Question about Necchi Sewing Machines
In what order do i put the tension assembly together
And it will not sew one stitch
  • 374 Answers
Probably the most important contol on your machine is this one that regulates your top thread tension there are reason for having to reset your tension.Classified your fabric that you are using there are several set up of tension in every fabric that you use.Cotton fabric is most easier other than silk fabric make a record on this set up.The required tension depend upon the stiffness of the fabric,thickness,layer of rabric to be sewn and required stitches.Try cotton fadric turn tension dial to N0. 3 and Stitch set to from 8 to 12 defend to what is nice to you.
Posted on Mar 07, 2009
Information on brother ult2003d machines
"So Long" means to increase the number of stitches.
Not filling in I'm assuming means you are missing stitches. Check underneath the fabric to see if the top stitch can be seen.
"No" will mean to increase the bobbin tension. The top tension should be on about four. This is the same bobbin tension that you are aiming for.
Oct 02, 2016 | Brother Sewing Machines
My thread tension dial came unscrewed. What order do I put it back together??? Any diagrams to help?
wire first, 2 pieces that look like tiny plates (thread goes between them) then the stitch indicator then the knob that holds all together
Oct 07, 2014 | Sew D'Lite Lightweight Portable Mechanical...
Deagram of tension assembly for white sewing machine 1418
This is why you take the machine to a trained professional.
The only thing DIY about a sewing machine is what you can sew with it.
Jul 15, 2014 | White Sewing Sewing Machines
How do I get the stitch length to be consistent? It changes with speed
consistent stitch length depends primarily on tension settings. there are 2 different tension settings on all machines. 1. upper thread tension. 2. bobbin thread tension. since these work together to create the correct stitch length+width, having either of these adjusted inappropriately can significantly impair stitch quality. "knowing' your machine has a lot to do with knowing how tight or loose the tension should be for BOTH settings. the settings will be different for each type of stitch, for each type of needle used, and for each type of thread used, meaning tensions will need to be re-adjusted after each change. in other words, the setting for a medium-width zig-zag with a size 10 needle using mercerized cotton thread to sew light-weight canvas will be completely different than the settings for a regular straight stitch using a size 8 ball tip needle using polyester thread to sew silky lingerie material.
Jun 14, 2014 | Brother PC-420
My juki 8700 h frays thread while trying to sew
Hello Daniel, I suggest you start with a new needle. Back off the needle thread tension and the bobbin thread tension to a minimum and see how it sews. If it does not ravel the thread, you can increase the tensions until you acquire the stitch you want.
Mar 26, 2014 | Juki DDL-8700 Industrial Straight Stitch...
When sewing, the top stitch and thread is fine. when you look under it is a huge mess of upper thread. I have cleaned shuttle, fixed the bobbin, replaced bobbin and upper thread. A number of times.
Recheck the tension on the top thread. Test it before you put it through the needle to see if there's any tension. It should pull but with some resistance. Also check the needle and make sure it is the right type for the fabric and not bent etc.
Looping on the underside of the stitch is from the upper thread, usually tension problem. But do check the bobbin tension and make sure it isn't too tight, though that's not usually the problem you're describing. The two tensions need to work together in order to get a nice, flat (not puckered or loopy) stitch.
One last thing you might check too, though again this wouldn't typically be the problem - is the dogfeed moving the material along under the presser foot correctly?
Most of the time the problem you're describing is due to not enough tension on the upper thread.
May 31, 2011 | Brother Sewing Machines
No tension on bobbin thread
You might remove the bobbin assembly looking for a broken tension spring (maybe a piece of it lying in the bottom the bobbin case.
Jul 19, 2009 | Husqvarna Freesia 425
Underneath stitch bad
Sometimes even though the tension is at recommeded placement, you may find with various fabrics or threads, you have to adjust it. I would try to raise the tension just a bit. Try it a little at a time until you achieve a stitch you are happy with. If adjusting the tension does not correct the problem, double check your threading. If sure it is threaded properly, especially going through the tension assembly...check your thread. I have found that the thread you use can and often does create tension problems. Try changing the thread and see if the stitch quality improves.
Mar 21, 2009 | Bernina Virtuosa 150
Pfaff Creative 7570
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}You need to do a tension assembly test
Tension assembly test. To do this test. Pull the threadthrough the tension assembly and test it to make sure the tension is workingcorrectly.
(To do this test, adjust your tension setting to normal or medium or 5 orsomething in the middle. Raise the presser foot and pull the thread through thetension. It should pull easily!! Lower the presser foot and pull the thread. Itshould pull noticeably harder.)
If it doesn’t work this way then you probably have a pieceof thread or lint stuck inside the tension discs. To remove it, turn thetension to 0 zero and raise the presser foot.Using a small screwdriver, openthe space between the discs and spray with canned or compressed air( a needle will work also). The stuffshould come out. Do the tension test again to make sure you got everything andthen try sewing again.
sewman7
Nov 18, 2008 | PfaFF Creative 7570
Stitching a mess
Either the thread is not in the tension assembly, the tension is not adjusted high enough or the thread is not in the take up assembly.
It's possible you have the wrong bobbin in the machine.
sewman7
May 20, 2008 | Singer 6038 Mechanical Sewing Machine
Sewing Machines Logo
239 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
