Question about ECHO, Inc. PB-251C Handheld Blower
Hi. How many wires come out off the handles
Hi. How many wires come out off the handles on/off switch. My blower turns on if I plug one wire but once I put the ground on the blower it shuts off. its a echo pb-231 LN
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
There are 2 wires. 1) ground and 1) to switch. It sounds like you have a bad switch.
Posted on Apr 10, 2009
When I turn off the snowblower with the throotle switch it will not stop have to pull the spark plug wire.
No other wire.
Instead of pulling the spark plug wire off, you could also take the end of that broken wire you mentioned and touch it to the metal that the switch is mounted on. It sounds like the wire you mention is supposed to be attached to the little curved wire. When you push the throttle down to the OFF position, it pushes the curved wire against the chassis and short-circuits the power going to the spark plug.
Re-connect the wire and also make sure the throttle is doing its job of having the curved wire make contact with the 'dashboard' or the engine housing or anywhere on the metal chassis. I just repaired my snow blower. Mine also had a broken wire that went to the back side of the panel where my choke knob is. The panel has a place to insert a plastic "key" that allowed the engine to run. In the case of my snow blower, the curly wire was normally in contact with the back side of the panel and pushing the key in bent the curved wire out of the way as you push the plastic key in between the wire and the chassis.
I looked around and saw a rocker switch that had the words "OFF" and "ON" on the rocker and decided to replace the lost key with that. I had to take the switch apart and turn the rocker around because in this application, I knew the snow blower would shut off when the switch was making contact and would be able to run when the switch was not making contact. Works fine now.
Feb 05, 2015 | Garden
1993 Ford Escort Blower Motor & AC Switch
I'm going to start from the beginning.
The blower motor gets power from the high blower relay and it is grounded thru the fan switch and the resistor. So you should have power on the pink white blower wire coming from the high relay to the blower motor. The orange black wire from the motor is ground going to the resistor and fan switch. The blue wires on the control panel are for the ac compressor.
The high blower relay gets power from fuse number 5 in the box. The blower motor is grounded thru the resistor and then thru the fan switch.
Photo courtesy of AutoZone.com
Jun 10, 2013 | 1993 Ford Explorer Limited
Hi I have a Ford Escort Zetec 1.8 16V A/C. I have a phew questions: 1. Some times my fan kicks is sooner than other times is there is reason and what do i do to make it run cooler? 2. My AC/Heater...
Your engine missing may be half the problem with cooling system. Run following test to isolate miss problem: injector balance test, cylinder leakage, and compression test .
Then while vehicle is running connect a timing lite to each plug wire and see which one is not firing.(or pull each plug off carefully one at a time until engine runs smooth the plug that smoothed out engine is bad plug/wire/ circuit distributor/coil pack.
A/C heater are you saying blower motor is not blowing any air at you? If so Check for B+ going to motor If B+ line is ok then ts probably the switch. Remove on/off switch from connector and by pass with a jumper wire the B+ wire with any one of the other wires and see if the blower operates if it does its the switch if it doesn't ,jump B+wire from the connector by passing resistors and see if blower works if it does then its the resistors if it doesn't its the motor.
Aug 16, 2010 | 1997 Ford Escort
Fan blower stopped working
Hi Retta_roche,
This circuit is controlled through the switch. In the high position,it by-passes the blower resistor.So if the blower is off in the high position, and the fuse is good, you need to check the switch,blower motor or the wiring.Since the switch physically feels different,start there. Pull the switch and ground pin #4 blk/org wire with the key on. If the fan works,the switch is bad. You need to check the connector at the blower motor for evidence of a burn. If you find the connector burned,you will need to replace the motor and the connector. I am sending the wiring diagram to help you. If you need anything else,drop me a line. Thanks,Chuck d442985.gif
May 16, 2010 | 2000 Ford Focus
Hi I have a 1998 Pontiac Grand Prix and the heater blower motor does not work, if I turn the ignition on and the blower motor is in off position my headlights come on. when I turn the blower motor to the...
This sound like the blower motor relay(lo relay) is wired in to the head light switch voltage.You need to follow the wire from the blower relay (there should be 4 wires) thats hot when the ignition is on and make sure it goes to the blower motor.It sounds like a couple wires got switched.
Nov 17, 2009 | 1998 Pontiac Grand Prix
I have a Pulan Pro 25 gas air blower. The rope
hi there the wire sounds like it goes to the chasis of the machine (earth) but it could also go onto the coil but if it comes off the kill switch then it will go onto the chasis earth (metal casing) hope this helps ben
Oct 12, 2009 | Poulan Featherlite Gas Blower, with Low...
Attach ground wire
assuming its an electric blower----- plastic blowers normally do not require an earth wire, check your plug to see how many wires in it,if it has only 2 wires in it[live and neutral] then the blower has no earth wire.if you dont feel safe in using blower add a safety trip switch to the socket and then plug in to the safety switch.this protects you.. you can buy the t/s in any good electrical store.
Jul 29, 2009 | Garden
Leaf blower
One suggestion, unscrew the spark plug and reconnect the high voltage wire. In a very dark area move the plug so that the plug thread touches some metal on the engine. Pull the starter cord. If you don't see a spark, remove the two screws on the handle and see if two wires are attached to the Stop Engine Switch. Remove one wire and bend it away from metal and try to see spark when pulling the start cord. If spark occurs, the Switch is shorted and needs replacing.
Oct 31, 2008 | Homelite 'Yard Broom' Leaf Blower
ECHO, Inc. PB-251C Handheld Blower Logo
298 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
