couple of seconds. Try again if problem persists. Try to get the disc spinning wth your finger. While spinning clockwise close the lid and see if it takes off. If it does you have a bad spidle motor and it will need to be replaced. If it does not respond to either. I would consider replacement. The cost to repair by the time you pay a tech and parts you could get a new one with warranty. Generally if these need more than just a cleaning most people just replace due to cost of repair.
Posted on Aug 07, 2006
  • 4 Answers
SOURCE: disc tray 1 is blinking with 2 ovals around it, tray not in right Panasonic SA-HT680
I had a jammed disc that was causing this same error message. To remove the jammed disc, remove the top by removing the screws and then you can remove the stuck/jammed discs. For the Panasonic SC-PT750 there are 7 screws, three small silver ones on the back, then 4 black ones, two on each side, all philips head. Once you have that off, gently pry it off starting from the back, the cover is actually hinged into the front plastic piece of the player.
Posted on Dec 31, 2007
SOURCE: DVD Tray will not open
I purchased this unit back in Mid November to make DVD's of my kids old VHS tapes. To date I have probably have made 400 DVD's. Sunday we came home from being gone all day and the unit was locked up. I tried the reset button, unplugged the unit etc to no avail. I unplugged the unit all Sunday night and looked at it again on Monday morning. I was ready to take the unit back to Best Buy and the unit ejected the DVD and has worked for 2 days (Recorded another dozen DVD's). Tonight while reading the paper a message came on my monitor that there was a problem with the disk and instructed me to push the "enter" button which shut the unit off and was suppose to recover the disc. The recorder is now locked up again. A number of 000000's flashes accross the display and the unit constantly cycles off/on. So it is trying to recover but is obviously not being successful. I am going to try the same thing tonight. I am not sure if I have a bad set of blank DVD's. They are Sony -DVD R, same ones I have been using all along. I do remember having this "Error" message when I first started this project and I had to unplug the unit to resolve but it didn't lock up and I haven't had any issues until Sunday. Seems like something in the software is screwed up. It is frustrating that there doesn't seem to be a manual way to eject the disk??!!
Posted on Jan 16, 2008
  • 47 Answers
SOURCE: Locked DVD Tray
I'm pretty sure the force disk eject is the same across all Panasonic models - however I couldn't find anything specific for your model number. Still worth a shot, though.
With the unit in standby, press and hold the 'Stop' and 'Ch up' buttons together. It should power up and force the tray open. If this doesn't work, try changing up your timing by pressing and holding 'Stop' first, then a half-second later, press and hold 'Ch up' and keep them both held together. You can also try the opposite.
If none of these work, it will have to be taken apart to get the disc out. If you aren't comfortable trying, it will have to go to service.
Posted on Mar 09, 2008
SOURCE: Panasonic DVD Player stuck in Wait
I had the same problem. I had to take it in and have the caruousel realined.
Posted on Jul 13, 2008
My Panasonic 5 disc cd changer model sc-pt950 is stuck closed, how do I open it
Open up the unit and look for the motor that opens and closes unit. Then manually turn the gears involved to open tray.
Sep 01, 2017 | Panasonic Audio Players & Recorders
Have a panosonic dmr-ez485v dvd recorder that cycles 5/6x when tray is closed with/without a dvd, and get "no read' message.
1.The DVD Drive makes two-three times noise than stop spin the media CD
or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray,
close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Feb 01, 2013 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Wont read discs
follow this steps, and use the common sense.God bless you
If the player skips, make sure that the DVD disc is not dirty or scratched..Use the cleaner disk buy it from R. Shack.
If the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
Sep 19, 2012 | Panasonic DMR-EZ37VK DVD Recorder / VCR...
CD-72 Marantz CD Player disc tray is stuck in the shut position.
You might have to open the player and see why. remember to unplug till you need to see if you can get it to work or not.
Sep 06, 2012 | Audio Players & Recorders
My DVD tray on my Yamaha DV C6480 (it holds 5 DVDs) got stuck in the half open half closed position. It may have come off the track. I opened the case and reinstalled the DVD Tray. Now the tray...
This happens to us all the time. Here is the note I keep on how to fix it quickly:
When tray gets messed up, the drive wheel (with pegs that interlock with pegs on the tray) needs to be such that the tray slides in and out freely. Push tray all the way in. Turn on.
Hope that gives a hint.
Nov 04, 2010 | Yamaha DV-C6480 Multi-disc DVD Player
CD/DVD drawer won't open so CD stuck inside :(
Well you can please follow the below steps -
1. Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
2. Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It's the part that holds the DVD loader in place.
3. Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don't want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
4. Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn't quite finished yet.
5. Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center.
6. Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you're careful. You should be able to access and remove the disc.
Good Luck!! Thanks for using FixYa!!
Feb 03, 2010 | Cambridge Audio Azur 540D DVD Player
DVD Tray stuck open
the tray is not catching (underneath the tray is ridges). unplug the dvd player from the wall for 5-10 min...plug back up and give the tray a lite push while tapping the open/close button
Jun 17, 2009 | Yamaha DVD-C920 Multi-disc DVD Player
DVD tray makes noise when it rotates
This noise can be casued by two things:
1) The tray is not completely in the loaded position and the "clamper" is rubbing. Replace the loading belt and the loading sequence will complete and the noise should stop.
2) The "CD table" that is part of the spindle motor assembly has slipped a bit. This will make the CD/DVD ride too low and strike the lower tray support. This will require that the table be "re-aligned" to the proper height which may not be possible on your model without special measurement equipment. The height is critical to proper operation of the unit.
Try replacing the load belt first and report your results.
Thanks,
Dan
May 30, 2009 | Kenwood DV-605 Multi-disc DVD Player
Sony 5 disk changer disk is stuck not able to open the tray
After some time it was showing some C 31 00 error. I searched on internet, opened the top cover, there is the CD changer and my cd was stuck in there, I pushed the CD from finger and there it goes... on press of eject it came out... thanks anyway...
Apr 02, 2009 | Sony CDP-CE375 5-Disc CD Changer
DVD-F87K
How can it not close if it's open yet not open if it's closed? lol
Anyway, could be: Bad motor, bad belt, bad gear, disc jammed.
Geno
Mar 18, 2008 | Panasonic DVD-F87K Multi-disc DVD Player
Panasonic DVD-F85 Multi-disc DVD Player Logo
107 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
