My Whirlpool microwave MG3090XAG isn't heating. I have power and the keypad appeartly is working fine. Turntable spins appropriately
SOURCE: No turntable, no heat. Light, vent fan and keypad all work...
That would be a problem with your primary interlock switch or its mount.
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
The interlocks are highlighted in the diagram below.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 29, 2008
SOURCE: Whirlpool Gold Microwave Mod#GH7155XHS-1
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Jul 12, 2008
SOURCE: Whirlpool microwave MH1170xsy0 1000 watts
With the symptoms you mention, I would suspect:
- loose or corroded connection at the magnetron
- bad magnetron
- shorted high voltage diode
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Posted on Aug 21, 2008
SOURCE: I have a Whirlpool MH6130XEQ-0 microwave that doesn't heat food
have, I would most strongly suspect a shorted high voltage rectifier
diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly
cheap fix, and your magnetron is still under the part warranty, but you would have to pay labor.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
very helpful when troubleshooting, testing, and locating components.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
warnings first:
(if it's not shorted or burned, it's
probably okay)
If within the magnetron portion of the warranty (5-9 years)
but out of the original full warranty (1 year), the manufacturer will cover the part cost, but not the cost to visit you or
the labor charge to do the work.
If nothing else, you
can save about $50-75 if you remove it from the wall and take it to a Whirlpool-authorized servicer.
You can find
your nearest Whirlpool/Maytag-authorized servicer here.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If
so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
You can
download Whirlpool owner's manuals and installation
instructions here.
We're happy
of our answer.
Posted on Mar 06, 2009
Jul 27, 2012 | Microwave Ovens
May 10, 2012 | Whirlpool MH6150XMS Microwave Oven
May 04, 2012 | Whirlpool Microwave Ovens
May 02, 2012 | Whirlpool Microwave Ovens
Apr 29, 2012 | Whirlpool Microwave Ovens
Dec 23, 2011 | Microwave Ovens
Apr 12, 2011 | Whirlpool Microwave Ovens
Apr 15, 2010 | Whirlpool MH7140XF Microwave Oven
Jan 13, 2009 | Whirlpool MH7140XF Microwave Oven
Jul 06, 2008 | GE JES1142SF Microwave Oven
Apr 23, 2018 | Microwave Ovens
