Question about Orion STV2763 27" TV
Orion NOFTV2701 27'' No Volume Sound
3/6/09 The volume and number are displayed on screen but there is know sound. On the 2/16/09 I had a dish satellite installed. On the 3/5/09 the sound quit. I called their tech support and they check their system, they said that at was the tv. Could you help?
Thank You.
When I tryed to enter a product. Orion FTV2701 27" TV, It said please enter a valid product. So I enter a product on the list.
  • aragon1234 Mar 08, 2009
    It pays to check all the cables.
I think my two year old grandson plug in the audio in cable into the earphone jack in front of the tv causing the problem. When my daugther unplug it the volume worked.
Thank You aragon1234
Posted on Mar 08, 2009
Get my dish reciever, sony home theatre, and 55in sanyo tv to work together
If your TV and sound system both have a Digital Optical Out/In you can use a TOSLink cable (an optical cable) to connect your TV directly to your sound system, and remove the connection between the DISH receiver and the sound system. As long as your sound system is on the right input, all sound accompanying the picture on screen will go to your sound system. Most TVs also have an option to turn off the internal speakers, if not just reduce your volume all the way down to avoid that weird ghost sound effect. If you use your sound system all the time for volume, you can program the sound system to your DISH remote's AUX, and even set the remote so that it only sends volume and mute commands to the sound system (that way you don't have to dance between sat, tv, and aux all day, just leave it in sat mode).
To program your remote to the sound system, follow the instructions on the sheet you got with the remote (yeah, right like anyone kept that) http://www.mydish.com/support/remotecodes you can use that link to program your remote. You can also use the learning mode if your remote has a little glossy square on the top left side and you have the original remote to the sound system. (Learning mode can be gleaned from the remote manual Remote Control Manuals)
After programming the aux device, and verifying that it changes the volume up, down, and mute, THEN:
Hold AUX until light blinks 3 times, hit pound (#), Volume Up, 0 (Zero), pound (#), SAT, then test to make sure it goes up and down.
Sep 24, 2014 | DISH Network Televison & Video
I have an Orion 46 inch led tv and the volume is on 100% but still sounds low
We have the 46 inch also and the volume is very low even on the highest setting. Our solution was going to walmart and buying a entry level surround sound system. We found one by Vizio for under 110.00 and it brought the Orion to life, being just what the Doc ordered.
Mar 05, 2013 | Televison & Video
Muted my sharp le 810 and now i can't retrieve the sound
If you push the volume button on set does it show on screen?
My guess would be the sound may be turned down on the box or tv or maybe in the TV menu the speakers may be turned off.
Does not sound (pardon the pun) like a circuit repair but like an error.
Check all audio settings or options first in the set and then the box.
Mar 21, 2012 | Sharp Televison & Video
Sounds stop working after about 1 to 2 hours of viewing.
We would be happy to help you with this. The volume levelingfeature that we have sounds perfect for this situation; it keeps the volumelevels consistent between programming and commercials and also prevents drasticvolume level changes when switching between HD and SD programming. The volumeleveling feature is supported by the following receivers: ViP 222k, ViP 612,ViP 722k, and ViP 922; the model number of your receiver is displayed onthe front in the lower left corner. Your receiver needs to be connected by onof the following: composite cable (green, blue, red cables), coax cable (singlecable with metallic tip), HDMI or optical devices that do not support Dolbyaudio.
Start by pressing the menu button on your DISH Network remote control, thenpress the number 6 for system setup then 7 for audio output. Once therehighlight the "Enable" option below Volume Leveling and press select.Once enable exit the menu by selecting done on the right side of the screen.
We hope this helps to get things set up the way you like it. Thanks forchoosing DISH Network!
Phillip Chang
DISH Network Customer Service Representative
Jan 17, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Samsung TV - have sound/auto volume set to on. When TV is turned off and then on, tv volume is extremely low. Go back to sound menu, it shows "on" but if you go back and act like you are turning in on, the...
Hello Blindrid,
What I would suggest you do is Press your MENU button on the tv remote, Then down to SOUND and then Turn the AUTO VOLUME to OFF. Then come out of the menu screen.
Just to check that it has all work correctly. turn you volume upto a certain number for example 25
Then turn your TV off the turn it back on. Wait until it is displaying a picture then press the volume button Once either up or down and you should see that it will go to 24 or 26 depending on what button you pressed for the volume. This will keep your volume set to whatever you had it on before you turned the tv off.
Hope this Helps Please leave a thumbs up.
Cheers
Little Dish Fitter
Oct 06, 2009 | LG 37LG30 37 in. LCD HDTV
What is the code for sky remote to operate orion tv-32082 a
please follow the steps below:
TV
RED + SELECT
TV
0236
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Aug 13, 2009 | Orion PM4202 Television
Sky remote
Orion
0549
322,383,263,205,039,065,053,205,348,349,392,544,572,
more..
054
Try this maybe it will help
Feb 01, 2009 | Microsoft Windows XP Media Center Edition...
I need the parental control code for a 19 inch Orion color tv
go to a channel that will let you turn tv sound down to zero. then turn tv to channel block asking for password. next on the tv hold the volume down button and at the same time hold down the number 0 on the remote. It should unlock
Feb 16, 2008 | Orion1934 19" TV
No pictureq
maybe you have defective heater line tru the CRT board! check the heater line if have a 4.5 volts or 4.8 volts! can you see the back of picture tube!?! they lights coming out at the neck of the tube! if no light! you have defective heater supply!
Oct 16, 2007 | Orion1934 19" TV
Orion STV2763 27" TV Logo
195 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
