Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Circuit problem possibly??
I have a 2001 model PT-51HX41 Panasonic CinemaVision HDTV that is rear projection. I checked out the lamps and all are working but there is a double image on the screen in two different colors. The double display is about 3-4 inches apart and someone said it could possibly be a circuit issue. What is a reasonable cost to fix something like this if I were to pay a repairman to do it?
I paid a repairman to fix it and got additional info that i didn't know about HD TV's. only $275
Posted on Mar 07, 2009
Problem with Panasonic PT-53WX54J 53 in. Rear Projection HDTV Television - Green Screen
You may have a component failing in the red drive stage possibly the blue as well or even the quadrature stage. A can of cold shot should help narrow the search considerably. It is also possible the red and blue projection tubes are nearing the end of their service life as well. If you have the means to test the tubes themselves, check the red and blue tubes for gas.
Dec 19, 2011 | Panasonic Televison & Video
Convergence Circuit Schematic diagrahm for my panasonic cinemavision rear projection HD TV? Picture of the convergence circuit on my circuit board.
I will need the model number of your set to assist you with your request. Please respond to this same post for assistance
Oct 21, 2011 | Panasonic PT-51HX41 51" Rear Projection...
WHAT LAMP SHOULD I ORDER FOR MY PT51-HX41E
This Model PT-51HX41 is a Projection TV ,it has 3 Tubes Red/Green/Blue and does not have a Lamp. What makes you think that one of the Tubes is Bad? What Seems to be the Problem with set?
Jan 09, 2011 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic Cinemavision PT-56hx41e, wording on screen is red?
the convergence circuit governing the red picture has gone defective and needs attention possibly a convergence amplifier IC or and convergence coil at the red CRT went defective
Apr 28, 2010 | Panasonic PT-56HX41 56" Rear Projection...
Panasonic HDTV from 2001. 51
I had the same problem and fixed it myself with a kit from www.TvRepairKits.com. Works great now.
Jan 09, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Bad color then no power on 51'' panasonic cinemavision
Check the power light for blink code--usually if this model shuts down the power light will blink in a sequence--3 blinks a pause and 3 blinks is short protection--usually means a convergence circuit problem.
Let me know what you find--I am here to help.
if this helped you rate this solution as I do this here for free.
SD TECH
Dec 17, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Replaced convergence chips, have new problem
Did you check the 2.2 ohm 2watt resistors? As often one or two will blow when the old ICs fail. The 3 blink error is indicating a problem with the convergence circuit still.
Jun 19, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic cinemavision hdtv 1080i projection TV. Is this tv digital? how does one access the digital aspect?
go to this link for the manual.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=d17d8491251fb501911086409da7f697&modelid=275504&q=Panasonic+PT-47WX49
Jun 11, 2009 | Panasonic PT-47WX49 47" Rear Projection...
No hdmi input?
You can use the component inputs on your Tv which is almost as good.
Mar 30, 2009 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic cinemavision pt-53wx54j
if the led is blinking one time its the 140 volt circuit. If its blinking a series of 3 blinks its the convergence circuit
Feb 15, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
146 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
