Question about Acer TravelMate 529ATX Notebook
Acer Travelmate 529atxv states max memory as 512mb
Found 512mb 100pc low density 144 pin modules on ebay, was wondering if I could use these to boost memory to 1024 Thanks
    Problem Solver:
  • 16 Answers
512mb is the max memory amount this computer will accept.
Each memory slot can hold SDRAM, PC133 with a maximum of 256MB per slot. Two slots total. Hope this helps.
Posted on Mar 07, 2009
How to remove keyboard to change cmos battery for Acer TravelMate 529ATX PC
I have an Acer travelmate 529ATXV and need to change the CMOS battery. I think it is under the keyboard but I am not sure how to remove the keyboard. Any help would be appreciated.
Mar 08, 2010 | Acer TravelMate 529ATX Notebook
Does the acer aspire 5315 2077 require a certain type of memory?
Go to www.crucial.com and click on the scan my system button to see what configuration of Memory Modules are installed on your laptop.
Here are some other details:
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Chipset: Intel 960GML
Drive Form Factor: 2.5"
Drive Interface: SATA
Maximum Memory: 2048MB
Slots: 2 (2 banks of 1)
Standard Memory: 512MB removable
USB Support: 2.x Compliant
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: DDR2 memory with support for DDR2 PC2-5300 speeds.
Q: How much memory can my computer handle?
A: 2048MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No.
No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
Q: Does my computer support dual-channel memory?
A: Yes.
Jan 14, 2010 | Acer Aspire 5315 Notebook
How can i know if a ram suits my Legend QDI
you got to options
1. following the indications of your motherboard documentation (recommended/best), if you need to find out details about your motherboard you can possibly download and use one of this tools to get info about your motherboard and possibly find the manual online in the manufacturer's website
2. the following page will check your system to find out what memory you have and what you need and up to how much you can go http://www.crucial.com/promo/index.aspx?prog=uslp_intel_fbdimm
3. checking on ebay: in the following links indicates that it should be low density:
Module Size: 512MB
PC133 SDRAM
UNBUFFERED
Non-Ecc
168 pins
3.3 Volt
Structure: 64Mx64=512M
Low Density: 2 Banks of 32Mx8
SPEED: 133MHz
CAS Latency: CL3
hope this helps
Nov 22, 2009 | QDI Group QDI Advance 10T Motherboard
PC Motherboard Query
Hi there
This Socket 754 board will accept up to 3GB of DDR 400 memory and an 8x AGP video card
Thanks for Using Fixya
Jan 13, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
RAM upgrade is not working
A 200-pin PC-3200 SODIMM should work in your machine but it will clock down to 333MHz. Your computer has 2 slots with a max of 512MB per slot (1GB total system memory). For maximum compatibility you should stick with a low density (16-chip - double-sided) PC2700 DDR-333 SODIMM with a CL of 2.5. Link below to see an example:
http://crucial.com/store/listparts.aspx?model=Pavilion%20ze4300%20Series
-E
Dec 25, 2008 | HP Pavilion ze4365us Notebook
P4S8X-X motherboard. Latest list of compatable RAM 1.gb
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.
  • Chipset: SiS 648
  • Supported DRAM Types: DDR SDRAM only
  • 184-pin DIMM Banking: 3 (3 banks of 1)
  • Module Types Supported: Unbuffered only
  • Max Unbuffered DDR SDRAM: 3072MB
  • Error Detection Support: Non-ECC only
  • Graphics Support: AGP 8X
  • Max Component Density: 512Mb
  • USB Support: 2.x Compliant
  • Jul 06, 2008 | ASUS Computers & Internet
    2 x 1GB Samsung PC2100 appearing as just 1GB (2 X 512MB)
    Hi Patrick,
    I see you're point. I know this, you can not run "more than" 512MB in any DIMM slot. That is shown at the bottom of page 10 & the top of page 11. You can not run both types of memory at the same time, even though the chart looks like you could. The description term on page 10, states; Users only can install either 168-pin SDRAM Module or 184-pin DDR DRAM Module at one time. (You can't run both). You can run 4x512MB in all banks using184-pin DDR SDRAM. Or you can run 4x512MB in all banks of 168-pin SDRAMs. Total of 2GB.
    So you can not run 1GB of memory in any bank.
    Mike
    Jun 29, 2008 | Jetway V266B Motherboard
    Upgrade to ram
    It's probably high density memory, it's a common problem amongst bargain hunters. There's more about it at the link below:
    eBay Guides - Myth Low Density vs High Density memory modules
    You'd be better off getting your memory from somewhere such as ebuyer or microdirect.
    Hope that helps. Please remember to rate this solution if you found it useful. Thanks for using FixYa,
    erch.
    Mar 19, 2008 | FIC P4M-800T Motherboard
    Upgrading acer laptop RAM
    You Can Actually Upgrade This To 2 Gig Memory.
    Each Slot Will Take 1 A Gig Strip.
    I,d suggest Buying another 256 mb Strip, To Put Into Slot 2.
    Or Buy a 512mb ( Half Gig ) Which Will Give you 750mb With your Existing Strip Already In There. ** Recommend 1 Gigabyte Max** 2 gig of Ram in This Baby Would Probably Start Glowing.
    You Can Buy DDR/266/333 In 256/512/1 Gig Strips. These Are Commonly Known As SD-RAM-Modules.
    Mike @ Compurepair.
    Feb 28, 2008 | Acer TravelMate 2500 Notebook
    Acer TravelMate 529ATX Notebook Logo
    204 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
