Question about 2wire 2700HG-B Router (2700HGB)
I would like to get my wireless modem light on....how do I do that (how do I get my wireless modem to go wireless).
Ok first things first, if you have a 2wire 2700hg-b the wireless broadcast is already running from factory settings, the wireless light wont lit until there is an active wireless connection to the modem, so if you havent altered any of the wireless settings on the modem you can connect really easy to it
1.- go to the modem and look for a label on it, it will have the model and the SERIAL NUMBER, displayed SN: this is a 12 digit #; you will have to care for the last 3 or 4 numbers of it
2.- below that number there is another 10 digit # between [ brackets ], you will need all the numbers from this one.
3.-now here is the tricky part, go to your computer and scan for available wireless networks make sure your wireless card/adaptor is enabled and propperly configured, or that Airport is enabled (for MAC USERS) among the wireless networks being listed look for one that will say 2wire either with capital or lowercases and this is the part where you are going to need the SN for, look for a network called 2wire that has the last 3 or 4 digits of your SN and select it, e.g.: 2WIRE123, 2wire789 etc.
4.-now by default this wireless connection will ask you for a password called also Network Key or Passphrase, when trying to connect to it , the password will be the 10 digit number between [ brackets ] that you got from the label on your 2wire unit.
5.-the wireless connection should be established and now the wireless LED on the modem should be on indicating a successful wireless link, and whenever there is traffic from the internet to your computer this light will flash along with the INTERNET one indicating data flow to the computer or any device connected wirelessly to the modem
Special NOTE 1: when attempting to create a wireless connection in a Windows Vista PC be really careful on the first attempts to connect to the desired wireless connection because after 2 or 3 errors Windows Vista will not longer even try to connect to the network and will give you the options to just diagnose the problem or try another wireless network to connect to, sometimes rebooting the pc and the modem (powering it on and off), can fix this but in some other cases you ,ight have to gain access to your modem with an RJ-45 CORD (ethernet cable) access it with Internet Explorer and rename your wireless network to attempt to connect wirelessly again, a little fancy.... so as i said be careful, when inputting the Passphrase or network key in Windows Vista, there is a case you can select that will let you see what you are typing on the passphrase field so you dont get any mistypes there....
Special NOTE 2: if you are using a MAC computer when typing the passphrase to join to the wireless network you must first enter a dollar sign $ before the passphrase or network key as we may also call it, so input the passphrase like this e.g.: $1234567890.
Posted on Mar 25, 2009
Go into 192.168.1.254, then go to "Home network", then "Wireless settings" put your network name in the blank box.
Posted on Mar 21, 2009
How to make my modem give out wifi?
check if your modem is cable in broadcasting wireless signal. if you can see wireless light in front of the modem then your modem is a router as well but if it does not have wireless light then you need a router hook up to it
Sep 04, 2011 | Arris High Speed DSL Modem
The power light on my wireless modem is red. My wireless light is green. What is the problem? How can i solve it?
>if the power light on your modem is red that means that the modem is already defective
> what you can do is to reset the modem
> if still no go you need to call your internet provider
> if still in warranty as for replacement of the modem
Mar 04, 2011 | AT&T Computers & Internet
My router is suddenly not working. The internet, modem, router and the wired lights are on, but the wireless and security lights aren't on and I can't connect from my laptop wirelessly.
check the wireless settings of the router.
Open the set up page of the router and make sure that the wireless SSID broadcast is enabled.
If enabled then try to change the wireless channel of the router.
if that doesn't work then try to upgrade the firmware of the router.
Click Here for more info about routers
Dec 19, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
2wire modem wireless light isn't on
make sure that the wireless is available with that model and if it is make sure wireless is enabled
Jul 21, 2009 | 2wire 1000hg DSL Modem & 802.11g Wireless...
Wireless light does not come on
are u able to detect your wireless network in view wireless networks
if not login the modem setting and check whether the modem wireless is enabled.
if still having problem contact 9444482052..........jammy
May 17, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Link light blinking
On these cable modems the link light is supposed to blink when you are connected to a router/pc. If you are hooking up a wireless router new you need to power cycle/reset your cable modem before you hook up the wireless router so that way it can refresh its ip address.
Mar 21, 2009 | Arris Touchstone 450a (CM450) Modem
MY WIRELESS ROUTER WILL NOT CONNECT TO THE INTERNET. The lights on the front are flashing. I have installed the modem adn router disk but it still wont work.....
If you have a modem connected to a wireless router that is connected to the computer, turn all the devices off and turn them back on in this order.
1. modem
2. wireless router
3. computer
let the device start up all the way before you start the next device. (I.E. let all the lights on the modem come on before starting the wireless router and let all the lights come on on the wireless router before turning on the computer).
Hope that helps.
Nov 10, 2008 | Belkin Computers & Internet
Wireless light
Is the Wireless signal turned on within your 2Wire options?
Try turning it on.
Aug 23, 2008 | 2wire (1000-000057-000) Modem
I want the wireless light to be on. its the only light thats off
if all the lights on the modem are Green then it means there's no prob with the hardware. just make sure that you're going to use the right WEP key or wireless password. the network name is 2wirexxx, the X is the the last 3 numbers of the SN which can be found on the bottom of your 2wire modem.make sure that your wireless switch is also turned on of course. the wireless light on the modem will lit if it is connected
May 09, 2008 | 2wire (1000-000057-000) Modem
2wire 2700HG-B Router (2700HGB) Logo
308 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
