Question about JVC AV-36S33 36" TV
I have hooked my cable into the back of my set and the picture is fuzzy unless I push on the cable. The connector on the back of the T.V. seems loose. Is there anyway to fix the connector?
    Problem Solver:
  • 11 Answers
The terminal problemly came loose from the circuit board take the back off an resolder connector to the board
Posted on Mar 07, 2009
Just bought a 55" DP55D44 Sanyo TV, and the picture seems to be showing fuzzy. How can adjust this?
The fuzziness is radio noise from space. No I am not kidding. It's from the background radio spectrum of the universe's creation and it is uniform and OMNI-directional, so it will always appear as snowy noise that is fuzzy in appearance. You can't remove this noise unless you connect a signal from a TV station or cable that is much stronger in strength than this noise. If you mean that a TV signal comes in and appear fuzzy, it is because this TV signal is very weak and you need a better antenna to increase the signal gain. Hope this helps.
Jan 02, 2015 | Sanyo Televison & Video
Picture gets fuzzy especially the writting on 2000 Sansui tv
This could be multiple things. If the fuzzy picture is on your regular cable channels and the tv is hooked up directly to the cable then it is a signal issue. Your cable signal is probably too low because it is either split too many times, a splitter went bad, a piece of cable went bad, you have RG-59 cable rather than the much better RG-6 cable. Another solution is if there is a vcr hooked up, the cable jack on the vcr could have gone bad, the vcr power could be on which will cause a fuzzy screen. If you have a vcr try to bypass it and hook directly to tv. If that fixes you problem then it may be the vcr or the wire from the vcr to the tv. If you have no vcr then I recommend buying a cable amplifier and hooking it up. This is a band-aid solution but it could work long term if it's just a matter of weak signal. If that does not fix your problem I would recommend calling a cable professional to evaluate your problem. Could be the line from the pole to your house or any of the wiring in your home.
Jul 10, 2010 | Panasonic CT-32SL15 32" TV
Fuzzy picture on tv 54in
Check your coaxial cable connection and inspect it wiggle it while the set is on if the problem clears replace the cable. Check to see if the male connector that sticks out the back of the set isint loose to the point where it moves when you touch it. If it does you need to have it looked at by a tech usually this problem can be solved with a little soldering but could get more complicated. Depending on the age of the set the fluid in the CRT's gets old and cloudy and light cant shine through it makeing your picture appear fuzzy. Your local tech should be able to change the oil in your set. Finally you could have some bad filter caps but I doubt it.
Jun 12, 2010 | Akai PTH5498 54" Rear Projection...
I have a Sharp 32" Standard TV ... picture will get fuzzy either due to someone walking by or sometimes if sound coming from tv is vibrating. If we shut tv off and turn it back on it is clear again. The...
Hello: Your problem seems to be in or around the tuner of the television, More then likely you have cold solder joints on the turner that needs to be resoldered. Also check the coax end protruding from the back of the set where u connect the cable and make sure it is not loose, a bad ground on this connector to the turner shield will cause this symptom. My professional diagnostic is that when the television is cold the solder connections are making contact with the board, and as heat builds up in the television while watching these connections tend to seperate and make limited contact, causing fuzzy picture and in most cases no picture just snow...
Sep 06, 2009 | Sharp 32C-240 32" TV
Why is my picture distorted? From the start up it is distorted. Even if nothing is in it.
make sure all connectors are secure for starters second id try different cables
Jul 07, 2009 | Sony Playstation 3 (PS3) Console
FUZZY PICTURE
1 thing you can try. sounds silly but. the older a TV is the 75om cable in the back. un hook it, clean it with a tuch of alohol, and the post it hooks to. dry it good. and put it bake on tight. must times the white line come from a dirty, wore out, or bad cable to the set. best way to test this is wiggle the cable behind the set. if the intenstty of the lines change, it's you cable. replace is. hope this helps.
Mar 20, 2009 | Televison & Video
No Signal from cable setting.
check settings on your source...make sure you are not plugging into a DVI/HDMI port on your TV unless you are in fact converting from DVI to HDMI (there a connector to buy) if thats not it replace the cable with a different one. There are several varities of HDMI cable and the signal is faster as you increase in price normally. I have Monster cables that work Perfectly....I would also check TV settings on the port you are plugging into and try a different one to see if the result is the same. If the result is the same you may have a bad source. Always rule out the cable too.
Feb 10, 2009 | Sony KP-51HW40 51" Rear Projection...
Connect Macbook Pro to Component input
you should be able to use an SVGA to component rca connector on any component input - i have a wd-65513, and thats how I have my pc hooked up to it. I could also never get a clear picture using the SVGA plug on the back of the set.
Jan 12, 2009 | Mitsubishi WS-65513 65" Rear Projection...
CANNOT USE MY TV UNLESS CABLE BOX OR DVD PLYER IS ON
Your TV sounds like its signal board has went out and will need replaced (This is the most common cause of the problems you describe!)
Please rate response and help keep this site FREE!
Jan 03, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Fuzzy pictuore
It's maybe because you are an idiot. "P-i-c-t-u-r-e.
Jun 08, 2008 | Televison & Video
JVC AV-36S33 36" TV Logo
70 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
