Question about HP OfficeJet 7310 All-In-One InkJet Printer
The ink cartridge I replaced in my printer is not working.
I replaced my HP 7310xi all in one color ink. I thought it was a 97 color cartridge. I still think that is the right one. For some reason, my printer now won't print and keeps reading "Please reinstall color ink cartridge" AM I using the right ink? What is the problem?
  • heidi_bostwi Mar 09, 2009
    Sadly, I think you are right. I checked the ribbon and it does looke like there is a hole in it. It sounds like it is not possible to replace the ribbon, right? So I need to just buy an entirely new printer I am assuming. Thanks for the info!
  • shyspeed May 11, 2010
    if you are sure that the ink cartridge is correct, just double check that you have removed all the tape, and inserted it correctly.
  • 78 Answers
I have one of these printers (7210-7310) with this same problem and this is what is wrong with it. There is a small wire spring that holds the ink cartridge in place in each cartridge holder. Remove the color cartridge and inspect the ribbon cable (it gray) inside the ink cartridge holder. There is a big problem with these HP printers where the spring pokes a hole the ribbon cable breaking one of the wires and rendering the printer useless. Poor design by HP, sorry.
Posted on Mar 07, 2009
Large ink spill. Printer no longer recognized new black cartridge.
You can perform the Tap 41 Cartridge Health Diagnostics Test: [applies to HP Deskjet 6800/6900/9800]
http://inkjet411.com/?page_id=1741 (refer to 2nd video to understand how to read the printed pattern)
1. With printer power on, press and hold the POWER button.
2. Press the Cancel (X) button four (4) times.
3. Press the RESUME button (Down Arrow) once.
4. Release the POWER button.
5. The Diagnostic Test Report should print.
--- A good HP 93/95/97/99 color cartridge should display 600 good nozzles, while a good HP 92/94/96/98 black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout: http://inkjet411.com/?page_id=1741
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink (special "ink back-up mode").
For information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Aug 27, 2013 | HP Deskjet 6988 Inkjet Printer - Color -...
I have an HP Officejet 7310xi all-in-one printer. I simply want to know how to replace the ink cartridges. there is a plastic plast that sticks up where you would pull the cartridge out that has a arrow...
Here is a link to the HP page showing replacement of the ink cartridges. Complete with pictures and video.
OfficeJet Ink Replacement
Note: The printer must be powered ON for replacement.
Thanks for using Fixya.
Jul 30, 2011 | HP OfficeJet 7310 All-In-One InkJet...
I am replacing the #97 color ink cartridge and my printer left ink icon blinks and doesn't appear to recognize the new cartridge
Is the cartridge "new" or "refilled" ?
Remove the ink-cartridge.
Turn the printer off.
Disconnect the AC power cord.
Reconnect the AC power cord.
Turn the printer on.
Re-insert the ink-cartridge, and be sure that it is "seated" fully and correctly.
Dec 15, 2010 | HP Deskjet 6940 InkJet Printer
I just loaded new HP 94 and HP 97 ink cartridges in my HP 6210 Officejet. I went through the alignment process and received a sheet that had colors, but no black ink. The printout indicated the alignment...
Make sure all the protective tape on the Black cartridge has been removed. Also are the inks re-filled? I have seen many re-filled cartridges fail in a similar maner.
Nov 22, 2010 | Computers & Internet
Insert HP color inkjet print cartridge 99 into HP OfficeJet 7410 I am replacing the HP 97 color print cartridge with th 99 print cartridge (both are color). The 99 will not go in all the way. I notice the...
The HP 99 cartridge is used if you would like to print photos. The HP 99 replaces the HP 96 (black) cartridge in your printer. The HP 99 cartridge has black, photo magenta, and photo cyan inks in it. When you pair this with the cyan, magenta, and yellow in your HP 97 (color) cartridge you have the full set of photo colors represented.
Jan 13, 2010 | HP OfficeJet 7410 All-In-One InkJet...
The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Jan 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Hp 2610xi not recognizing HP 97 color cartridge
If you look in the 96 (Black) cartridge loading area you might see that the retention spring has poked a hole in the circut board. I am now either trying to replace the ink cartridge holder or purchace a new printer. I have about $70.00 in new ink that I can't use now. The 2610xi worked great until the spring popped out of its holder.
Jun 10, 2008 | HP Photosmart 2610xi All-In-One InkJet...
Other compatable cartridges
Cartridge Description
Zone 1
small black inkjet print cartridge
HP 94
small tri-color inkjet print cartridge
HP 95
large tri-color inkjet print cartridge
HP 97
photo inkjet print cartridge
HP 99
Jan 15, 2008 | HP PSC 2355 All-In-One InkJet Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
460 people viewed this question
Ben Johnson
