Question about Apple iPod classic MP3 Player
I spilled diet dr. pepper on my iPod classic and now it only works when it is plugged into the ac adapter into my wall. When I plug it into the computer, it starts spazzing out and will not go to my music, just the apple when it turns on. However, when it is plugged into the wall, it says it is completely charged and works perfectly. The click wheel still works and so does the screen. As soon as i unplug it, the screen disappears in lines and finally fades out altogether. Is there anything I can do or is there any way someone can repair it?
  • cutiepatooti Mar 07, 2009
  • 423 Answers
If it works when you have it plugged into the wall and doesn't when you don't, then I would think it might be the battery. It would be in your best interest to see if the damage is covered under warranty. If it is, then by all means, send it in for repair.
If it's not covered under warranty, and it were mine...This is what I would do: I would disconnect it from power. Then, I would take it apart and check the battery and the place were the wires connect to the board. - After all, you know it works, right? So you don't have to go any further than that.
You can, (or get a handy friend) to take a q-tip and dip it in some 90 percent or better isopropyl alcohol, gently wipe the metal connector tips on the board (where the plastic connector clips the wires on). DO NOT use so much alcohol that you soak the board, just use enough to get the q-tip a little damp. To remove the clip, GENTLY pull the clip off the metal connectors on the board. Pull the clip straight off...do not pull it off with any twisting motion.
Then, you can put a drop or two of the alcohol inside the plastic clip itself that holds the wires going to the battery, again...not too much. Let the alcohol dry and hook it back up and see if that makes it any better. It if does work...great. Drive on and remember to keep the Diet Dr Pepper away from your ipod.
If it's not any better, then I would highly suspect that the battery is toast and would get a new one. You can find some killer deals now at pawn shops. People are hocking stuff left & right. Even if you buy one cheap that doesn't work quite right, you can still cannibalize it for the battery. Hey, it would be less expensive than having it repaired.
If your not handy, or don't have a handy friend, then you just might want to send it in to a repair place.
Hope this helps you out.
Rob
Posted on Mar 07, 2009
    President:
  • 987 Answers
1 I spilled diet dr. pepper - ipod1_thumb.jpg Toggle the [Hold] switch on and off. (Slide it to Hold, then turn it off again.) Step2 ipod2_thumb.jpg Now press and hold the [Menu] and [Select] buttons until the Apple logo appears, which may take about 6 to 10 seconds. You may need to repeat this step. Step3 If the task seem a bit tedious, set the Ipodmag-glass_10x10.gif on a flat surface. ensure the finger pressing the Select button is not touching any part of the [click wheel]. Also ensure that you are pressing the [Menu] button toward the outside of the click wheel, and not near the center.
  • 10,515 Answers
The spilled dr pepper contain certain chemicals that would affect the working of your ipod classic.
When you plug in your ipod to usb, the chemicals that might have been attached to your ipod , might have came in contact with the current and affecting the normal working of ipod.
Try to clean your ipod, with a soft gentle cloth or cotton.
The procedure would be :-
To clean iPod, unplug all cables and cords and set the Hold switch to Hold. Then use a soft, damp, lint-free cloth. Avoid getting moisture in openings.
Don't use aerosol sprays, solvents, alcohol, or abrasives to clean iPod.
If that would solve your concern, that's perfect.
Unless you need to send it to the service centre to get that repaired. Might be it could have affected the battery or any of the component.
Thanks for using Fixya.
  • taran_2005
    taran_2005 Mar 07, 2009
    We aould really appreciate your feedback.
    Thanks.
    Brigadier General:
  • 5,158 Answers
It appears you have shorted out the battery. you would need to remove the battery and clean the area... i would suggest using a solution of baking soda and water.
  • Apple Master
  • 13,433 Answers
Official apple repair is here
https://selfsolve.apple.com/GetWarranty.do
Need to knw how to read code on bottom of cans of dr pepper for experation dates
From the Dr. Pepper FAQs: https://www.drpepper.com/en/faq#8
The "Production Code" on the bottom of the can contains the expiration date information. The production code format is determined by your local bottler. Please call the Dr Pepper consumer toll-free number (1-888-377-3773) for assistance.
The shelf life of Dr. Pepper is as follows:
1. Diet Dr. Peppers with Aspartame or Aspartame/AceK blends: 3 months or 13 weeks
2. Glass & Cans with Sugar or High Fructose Corn Syrup Sweetener: 9 months or 39 weeks
3. Plastic Bottles (all products): 3 months or 13 weeks
Sep 13, 2017 | Wine & Spirits
We have dr pepper in cans and need to know how to tell if they have expired
Which Dr. Pepper products contain caffeine?
Dr. Pepper products that contain caffeine are:
Dr. Pepper
Diet Dr. Pepper
Cherry Vanilla Dr. Pepper
Diet Cherry Vanilla Dr. Pepper
Feb 04, 2013 | Wine & Spirits
Which Dr. Pepper products do not contain the artificial sweetener aspartame?
The following Dr. Pepper products are aspartame-free: Regular Dr. Pepper, Caffeine Free Dr. Pepper, Dr. Pepper Vanilla, and Dr. Pepper Cherry Vanilla.
What drink contains more caffeine, Diet Dr. Pepper or Diet Coke?
Diet Coke contains a few more mgs of caffeine per can. Diet Coke contains about 40 mgs of caffeine in a 330 ml can, while Dr. Pepper contains 35 mg of caffeine per can.
What is the shelf life of Dr. Pepper?
According to the official website of Dr. Pepper, the shelf life of diet products containing aspartame or aspartame/AceK blends is 3 months. All plastic bottles have a shelf life of 3 months. Sugar products (sugar or high fructose) that are in a glass/can have a shelf life of 9 months.
How do I charge my ipod? Just got it from my
Connect it to your computer via the USB cord. You can also get adapters which will allow you to charge it using a wall socket (AC power). The adapter plugs into the wall, and then you plug the Nano's USB cord into the adapter.
Jan 29, 2010 | Apple iPod nano
My ipod only works when It's pugged into the ac adapter.
You probably damaged your ipod battery. Try replacing it.
Try either http://www.ipodrefresh.com or http://www.ipodrecharge.com. They specialize in ipod repairs.
Mar 07, 2009 | Apple iPod classic MP3 Player
Dr. pepper was spilled on my samsung S730 POINT AND SHOOT camera...everything still works except the flash
You will have to send the camera in for repairs, not sure if samsung warranty covers Dr. pepper damage you will have to ask them.
Heres one repair place
http://www.advancecamera.com/repair/
Jul 14, 2008 | Cameras
Apple iPod classic MP3 Player Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
