Question about HP Pavilion dv6325us Notebook
Start up with hp6325us
My computer is running vista. i had the laptop for 2 years. one day i tried starting up the laptop and it did nothing but stay in a black screen. all the quick play buttons are on the sd slot light is on and does not shut off. the funny thing is when i switch the hard drive it works. i placed my hard drive into my daughters computer and it works on hers and her hard drive works in mine. both computer starts up fine. i did a recovery disk on her computer for my hard drive, but when i placed it back into my computer case, it still did the same thing...nothing. any ideas before i through this laptop out the window/\?
  • 398 Answers
I think its the pentium processor had one a while ago with same problem , dont take my word for it though, just a thought
Posted on Mar 07, 2009
My laptop is stuck on the screen before the page for the login screen, it is a blinking dash, with a black backdrop, it has been stuck for 2 days, what is wrong with it? And how can i fix it?
If the DeLL Post screen comes up it means that your laptop is okay. Pretty much your windows is corrupted and that's the reason why it's not starting up.
Things that you can do: (for windows vista & windows 7 only)
1. Restart the PC and immediately press F8. (You need to tap/press F8 repeatedly while starting up). You should get a screen that says "Advanced option menu."
2. Select Last known good configuration. If it does not work. restart the pc and press F8 again.
3. Select Repair your computer.
4. Run start up repair. If nothing happens. Run system restore. If it fails, the boot manager file of windows is corrupted.
Last option, you could try Dell PC Restore by pressing CTRL + F11 at the same time while the system is starting up. (You could start pressing CTRL + F11 when the DELL flash screen comes up).
NOTE: Running Dell PC Restore will erase your files/data & put your system back to factory settings.
Dec 31, 2010 | Dell Inspiron 1545 Notebook
I have a lenovo 3000 n100 few days back i formated my hdd and installed windows xp over vista running before but now the is no display when i start my pc just a fan runs for a about 5 sec and then stop...
Hi. Since the computer is turning on we may try draining the electrostatic energy of the motherboard. Take out the batery and unplugged the power adapter from the wall socket. Press and hold the power button for 30 secs and put everything back in then turn ON the computer. If same problem appears then this cold be an LCD problem.
Sep 09, 2010 | Lenovo 3000 N100 Notebook
I have a relatively new 16" Husqvarna chainsaw, and I have the hardest time getting it started....sometimes I can't even get it started. Once I get it going, it usually runs fine, but it is extremely...
We have a Husky 435 (two year warranty) that was new last year. It would start and run fine for several days, then nothing--took to warranty service where they replaced the ignition module the first time. Ran for several more days, then nothing again--this time they replaced the carburetor and it seems to working fine from then on. Suspect that Husqvarna has had problems with our ethanol-blended fuels. If you still have warranty coverage, then take advantage. Hope this helps!
Jul 15, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Acer desktop PC locked up and now won't turn off or boot up
I've seen a similar issue on Acer Veriton 7900. When you unplug the power chord while the machine is still running the BIOS/CMOS gets bugged up. If your PC doesn't have a 3 year warranty you can clear the CMOS/BIOS. To do this, note the following...
1.) Unplug the power cord
2.) Remove the CMOS battery from the unit
[OPTIONAL] move the jumper on the mainboard to the 'clear position' It should be indicated on your mainboard.After 30 seconds move jumper back on original position
3.) Wait for 30 seconds
4.) Place CMOS battery back into its position
5.) Reconnect the power cord and attempt to power on the unit.
May 13, 2010 | Acer Computers & Internet
Stuck in hibernation
turn system off remove battery...leave alone for ten minutes...have a cup of tea...
turn system on ..leave battery out use mains only.
boot up ..then turn off properly..
now insert battery and happy days.
boot up
Sep 15, 2009 | Compaq Armada E500 Notebook
My satellite A105 is running slow and it has in the last few days started to turn itself off, while I am working.
hey here are somethings you need to do.
1) Open internet explorer -> Tools-> Internet options ->General -> Browsing History -> Delete -> Check all boxes -> Delete. (IE 8, The process is quite similar in other browsers as well)
2)For XP
Start-> Run-> type temp-> Ok-> Select all-> (Shift +Delete)
For vista
Start-> Start Search-> type temp-> Ok-> Select all-> (Shift +Delete)
3) For XP
Start-> Run -> type %temp%-> Ok-> Select all -> (shift+delete)
For Vista
Start-> Start Search-> type %temp%-> Ok-> Select all-> (Shift +Delete)
4) Turn off laptop, Remove battery , Remove AC adapter, Press power button for 2 minutes. Put both back on. Turn on laptop.
5) Run virus scan and check for malware and other virus related issues. If anything is found delete the infected files.
6)
For XP
Go to Control Panel-> Add and remove programs-> Remove all unnecessary softwares
For Vista
Go to Control Panel-> programs-> Installed Progams->Remove all unnecessary softwares
7)
For XP
Run-> msconfig-> Startup->Disable all
For Vista
Start search -> msconfig -> Startup -> Disable all
8)
Check for the system RAM. If your laptop has 2 memory cards installed. One might have failed. So try to remove it and fix it back again and check
9) Get the fan checked.?
Aug 15, 2009 | Toshiba Computers & Internet
My hp laptop turns on but nothing is on the screen
It sometimes happens when u use sleep or hibernate on computer using Vista that it doesn't start properly. You would have to use sleep regularly tho. In your case i'm not sure. Sometimes computer randomly manages to run properly and other days it just won't start even after many tries. Just repeat process of turning it on until it starts properly. If it does it's probably the case of what i mentioned... if it doesn't problem might be somewhere else ( maybe your power cord is damaged and your battery too? ) i had friend with the same problem and it kept getting worse. They had to change motherboard or power source for her i'm afraid. Hardware change is definitely required i guess. Good luck
Apr 04, 2009 | HP Pavilion dv2000t Notebook
Computer turns on but screen wont
First,If you are running windows vista,This can be due to an update that has your video driver and windows video driver running at the same time.
Hardware would be the invertor board is bad.
Ttry to start with F8 and choose start in vga mode,If this allows you to start normally,go to the device manager and update the video drivers
Feb 22, 2009 | Toshiba Satellite P205-S6337 Notebook
Battery discharges, and will not charge, computer wont run on AC
how long have you had your laptop? the toshiba laptop battery can be normal used in 400-500 cycles, that means normal in 2 years. if the age is over 2 years, the battery declines day by day. get a new one if it is unnormal
Dec 04, 2008 | Toshiba Satellite P35-S609 Notebook
Startup
hi,
you should have specified about your laptop. but you can try the following steps.
1. check the powercord and battery.
2. check screen brightness and contrast.
3. assuming that you login . click start-> run ..( msconfig ) -> and press ok-> in the window that appears click the startup tab. now click disable all. this will probably help..
4. or you might be running Vista in a 512 ram.
5. or you can try to insert the windows installation disk and start the laptop. and if the blue screen appears continue reinstalling the OS. this would probably help.
Dec 30, 2007 | Sony (B99860307) for VAIO PCG-K series...
HP Pavilion dv6325us Notebook Logo
96 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
