Question about Dell OptiPlex GX280 PC Desktop
Can't boot my Dell Optiplex GX280 from the
Bought a new 80gb sata hd and wanted to do a clean install of Windows XP. have the cd drive 1st in boot sequence. turn machine on, it goes through initial dell setup, then screen goes black. i cqan hear the hd and the cd drive working their little tails off, but nothing happens. eventually, all goes silent and i'm stuck with a black screen and a silent computer. any ideas. I've tried everything i can think of, short of taking it to my local repair shop and spending 30 bucks for them to fix it.
  • 5 more comments
  • dragontears Mar 07, 2009
    the bios recognizes the hard drive, so i don't think that's the problem. it's the only drive in the machime, so it should be the master. and would that have anything to do with the cd/dvd drive not reading the boot disk? i know the cd/dvd drive works as i've been using it for almost a year without problems. i have a brand new hp running vista, can i put the new drive in that and load xp, then move it to the old computer?
    LOL You won't believe what I did to fix the problem. I was trying to run the computer through my 47" HDTV (as I had done before), so , as a last ditch effort, I plugged in an old 15" VGA monitor, and guess what? A boot window for the CD popped up and I was able to install XP. Guess the motherboard doesn't have the cajones to handle the 47" monitor. So, problem solved and thanks for all the input from everyone.
  • Sean Raithby Mar 17, 2009
    if its a SATA harddrive the bios will most of the time automaticly comfigure to the hdd settings
  • Jaidan Apr 05, 2009
    im bummed out....i have a **** IBM 15 inch computer screen right....anyways thats not the point ok what happens with mine is i turn the computer on and it loads up the IBM screen for the monitor and at the top right hand corner it says press F2 for set up and F12 for boot menu i press F12 boot menu and it just goes to setting i press F2 set up and it goes black.....its realy fustrating...ok so i tri reboot it with a Windows Xp cd and it goes to the IBM screen loads up then says "press any key to boot from cd" i press it then is says somthing like "system is inspecting your hard ware configuration....." i wait then it goes black what do i do?!
  • sean routt Apr 15, 2009
    my gx280 dell has a cd stuck some where . i put in the cd and when i opened it the cd was gone. cant get the cd to eject it will open but the first disc i put in has dissapperaed please help me
    i got a new gx280 i put a cd in and it didnt work when i ejected it there was no cd. i cant get the cd out what can i do. ive tried a different cd and that works fine but the first one is lost please help me.,
  • Wumpus Apr 16, 2009
    Similar sort of thing for me, except I'm only using a 19" widescreen TFT screen, 1440x900.
    The GX280 won't boot with the monitor plugged in.
    If I unplug the VGA cable, boot the machine, then plug the VGA back in, it works fine!
    I think the GX280 simply doesn't like resolutions it doesn't understand, and won't get through POST as a result.
    I'd try using a plug-in graphics card, except that it's a small case so the card needs to be PCI-E and half-height, and I don't have any of those handy.
    What with all those bad capacitors I had to replace as well....
    Won't buy Dell again, that's for sure.
The fix
unplugged the CD drive & set the DVD drive to be the Master
Clearing CMOS Settings
Posted on Jul 17, 2010
I have booting probleam with my dell optiplex 280..after showing dell in blue at statup it just shows a command prompt ob black screen and don't go further to boot windows.I am really fed up of this is there any solution.I am hating my pc and thinking to change the brand with hp
Posted on Feb 09, 2010
  • 565 Answers
U need to use the sata drive floppyor windows xp corporate with sata drivers. can download from torrents.
If helped rate fixya
Posted on Mar 07, 2009
  • Dell Master
  • 3,051 Answers
Hi there
hey if you boot into bios and you need to make sure that the computer will recognize the hard drive and that the jumper that is on the hard drive is set as either master or slave depending on what you want than make sure that of the parameters are right and apply it. than restart the computer and than see if the cd will now boot and you should be able to continue from here ok
best regards mike
1720 s.m.a.r.t HDD detects imminent failure the computer cant boot-up.
if you haven't got a good back up, external to the hard drive, it may be too late
dead hard drives are mostly un recoverable
take it to a computer repair shop to make sure that it is not a boot problem
if the hard drive is failing, replace it with a solid state hard drive that has no spinning discs to fail
Jan 13, 2017 | Computers & Internet
Satellite S50-B-15P Hi I want to find out what type of SSD drive is installed in my laptop. I want to up-grade to higher capacity. Thanks
Download SiSoft Sandra. It will tell you exactly what you have and also test every component. The best program by far and has been since Windows 98.
http://www.sisoftware.net/
Jan 11, 2017 | Computers & Internet
Will not start up
hi , Reuben
I would suggest you try safe mode.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
Follow the steps to boot the computer in safe mode with networking:
1. Restart your computer if it is powered on.
2. Tap the F8 key after your computer initially powers on.
3. Once you see the Advanced Boot Options menu you can stop tapping.
4. Use the up/down arrow keys to highlight your selection.
5. Select Safe Mode with Networking and press Enter.
6. You should see drivers loading, and then please wait.
7. You should then be at the Welcome Screen.
8. Logon to your computer using an account with Administrator privileges.
May 27, 2015 | Computers & Internet
What is the difference between windows 7 editions: starter, home basics, home premium,ultimate, professional,interprice?what is the difference between service pack 1 & 2???pc
Since October 31, 2013, Windows 7 is no longer available in retail (except for the Professional edition preinstalled):[6]
Windows 7 Starter Windows 7 Starter is the edition of Windows 7 that contains the fewest features. It is only available in a 32-bit version and does not include the Windows Aero theme. The desktop wallpaper and visual styles (Windows 7 Basic) are not user-changeable. Microsoft originally intended to restrict users of this edition to running three simultaneous applications but this limitation was dropped.[7]This edition was available pre-installed on computers, especially netbooks, through system integrators or computer manufacturers using OEM licenses.[1][8][9] Windows 7 Home Basic Windows 7 Home Basic was available in "emerging markets", in 141 different countries.[10] Some Windows Aero options are excluded along with several new features.[1] Home Basic, along with other editions sold in emerging markets, include geographical activation restriction, which requires users to activate Windows within a certain region or country.[11] Windows 7 Home Premium This edition contains features aimed at the home market segment, such as Windows Media Center, Windows Aero and multi-touch support.[12] Windows 7 Professional This edition is targeted towards enthusiasts and small-business users.[1] It includes all the features of Windows 7 Home Premium, and adds the ability to participate in a Windows Server domain.[1] Additional features include support for up to 192 GB of Random-access memory (increased from 16 GB),[13] operating as a Remote Desktop server, location aware printing, backup to a network location, Encrypting File System, Presentation Mode, Software Restriction Policies (but not the extra management features of AppLocker) and Windows XP Mode.[1] Windows 7 Enterprise This edition targeted the enterprise segment of the market and was sold through volume licensing to companies which have a Software Assurance contract with Microsoft.[1] Additional features include support for Multilingual User Interface(MUI) packages, BitLocker Drive Encryption, and UNIX application support.[1] Not available through retail or OEMchannels, this edition is distributed through Microsoft Software Assurance (SA).[1] As a result it includes several SA-only benefits, including a license allowing the operating of diskless nodes (diskless PCs) and activation via VLK.[14] Windows 7 Ultimate Windows 7 Ultimate contains the same features as Windows 7 Enterprise, but unlike the Enterprise edition, it was available to home users on an individual license basis.[1] Windows 7 Home Premium and Windows 7 Professional users are able to upgrade to Windows 7 Ultimate for a fee using Windows Anytime Upgrade if they wish to do so.[1] Unlike Windows Vista Ultimate, the Windows 7 Ultimate edition does not include the Windows Ultimate Extras feature or any exclusive features as Microsoft had stated.[1] All editions will receive Mainstream Support (new features and bug fixes) until January 2015 and Extended Support (security updates) until January 2020.[15]
Dec 08, 2014 | Computers & Internet
Error code 0151
hard drive failure. replace with new drive and reinstall whatever os you choose. i recommend 240-480 gb ssd.
Apr 12, 2014 | Dell Vostro 1015 Laptop Computer (Intel...
I have an imac computer model M6498EMC that is without a hard drive.I have all kinds of sata and ide drives.can i install one of these and how do i do it exactly
You will find at the bach of the PC there are little 'doors' with screwed covers. find an empty slot slide drive in and screw down then connect up inside to the loom on a spare socket
Sep 27, 2013 | Computers & Internet
I can't hook my monitor up to my pc I have a dell optiplex gx620 Sff
On the back of your PC there is a blue 15 pin video connection. Connect your monitor to this video connector, power up your monitor the boot up your PC.
Mar 23, 2013 | Computers & Internet
I can't get my computer to accept my user password to logon to my computer; password is correct and is being typed correctly. I get that wrong username or password message. In addition to this, my...
Please download the ERD Winternal Image from http://www.mininova.org/tor/857048 and burn it in a CD.
Thenboot your PC from the CD. Select your Windows Media Edition for whichyou have forgot password. Without asking for any password you will getinto Windows. Then goto control panel->User Accounts->Select theUsername[for which u want to change password]. Then use change passwordoption to change password. Then Reboot the PC and remove the CD. Nowyour windows password will be reset.
Thanks.
Mar 08, 2009 | Computers & Internet
Dell OptiPlex GX280 PC Desktop Logo
3,353 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
