Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
I have a Whirlpool GSW9800PW2 that will aggitate and spin, but there is now a "clicking" sound in rhythm with the agitator. I have taken the agitator out and aloud the machine to start the agitate cycle and still hear the clicking. Could this be coming from the clutch or the gearcase?
    President:
  • Whirlpool Master
  • 2,651 Answers
Possilbe, also can be comingform sonethingeither between the tubs, or pokingthrough one of the holes in the inner tub "clicking" against outer tub
Posted on Mar 07, 2009
Whirlpool lsq8243h doesn't aggitate
if it doesn't agitate but will spin it is probably the agitator cams.
http://www.repairclinic.com/PartDetail/Agitator-Repair-Kit/285809/470910
If it doesn't spin it is probably the motor drive coupling
Here is a link to the part and a video on how to replace it.
I would suggest watchine the Video before you order the part then you can check if this is the problem.
http://www.repairclinic.com/PartDetail/Motor-Coupling/285753A/1195967
Oct 07, 2012 | Whirlpool Washing Machines
Whirlpool lsq8243h
If it doesn't agitate but will spin it is probably the agitator cams.
Oct 07, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
How can I remove the agitator to clean the liquid softner dispenser, it is clogged
you will have to remove plastic nut at top of aggitator to be able to raise the aggitator out of the tub hope this helps
Feb 29, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Cabrio WTW6600SBT Top Load Washer won't aggitate
My Whirlpool WTW6600 had the same problem. The tub no longer floated up and down on the center shaft, so it only spun, not agitated. You must remove the tub (with some effort) and lightly sand / clean the center shaft. Lube it lightly with wheel bearing grease so that after it is reassembled, you can pull the tub upward and feel about 1/2" movement. This will enable the proper gear assembly to engage. It can spin when it rests at the bottom of its travel, but once you fill the tub, it floats, moving upward, and engaging the agitation gear. Good Luck!
Nov 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Noisy aggitation
You have a 2 piece agitator and it is worn out. You can either replace the entire agitator or get a repair kit for it. Hope this helps!
Feb 05, 2009 | Whirlpool Washing Machines
Washine mashine aggitator
Rob, sounds like you need an agitator repair kit. Not a hard job, under the dispenser cap you have a set of ears, spring and plastic bearing. The kit is cheap, you can find it here http://www.repairclinic.com/0080.asp Catriver...post back
Dec 03, 2006 | Kenmore 15864/15862 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
202 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
