Question about Amana ARB8057CSL Bottom Freezer Refrigerator
No ice or water
I have connect a water pipe to the fridge and neither the ice or the water spicket work.
I have loosend the water pipe to make sure water is flowing and it is.
  • 410 Answers
Do you have a filter installed? this unit has a built in filter and without the filter i nstalled it will not dispense water or make ice. thanks peyton
Posted on Mar 07, 2009
Ice not forming in ice tray
Hi - there are several problems that can cause this - but ultimately, if your freezer is keeping frozen foods frozen, the problem is lack of water flow.
Most automatic ice makers work on a timer. At a regular interval, if the ice maker arm is down to signal a "not full" ice bin, the heater on the bottom of the ice form turns on to break the bond between the ice and the mold. After a short time, the wiper linkage turns to allow the wipers push the individual cubes out of the mold and fall into the bin. After that, the solenoid on the water line is energized that will allow the water to flow to the ice maker to fill the mold, and then shuts off.
The water may pass through the filter inside your fridge (if equipped) and the filter may be clogged (if you can dispense water from your fridge and it works - this not likely to be the problem). Some fridges require a filter to be present - other will work without a filter - but none will work with a clogged (or frozen) filter. Make sure the fresh food compartment of the fridge is not freezing the filter.
Most of the ice maker functions are silent - except for the sounds of the ice dropping into the bin, and in some cases, the "snapping" or "clicking" of the water solenoid turning on and off (coupled with the sound of water running).
See if you can hear this happening. If you do, the problem could the either the flexible water line or the point of the water line attachment to the cold water pipe in the house. If you moved the fridge out for any reason, it is possible that the water line has been kinked or crushed when the fridge was moved back into position. If it has been undisturbed, it may be related to the valve that supplies water to the fridge. Sometimes, a clamp-on pipe piercing valve is used to connect the smaller fridge water line to the cold water pipe in the house. It is not unusual for these to give trouble after several years - particularly in areas with "hard" water. It may be worthwhile to replace this if it has been installed for some time.
Lastly, it may be the ice maker itself. It has heaters, switches and motors - any of which can fail and cause trouble. You could pour water into the the maker with a watering can or similar and let it make ice as normal. If ice is never dropped into the bin, then something on or cabling to the maker itself has failed and will likely require professional service or replacement as an assembly.
These should get you going and may pinpoint the issue - good luck!
Apr 08, 2013 | Refrigerators
Hi,would u please be able to tell me how to refill the ice and water despenser on a Omega FRR616S fridge
did you connect the fridge to your main water pipe? if not you need to get plumer to dod so. if yes make sure there is no blockage in the pipe system, and it sould work. also you need to reset the fridge from the front panel
Sep 07, 2011 | Refrigerators
How to drain71- 40 .where is drain need to replace hearer need to drain first. 50 gal
There is usually a spigot right at the base of the water heater. Thread a garden hose on the spigot and route the garden hose outside. Of course be sure to pull the power breaker first. After you are sure that the power is off, turn the spigot handle and let the water flow. Be sure that you turn the inlet valve off that is located on the top feed pipe. Be sure to turn the feed back on before you power up as this will ensure that the upper and lower calrods are covered before you power on.
Jan 22, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Kenmore, coldspot, model # 10650564991, side by side. The problem: spicket broke off of the water station on the door. My repairman/parts person says the part is $50.00! According to him/her, the etire...
The Technician was right. The part only comes as an assembly. See this link: (Item 10)
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10650564991/0582/0165000/P0050062/00008?blt=06&prst=0&shdMod=10650564991
Detailed view:
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Refrigerator-Parts/4388152/0046/106/Model-10650564991/0582/0165000?keySuffixId=NA&productTypeId=x&searchModelNumber=10650564991&subCompDesc=Dispenser%20front&brandDesc=KENMORE&modelDesc=SIDE-BY-SIDE-REFRIGERATOR&pathTaken=partSearch&blt=11
The only thing I can recommend that you can do possibly save yourself some money is go to any local appliance repair shop an see if they are parting out a refrigerator. There is yet one other option and that is to call a local refrigerator recylcling place and see if you can obtain the fitting there.
Other than that the service person is going to order the NEW part thatis $55.74 + shipping from Sears.
The current available part number is: 4388152 and is called Nozzle Tube Kit.
This is the best I can do for you.
Thanks for choosing FixYa,
Kelly
Jan 14, 2011 | Kenmore Refrigerators
1996 Frigidaire Fridge/Freezer.... The fridge is leaking underneath suddenly, soaking a full sized towel every 2 hours. The water rung out of the towels is slightly brownish in color. No leaks can be...
I'd check the water supply line to the fridge. If kinked of damaged, may be the source of the leak (make sure that the the connection point to the building's cold water pipe isn't leaking - and simply running down the supply line to the fridge!)
Of course, it could be a cracked solenoid valve (turns water on and off when the ice maker calls for water for ice), loose or broken clamp, broken filter (if equipped), etc. All these connection points in the water supply lines should be visible.
Unplug the fridge as soon as you can reach it before working on a wet floor with live electricity.
Please rate my reply if it was helpful - good luck!
Aug 19, 2010 | Frigidaire FRT21P5A Top Freezer...
How do I replace the water line in the door?
Find your route to the water line. Drill a hole in the floor behind the refrigerator and thread the copper tubing into the basement. Go to the basement and find the main water line and pull the copper tubing to it.
Step 2
Attach pipe to refrigerator. Go back up to the kitchen and attach the end of the copper tubing to the water pipe of the refrigerator. You can use a nut and ferrule to connect the tube to the fridge. Make sure to leave a little bit of copper tubing coiled behind the fridge so as to not disconnect the tubing when moving the fridge.
Step 3
Turn off the water. With the fridge all hooked up, go back to the basement and turn off the water. Find the cold water pipe and drill a 1/4-inch hole to accommodate the copper tubing.
Step 4
Attach valve to pipe. You need to attach the water valve to the main pipe. This allows you to control the flow of water to the refrigerator. Make sure you have a gasket to seal between the valve and main water pipe.
Step 5
Connect the copper tubing. With the valve connected to the main water pipe, connect the copper tubing using a clamp. This should be everything you need. Turn on the main water and you should be able to get a glass of water, but it will take an hour or two for the ice cubes to freeze.
Take care..
Aug 08, 2010 | Kenmore 53092 / 53094 Side by Side...
I can not connect a pipe to the fridge to dispense water. Is it possible to manually fill in water and create ice blocks or dispense later?
no to use the ice and water feature you need to plumb it in you can use with out plumbing in but not if u want the ice and water function
May 20, 2010 | GE Americana A4425GDTWW Side by Side...
Ice maker not working
Check to make sure the water line is properly hooked up and on (this would run from the general area of the ice maker out the back of your fridge, down, and through a pipe into the floor or wall. If this is not hooked up or present, your ice maker has no way to get water) if the water is on at the fridge, make sure it's on where the pipe is connected to the water line is as well.
Second, check to see if the "full" bar is in the proper position. This should be somewhere in front of where the ice dispenses, if it is in one position and it's not working, move it to the other position.
If these general solutions do not work, please respond with your make and model and any other information on the malfunction you can give us!
Thanks for using FixYa!
Dec 04, 2009 | Amana ARS266ZBS Side by Side Refrigerator
GE GSS25QGTA Side by side fridge not cooling, no digital display, no ice or water dispensing, lights in freezer abd fridge work. Any ideas?
did you plug the fridge in and connect and turn the water pipes leading from the fridge to an outlet and water outlet, if you didn't you should
Dec 02, 2009 | Dryers
Ge fridge- water dispenser in door wont work yet ice maker does.
There are a few reasons for this. Most common, is the water filter. After a period of time(literage usage) the filter eventually blocks up.Flow will not continue until a new one is installed. On occasion, the water line in the freezer ices up, but doesn't often happen. If so, you will need to defrost freezer until pipe is no longer iced up(set freezer to about -20 degrees celsius).or very possible, water solenoid at the back of the fridge has gone faulty.You will need help with this check,There will be 2 valves. Very possibly it will be the RHS one at the back. Switch water supply off at the back then go to the water solenoids at the back of the fridge.and disconnect the one pipe on the solenoid that leads into the fridge. Open fridge water tap again and ask member to quickly press water dispenser lever.Note if water squirts out for that brief period.. If not, reconnect pipe again then do the same disconnection to the second solenoid. If no water comes out then,(make sure water is open), then the water valve needs to be replaced.
Oct 04, 2009 | GE Refrigerators
Amana ARB8057CSL Bottom Freezer Refrigerator Logo
77 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
