Question about Apple iPod nano
Won't turn on
When plugged into computer ipod comes on and can control it when unplugged it shuts down wo't come back on
Ketukryyyyyyyyyyhs jtrs yh ghsdf ddddddddddddddddd
Posted on Mar 07, 2009
Yamaha Receiver won't turn on after USB plugin in. Help!
Unit is in protect mode. Sometimes an ipod draws too much current through the usb jack and causes the unit to shut down due to an abnormal voltage being detectected. Press and hold the 'info' and 'tone control' buttons and push power. This should turn the unit on. Turn it back off and turn it on again and should power up normally. If the ipod continues to make the unit shut down when plugged in, try and make sure it is fully charged before plugging it into the receiver - this may help.
Apr 13, 2014 | Yamaha RX-V375
My ipod wont turn back on
You have not stated any model no. which makes it hard to provide a solution.
The iPod A1136 is the fifth generation iPod from Apple that uses a click wheel to scroll through your device's media library, and may occasionally lock up when you attempt to play a song or display a photo. This error error occurs when the hard disk is unable to access the information and stalls while opening a file. A reset of the device usually corrects the problem, as it clears the device's memory and any errors. Check your iPod's buttons to determine if the cause is due to a hardware error before resetting the device, as the problem may be due to the iPod's hold switch. Slide the hold switch at the top of the iPod to the right, and slide it back to the left to ensure the switch is in the off position. Hold down the center button in the click wheel, and at the same time hold down "Menu" on the click wheel. Continue to hold the iPod's buttons until the device's screen shuts off, turns back on and shows the Apple logo. Plug the iPod's connector cable into the dock connector on the bottom of the iPod. Plug the other end of the cable into your computer's USB or FireWire port to charge the iPod. Wait at least two hours for the iPod to charge. Launch iTunes on the computer, and click "Controls" of the iTunes menu. Click "Eject iPod" in the sub-menu to disconnect the device. The iPod takes four hours to completely charge its battery.
Hope this helps.
Jan 24, 2013 | Apple iPod Audio Players & Recorders
Ipod classic won't turn on, battery with lighting bolt when plugged in.
You probably need to reset your IPOD. Here are the directions:
1. Unplug the IPOD from the power source.
2. Slide the hold switch or button to HOLD and back again.
3. Then press the MENU and CENTER buttons at same time until the Apple logo appears.
You should be back up and running. If not, try again and remember to make sure you press MENU and CENTER buttons at the SAME time and continue to hold them down as long as it takes for Apple logo to reappear. I once had to hold them for more than a minute before an IPOD touch would reset.
Dec 01, 2012 | Audio Players & Recorders
HOW TO UNLOK THE A1136 IPOD
click start control panel scroll to folder options tick in the box to show hidden files and holders
connect your Ipod to your computer
click start click click on you Ipod to open
then go Ipod controls device there should be a folder saying locked
right click select rename to open or delete the folder your Ipod should now be open
or you might do a factory reset
hope this helps
Oct 18, 2012 | Apple Ipod Video 5.5 Gen Black 30gb Mp3...
hope this helps
Oct 18, 2012 | Apple iPod MA446LL/A MP3 Player
My gateway profile 5 won't turn on. Checked plugs
Try to power drain it. Unplug all the power related devices that are connected, like a monitor data cable or external printer, just unplug all the cables in the back after you shut down your computer, press the power switch of your computer and keep it pressed for about 45 secs, release it, plug everything back and check it if its working. As well double check if that particular socket is usable, plug something else in to see if its working.
Jun 30, 2011 | Gateway Computers & Internet
My ipod touch will not turrn on or reboot whats wrong?
Checklist to see if your iPod needs a reboot:
. Your iPod is charged.
*If not, you might have to plug in your iPod, and make sure the computer can't go to sleep while it's charging. The iPod won't charge if the iPod is locked, so no orange.
Charging your iPod problem solution, that also works.
* Your iPod might need to completely drain in battery source before you can charge it. If that's the case, leave the iPod unplugged for 24 hours before trying to charge it. That will make sure the power is drained and your iPod is ready to be charged.
2. Your iPod is unlocked. Slide the button back and fourth a couple of times, just to make sure it's working.
3. And your iPod still has a black screen, frozen logo, or white screen.
Rebooting your iPod.
1. Run a cold boot (shut your computer down, then turn it back on) on your computer. * If your iPod crashed because of the software freezing, or the computer crashed.
2. Open your Apple Software.
3. Plug in your iPod. Make sure that you plug in your iPod into your computer, and that the plugs are secure. Your computer should detect your iPod, black screen or not.
4. Set down the iPod. Take your iPod and put it on a flat surface.
5. Press firmly. Take your fingers, and firmly press the middle button, and the menu button. It will read menu on the top button of the click wheel, and the center circle of your click wheel is what your looking for.
* Make sure your fingers are planted on the top of the center button, close to the menu button, and you are pressing it together.
6. Count to 8.
Now you should see an Apple logo pop up on your iPod screen.
Sometimes you need to try it a few times, to get it to work.
It should be synchronizing and happily you should be on your way.
*You also can reboot your iPod without it being plugged into the computer, I always do mine while it's plugged in.
you have to erease all the dta on mines and put the music and everything back on,
Sep 23, 2009 | Apple iPod touch
Help with my Ipod Nano!!
shut down you PC and unplug all the power outlet... without removing yet your IPOD
Jun 18, 2009 | Apple iPod MA446LL/A MP3 Player
Remote was hit, shut set off, and can't get it back on. Sounds like timer is on.
First try turning the TV on from the Power button the set itself (assuming it has one).
If not, unplug the TV from the wall, wait a half hour, then plug it back in. It should come back on.
Also check that none of the buttons on the remote are stuck down, and that the batteries in the remote are OK. The toy might've stuck a repeating button down (like volume) which may have then drained the remote's batteries.
Apr 07, 2008 | Televison & Video
Apple iPod nano Logo
37 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
