Question about Dell Latitude D600 Notebook
The battery does not charge anymore ,the bios setting says idle
How can I get the battery to charge again? Is it a bios setting? or am I missing something? It worked fine until I took a trip and partway thru the trip the battery quit charging?
  • steveverhoev Mar 07, 2009
    No, the light on the laptop doesn't come on anymore. I will find a VOM meter and check output. Thanks
    Should the battery setting in BIOS say idle?
  • 463 Answers
Remove battery and reseat.
Use VOM (Volt-Ohm Meter) and phsically check to make sure the power supply is putting out advertised voltage (typically 19-20 VDC)
Make sure power supply recepticle (the female part on the laptop itself) has not been broken or reamed out such that contact is not being made.
When you plug power supply in, does the charging light on the laptop come on?
Posted on Mar 07, 2009
I'm in the same situation. Apparently, the motherboard contains a chipset that controls the power charging to the battery by identifying the charger type. I updated my Bios & flashed, bought new baterry and check with 2nd charger with no luck.
Solution.. Replace Motherboard ( in other words trow your laptop and get a new one)
Posted on Apr 13, 2010
Charging
The replacement battery may be no good
May 31, 2013 | Dell Latitude XT Laptop
Sony laptop not getting charge
Check inside your Bios or System Setup for settings that control the battery. Turn your laptop off, then turn it on and watch the screen for which key it says to hit to get into the Bios or System Setup. Hit that key when you see the message or it will not work and you will have to reboot and try again. Once you are in the Bios or System Setup, search thru it for some settings that control the battery.
May 29, 2012 | Sony VAIO EB Series Brown Notebook...
I can't get into BIOS anymore. It just sails right by when I press F2 and starts up Windows. I've tried DEL and F1 but that doesn't work either. The problem started shortly after I updated the BIOS from...
remove the cmos battery from your motherboard and return it again after 5 seconds, that will restart your BIOS, or you look for the BIOS reset pin on your motherboard just consult your manual as guide.
Jan 11, 2010 | Dell OptiPlex GX280 PC Desktop
Acer aspire one battery light flashes orange. When booting after a few seconds it shutsdown. Now all lights stay off. Can this acer netbook work without batery ? It doesn't seem to charge the batery
Finally I got it working again, after a lot of try's (just put the plug in for a few hours) the led was red again for a brief moment, then it starting to flash orange again.
I looked it up on a lot of forums, the problem is that the (old) bios doesn't charge the batery anymore when it is deeply discharged.
So I put the plug in and out for about 10-15 times , and the brief moment it is not flashing it's still charging. Until it is not deeply discharged anymore and then it is charging the batery like it did before.
But I still don't understand why it is not working without the batery inserted ??
Nov 14, 2009 | Acer Aspire One PC Notebook
Dell insprion laptop not charging the battery, showing IDLE when charger is connected to it, my charger is showing idle even in bios setting what is the problem
remove battery.
connect ac adapter.
make sure ac adapter led is on.
connect ac adapter to laptop.
check if ac adapter led still on after connection laptop.
turn on laptop then check bios if ac adapter is determined.
check bios as well if it is updated. if not then download the latest bios update from dell support site.
after updating bios charge the batt while laptop is not use. check if changes will happen on the number of charge. make sure you check the charge in bios not in windows.
if charge in bios made changes while on windows still says idle and not charging then reinstall the OS.
if all fails no changes in charge % batt then have the batt replaced.
Oct 24, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dell HQRP 19.5V charger not charging, idle
Are you using the correct replacement?take the battery out .use a toothbrush ,brush the contacts on the battery and the contacts on the computer try charging again.
good luck
Sep 11, 2009 | Dell HQRP Replacement Laptop AC Adapter
Battery Charge and shut down
there's is some problem with the bios setting set the bios setup to default setting to get back to its stable settings
Oct 10, 2008 | Toshiba Satellite M35X-S349 Notebook
Bios setting Utility for asrock Motherboard P4VM8
i would set the bios back to default to cure any problems.....to do this the easy way i would take out the battery on the motherboard.....it looks like a watch battery and the numbers on the battery are usually 3023 or 2032.....levae it out for 10 minutes minimum and then instal it again the same way you took it out....thatll clear the bios and reset the settings. try that and tell me what happens.
Oct 01, 2008 | Asrock P4VM890 Motherboard
Bios set 08-08-2008 resets to 31-07-2007 every time i turn computer off.turn computer off then turn on it resets its self to 2007.turn power off and on at power switch. computer starts on own i do not push...
- do a bios update (or downgrade if needed) to see if it fixes the issue
- but probably the BIOS battery is not keeping the proper voltage anymore, and it automatically resets the BIOS (do the bios setting that u change, remain changed after unpluging/pluging the comp ?!). Try keeping the computer pluged in for a day and see if the battery charged properrly (if the set date remains )... if not ..change the battery.
- as for the self starting, there is a setting in the BIOS, that activates/dissables that ! - see u;re user manual ...
Aug 08, 2008 | Computers & Internet
Dell Latitude D600 Notebook Logo
783 people viewed this question
Alun Cox
