Question about Dell POWER SUPPLY Power Supply
Dell Dimension 4100 won't stay switched off
I'm not ready to part with my trusty Dimension. It multitasks quite happily under Win2000. It has however developed an annoying quirk. When I switch it off (either full shutdown or hibernate) it will now switch itself back on after a delay ranging from 1 second to 30 minutes. My workaround is to unplug it from the wall as soon as it clicks off after a power-down. I suspect this is probably a power supply problem. Any thoughts?
  • 3 more comments
  • solutionx Mar 07, 2009
    As I suspected - this is unusual!
    It happens whether it is shut down or hibernated. Hibernate should not be compared to sleep or standby because in hibernation the machine is switched off. It can be unplugged with no loss of data or work in progress. So, the machine shuts down - powers off - whether in 'full' shutdown or hibernation mode. You hear it go click and at that point you must pull the plug, otherwise in a matter of seconds or minutes, you will hear click, whirr, fans and the machine is back on.
    Thanks for the details. As soon as my virus scan is complete I will do that and report back.
  • solutionx Mar 10, 2009
    Techigs: I did check the BIOS settings and it was set to wake up on LAN events. Not sure how it could have got set that way, but it seems to be able to stay switched off again! So thanks very much for your idea.
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Good answer techigs...you deserve the 4 diamonds on that one..
  • Randall  Trahan
    Gotta be honest with you. Heard of lot of complaints about computers shutting off early but never any coming back on..it has to be rebooting to come back on..in which case it could be a couple of things. Did you notice if it restarts and then comes back on or you are saying it goes into hibernate/sleep mode then comes out of it...let me know and we'll take it from there.
  • 59 Answers
Well try this to check some settings.
1. Reboot computer and hit F2 to go to the BIOS settings.(you may have to keep pressing F2 until you see that it is going into setup)
2. Once in the BIOS you will have to use the arrow keys to move around and there is a key at the bottom. Move to the Power section and hit enter.
3. Check and make sure that the settings for Power up on PCI/PCIE Devices is off.
4. Check and make sure that Auto Power On is Disabled.
5. AC Recovery is off.
6. If all the settings are done, hit ESC to exit the menu.
7. Arrow key over to Exit.
8. Hit enter and comfirm save settings.
If all the settings are correct, then you are quite possibly correct in it being the power supply.
Hope this helps.
Posted on Mar 07, 2009
  • Tim Crosslin Mar 10, 2009
    Glad to of been of service.
No beeps but lights A B are orange
....and lights C, D are green, and your computer fails to boot up ? (you do not say) (on Dell PCs, which I don't have, the LEDs are usually described as yellow and green. There are four of them on rear of the PC ?).
First go to this webpage:
Product Support
if you are able run the Dell Diagnostics, or if not the ePSA.
Also read this manual - the only one available specifically for Dimension 4100 -
http://downloads.dell.com/Manuals/all-products/esuprt_desktop/esuprt_dimension_desktops/dimension-4100_Service%20Manual_en-us.pdf especially the section on safety. If you have to open the case remember to properly earth yourself.
To the answer to your question, if the 4600 model has the same codes as the 4100 see the service manual for the Dimension 4600 (or get the corresponding manual for the 4100 by contacting Dell support) look here
http://downloads.dell.com/Manuals/all-products/esuprt_desktop/esuprt_dimension_desktops/dimension-4600_service%20manual_en-us.pdf
in the Advanced troubleshooting section. It tells you the problem may be with your memory module(s) and it suggests what to try. I favour checking to see if you get correct errors with no memory inserted then with each module in each slot until all 4 combinations have been exhausted. This likely to tell you what is wrong. You may have to replace a memory module, or work with only one module or replace the motherboard.
23.June.2015
Apr 18, 2014 | Dell Dimension 4100 (-JM0TB01) PC Desktop
How to remove cover from dell dimension 4100?
APB1963,
You can click the link below to download the online manual for the Dimension 41000. Within the manual are instructions for opening the computer case.
Dimension 4100 Online User Manual
http://dell.to/16xh0kC
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Aug 05, 2013 | Dell Dimension Computers & Internet
I have a dimension 4100, and only have 512 in ram because it only has 2 slots, is there any way to use a bigger stick to increase ram?
Yes, if only one slot is being used you can install another 512 MB of ram which will give you 1024 MB or 1GB. If both slots have 256 MB in each one then you will need to just buy a 1GB strip of Ram. Go to the link I am posting and let them scan your computer. They will tell you exactly what you can install and the price. This is a site I use all the time and it is reputable and safe with good prices. This will require a download of the scanning tool which is safe. Allow the download. http://www.crucial.com/
Nov 05, 2009 | Dell Dimension 4100 (-JM0TB01) PC Desktop
How do I remove the cover from the Dell Dimension 4100?
moz-screenshot.jpgmoz-screenshot-1.jpgmoz-screenshot-2.jpgRemoving and Replacing Parts: Dell Dimension 4100 System Reference
This link to Dell's support site should help you figure out how to open the case whether it is a tower or desktop. This article comes with images and will show you everything from the assembly/disassembly of the cover, front panel, drive cage, motherboard, CPU, etc.
Hope it comes in handy and don't forget to bookmark the page!
Mar 27, 2009 | Dell Dimension 4400 PC Desktop
Dell Dimension 4100 freezes for approx 1 minute
your ram is prolly going bad
try to download and run "memtest86"
Mar 07, 2009 | Dell Motherboard Dimension 4100 Intel 815...
No video
you can try to hook up everything back up and then take out the video card and clean the place that it llides into and the card itsself and reinsert it and see what happnes but please make real sure that u connect everything back just like it was cause if there are cablkes that are switched there will be problems
Aug 19, 2008 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Setting it up
Hi
Dell Dimension 4100 uses an add-in AGP Video card.
The Video Port is labeled "5" in the illustration below;
System Reference - http://support.dell.com/support/edocs/systems/dzuul/techovu.htm
Mike
May 15, 2008 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Problems with Dell Dimension 4100 PC Desktop
maybe your dell dimension needs an audio driver. you can find drivers here by inputing the model or the service tag number. service tag found at the back of your PC.
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs&~ck=mn&SvcTag=&SysID=DJ_DIGITAL_MP
Just follow instruction if your were in the site.
if this not solve;
try another audio card.
Jan 02, 2008 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Dell POWER SUPPLY Power Supply Logo
180 people viewed this question
Alun Cox
