Question about Vizio GV42L 42 in. LCD Television
Channel button on tv and remote control dosent work
I've only had the television for about 3 weeks and the remote channel button and the television channel button stopped working
  • 360 Answers
The channel buttons on the tv and remote only navigate through the channels programed into the tv. You will need to go into set up and scan for channels or manually add channels you wish to receive.
clarkco
Posted on Mar 07, 2009
Just press menu go to auto search
problem fixed and you'll have more digital channels as well
Posted on Mar 29, 2009
I have had several technicians at my parents house they have a sanyo pdp42xr9da with remote rcj17oa the remote dosent talk to tv we have had the tv for two years it did work but now dosent please suggest...
Most of the fault in this kind of symptoms is the remote control itself.
To confirm it, aim directly the remote control to your cellphone camera and press any button key at the remote control. While pressing the button key, you will be able to see the flash of the infrared indicating that the remote control is working fine. If you can't see the flash of the infrared this is an indication that the remote control is already faulty.
Remote control
If you've confirmed that the remote control is working fine, then the fault came from the infrared receiver(sensor) of your tv. It needs to check by the qualified technician to isolate the problem.
Feel free to ask question of you need further assistance.
mjsazon
Oct 04, 2011 | Televison & Video
Code required to programe sky remote control for murphy 42884t2lcd
Hello
Three digit remote code with Sky with Murphy TV are:
132 244 191 502 100
Sky+ Remote Control Unit Programming Procedure Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note:
In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press TV followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Sep 21, 2011 | Televison & Video
Hi, i have 14 "
As I see it, your problem has something to do with your remote. I bet you have pressed the "auto search" button of your remote that's why your TV keeps on searching channels automatically from channel 76 down. Here's what you've got to do:
1. Get your remote control
2. Turn on your TV.
3. Press the "auto search" button to stop your TV from automatically searching channels.
4. In case it works, I'd advise you to look for channels manually using the number buttons or the "previous" or "next" buttons.
5. If it doesn't work still, contact your technician or your service provider about it. They are of great help for you!
I hope it helps. Thanks a lot.
Jul 23, 2011 | Televison & Video
Sky remote control code needed for lg tv - model 37lk450
Hello
Setup codes for LG TV with Sky remote are:
065 244 405 318 037 398 191 459 245 389 060 275
065
742
743
726
508
584
1*Select any channel on the TV.
2*Point your Sky+ remote control away from the TV and press the tv button.
3*Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
5. Point the Sky+ remote control at the TV and try the volume button. If this works try the other TV functions.
Please note:- in der to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
Jul 16, 2011 | Televison & Video
My four year old was messing witht he bottons on the front of my Apex AT2702 television set, and not all it shows is a blue screen with a key symbol in the bottom left hand corner.
Hi
There are 7 buttons with its front panel including power ON/OFF switch button.They are; From left to right:- Video, Menu, Volume(-ve), Volume(+ve), Channel(-ve) and Channel(+ve). If these buttons are not there, it will be difficult to operate this set without a remote control. If you haven't the remote contro with you now, buy one universal remote control. The universal remote control suited for this set is COMCAST ON DEMAND CUSTOM-3 UNIVERSAL REMOTE control. The setup codes are:-
0748, 0765, 0767
OK.
Jul 11, 2011 | Apex Digital Televison & Video
While moving my parent's Curtis Mathes Cm19001 TV produced in 1999, I touched the channel button which took the TV off of channel 3. We've tried to use the channel buttons to return to channel 3,...
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try Remotes.com to buy a tv original remote.Return the universal remote.
Jun 18, 2011 | Curtis-Mathis CM19011 TV
My ilo tv will not change from channel 3. The
You may have accidentally pressed 'Favorite' on the remote which will lock the controls. Try pressing 'Favorite' to unlock the controls.
Jul 10, 2010 | iLO 2600 Television
Where do i find the codes to program my remote to the cable box
you can do a auto progrom
first you turn tv on
on the cable remote you have the io button and the tv button you press them both down at the same time for 3 secounds the io button will light up while it is lite you press the channel button up or down till the tv turns off then you press tv again it should blink twice to confirm the code then you will be able to use the remote with your tv if it dosent work take your time when it goes off dont hit the channel button to fast or again or you will load the next code if it dosent work try it again slowly till the tv turns off
Dec 14, 2008 | Polaroid PLA-4250A 42 in. HDTV-Ready...
TV is not working
If it's 3 weeks old bring it back if you can. There should be at least a 30 day warranty. When the channel and volume buttons on the TV don't work it sounds like something failed.
Oct 19, 2008 | Televison & Video
MAGNAVOX TV MODEL CCT192AT01 FROM DECEMBER/1995
You need the original remote for that. Try "remote controls.com" and I believe they should have one. If not, let me know.
Feb 26, 2008 | Televison & Video
Vizio GV42L 42 in. LCD Television Logo
543 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
