Question about Toshiba Satellite 2405-S201 Notebook
Toshiba satellite laptop screen won't stay up
Screen falls down, won't stay where I put it.
  • Shadow1989 May 11, 2010
    sounds like you have loose tension screws.
  • 52 Answers
There are screws on the hinge that would require tightening they have come loose there are alot of little teeny tiny screws in those laptops so it is recommended that you take it to a technician
Posted on Mar 07, 2009
Toshiba Satellite Automatic shutdown on startup
Try F8 upon start-up and use safe mode to boot then try a doing a system restore, it may have installed an update automatically that conflicts somehow
Apr 23, 2010 | Toshiba Satellite A135-S4527 Notebook
Blinking toshiba satellite A 05-54547 problem
A blinking monitor just might be a loose connection of the main display cable that runs up the left side of the display and connects to the motherboard. Also check the two wire cable attaching the inverter to the screen. The bezel of the screen will have to be removed as well as the power strip and keyboard to check the display cable. Remove the lcd screen from its hinges and look behind the display, there is a flat cable that plugs into the top edge of the screen. This cable has a habit of getting loose and falling out of the socket.
Now there is a chance that the BIOS of the laptop needs to be updated. There are many instances where the display starts acting up and a BIOS update is the correct action to take. Go to the Toshiba support site, put in the model number and then put in your operating system. Scroll down to where the BIOS is listed under downloads/drivers. Download and install the new BIOS, reboot.
Nov 08, 2009 | Computers & Internet
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Found a Toshiba laptop, about 2 years old. Screen
at two years old it is basically exctinct already and the costs of laptops coming down so rapidly you can probably go on craigslist or ebay and find a cheap laptop that is working and ready to be portable. you can also try and sell the toshiba online for parts
Sep 02, 2009 | Toshiba Satellite A135-S4427...
Toshiba laptop won t start up
try taking the hard drive out then switch it on without it then switch it back off, put the hard drive back in then it should work, if not try f8 then safe mode and do a system restore
Jan 19, 2009 | Toshiba Satellite A60 Notebook
Toshiba satelite a45-s130 manual
turn on my toshiba satellite a45-s130 hear one beep and the screen stays on for a couple seconds and shuts off.
Nov 03, 2008 | Toshiba Satellite A45-S130 Notebook
Cursor Will Not Stay Put
Try uninstalling the drivers from the device manager, then do a hardware search. It will automatically find the touch pad and reinstall the drivers. If this doesn't work, then check the connector under the keyboard. Disconnect it and reconnect it, they sometimes work loose. If these don't correct the problem, then you have a faulty touch pad and you'll have to replace it.
Jun 20, 2008 | Toshiba Satellite A45-S250 Notebook
TOSHIBA SATELLITE L40 SCREEN SHOWS A FUZZY TOSHIBA LOGO AND GOES BLACK
change your flexible wire (vga) connected from board to the screen, also change your module, the module is at the rear of the screen.
Jun 02, 2008 | Toshiba Satellite A135-S2276 Notebook
Cover will not stay opened
It sounds like you need new hinges for your computer. I didn't see any for your particular model on eBay which would be the best place to look but you may be able to contact Toshiba and order replacement hinges. To replace the hinges, you will need to remove the bezel from the LCE screen and possibly the power button board, depending on how your particular laptop is put together.
Jun 21, 2007 | Toshiba Satellite 2415-S205 Notebook
Toshiba Satellite 2405-S201 Notebook Logo
370 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
