Question about Kenmore 62622 Microwave Oven
Sear's microwave falling apart
I have a Sear's Model 665.61683101. ver since I bought the oven back in 2002, the door handle has cracked and broken off, the plasic trim around the door, and the plastic air difuser located just above the door has cracked and come loose.
Has Sear's recalled this microwave or has anyone else experienced problems similar to mine?
  • 107 Answers
If this is and Over the Range micro, the exhaust fan needs to run ANYTIME the cooktop is on. They make things for quantity and not quality, so the plastic has little tolerance for heat. Running the fan, diminishes heat off the front of the unit. Also, the micro MUST be at leat 24" off the cooktop.
Posted on Mar 16, 2009
Microwave door handle broken
That's correct the door has to come apart. Just be careful that screen is actually a choke to keep in any microwave radiation. Put everything back exactly as you took it apart.
Good luck
Feb 14, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
How to remove the outter door frame on the GE Microwave
http://www.repairfaq.org/sam/micfaq.htm
for both queries this site would help somethin i think.. tpugh information is very huge please see if it is useful for u
Dec 25, 2007 | GE Advantium 120 Convection/Microwave Oven
Handle replacement
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
This should be a very simple repair that you can easily perform yourself.
If you have any questions, please post back and let me know. You can refer to this illustration, if you like, to assist you as well:
http://pcappliancerepair.com/model-display.php
I hope this helps you.
Mar 17, 2010 | Whirlpool GH4155XP Microwave Oven
It's broken
The door handle can easily be replaced on most microwave ovens. You just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to access and/or replace the door handle:
The cost usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. However, price and configuration of your oven also depends upon the MODEL NUMBER. If the model number is correct, the part number for a replacement door handle is WB15X10023.
If you have any questions, please post back and let me know. I hope this helps you.
Jan 29, 2010 | GE JVM1631 Microwave Oven
I am trying to replace the door handle. How to I
On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
If the model number is correct, and you haven't purchased a replacement handle yet, the part numbers are WB15X10119 and WB15X10120. There are two pieces with the door handle on this model oven. Replacements may be purchased at the websites listed in the link I provided.
If you have any questions, or if your model number is different than the one listed, please post back and let me know. I hope this helps you.
Dec 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How to change the handle
To access the door handle mounting screws, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to simply pry the plastic up and work your way gradually around the perimiter of the glass. Most microwave ovens have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
May 14, 2009 | Kenmore 62702 Microwave Oven
Cannot remove face on Micro/Covec Oven to replace broken handle
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Feb 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Handle screw broken
You have to take the trim off the in side of the door around the glass. Be careful, because the glass could fall out. You should be able to open it with a regular flathead screw driver. There is probably 4 screws holding the handle on. I am pretty sure the only way to get the part is through whirlpool.
Jan 26, 2009 | Whirlpool GH4155XP Microwave Oven
Replacing door handle???????
gently pry the plastic from the inside working from the hinges to the corner. you will need to put something in place of the screwdriver when you pull it out to go to the next pry position (about every 2 inches. i use apex bits. you can use anything about the diameter of a cigarette. then the screws for the handle will be exposed . it all snaps back together.
Feb 18, 2008 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Plastic shielding and door handle broke off
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
If you don't find your model there, call the number shown on that page.
Oct 12, 2007 | Goldstar MV-1501 Microwave Oven
Kenmore 62622 Microwave Oven Logo
178 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
