Question about Aurora Electronics Office Equipment & Supplies
How many ten tons dumptruck you get from an area against height
Given 17,500 sq meter area with an average height of 60 ft.. how many 10 tons dumptruck can you get
Posted on Mar 07, 2009
I am trying to figure out the square footage for siding on my house the front and back are 50ft long by 8 ft high. the sides are 30ft by 8 and then the peaks
50 X 8 = 400 multiply that by 2 ( front plus back) = 800 sq ft
sides 30 X 8 = 240 again by 2 for both sides = 480 sq ft
add both sums = 1280 sq ft
now to work out the triangle areas for the peeks you have to provide the vertical heights of the peaks and use the formula for areas of triangles (1/2 base by height) to get the rest
however you have not considered on the window/doors areas that could be used in the apex areas
you have a basic area but you are advised now to get quotes from cladding companies who can calculate it to close area to save wastage
Aug 01, 2017 | Heating & Cooling
My pool is 16feet wide by 32 long 10 feet deep what is the square footage
What you looking to know?
Square feet suggests a flat area, like the floor plan of the pool, which would be 16 x 32 = 512 square feet. Like you'd measure walls for tiles or paper etc.
As you've given 3 dimensions, sounds like your after the cubic capacity/volume of the pool, in which case your looking at cubic feet (same as flat area above, but with the added depth to go from flat 2d, to 3d (2 vs 3 dimensions)), which would be 16 x 32 x 10 = 5,120 cubic feet.
Jun 02, 2015 | Pool & Spa
How do i convert 60 tons of ashpalt to square yards
AC is approx. 145 lbs per cubic ft.
there are 27 cubic ft in 1 cubic yard
60 tons x 2000 = 120000 divided by 145 = 827.58 cubic ft divided by 27 = 30.65 cubic yards
square yards would depend on thickness of AC.
you can take thickness x sq ft to get cubic ft
in concrete 1 cubic yard =
4 inch thickness = 81 sq ft or 9 sq yrds
6 inch thickness = 54 sq ft or 6 sq yards
Feb 16, 2015 | Heating & Cooling
1904 sq feet how do I convert this to linear feet for roofing
I have done tons of roofing and we always use square feet .length X width= sq ft .like 50 ft long by16 =800 then double to get both sides of roof is 1600 sq ft
Feb 12, 2015 | Cars & Trucks
Hi i need to know how to convert 80 sq ft to cubic meters
You don't. Square feet is a measure of area while cubic meters is a measure of volume.
Consider a room 8 ft by 10 ft. The floor area is 80 square ft. What's the volume of the room in cubic feet (let's not worry about converting to meters yet). Well, that depends on the height of the ceiling, doesn't it? If the ceiling is 8 ft high then the volume is 640 cubic feet. If the ceiling is 12 ft high then the volume is 960 cubic feet. Without that third dimension, you can't calculate the volume.
Oct 18, 2013 | Office Equipment & Supplies
If on a certain flexible pavement, there is a pressure of 100 psi along with a loding of 50000lb. can u please tell me how to go about and calculate average pressure or what to do with the loading...
I'd assume that this meant 50000 lb load causes an overall (average) pressure of 100 psi, and so the area (not originally given) is
50000 / 100 = 500 sq in = 500 / 144 = 3.47 sq ft
It is not possible to figure the average pressure from your data (if it isn't 100 psi) as the area is not given.
Sep 17, 2013 | Computers & Internet
How many tons in 3 cubic meters sq by 3inchs deep
I am sorry to say it but your units do not make sense: Units of volumes and areas are mixed up.
Let us try to make sense of it.
If you have some container whose base is 3 square meters (not cubic meter sq) and it has a height of 3 inches you can calculate its volume in cubic meters or in cubic inches or cubic feet. To do so convert the height in inches into meters and multiply the area of the base by the height in meters and you will obtain the volume in cubic meters. To get the volume in cubic inches convert the area of the base to square inches and multiply by the height in inches.
However, even after you have expressed the volume in one unit or another (m^3 or in^3) you cannot find the mass of the substance contained (be it in tons, tonnes or kilograms): You need to know the substance and more specifically its density or its specific gravity).
Please, reformulate your question and specify the substance that fills or would fill the volume. Without that information, nothing doing.
Apr 08, 2011 | Office Equipment & Supplies
What is the capacity on my Rheem Classic High Efficiency Outdoor a/c unit. I have a home that is 3200sqf. It seems to be on some type of a damper system... Is this unit big enough for my home?
depending who you talk to a ton will cover about 500 sq ft (as some say 400 sq ft others say 600 sq ft). I believe your unit is a 3 1/2 ton unit. Below is a chart
0sf-750 sf= 1.5 ton
751-1000sf= 2.0 ton
100sf1-1250sf=2.5 ton
1251sf-1500sf=3.0 ton
1501sf-1750sf=3.5 ton
1751sf-2000sf=4.0 ton
2001sf-2500sf=5.0 ton
I would say if you have two units then you are covered, remember the area(region) walls, ceiling and other climate factors will play into your tonnage for you house. The best thing is to consult with a honest and reliable a/c installer in your area. i hope this helped Tim
Sep 02, 2010 | Ruud UAMB042 Air Conditioner
I have a GE model No. BTN 748A100A1 (central air outside unit). Serial number 40564128. When was it made? What is its efficiency? It now handles #1950 sq. ft. Cab it handle 2950 sq ft when I remodel?
GE stopped making AC units probably 20 years ago. The same unit will not handle an additional 1000 sq. ft. I believe it is a four ton unit and about a 6 SEER rating which is way down on the efficency scale. You will need a 5 ton system to handle 2950 sq. ft. The average SEER rating now is 13.5.
Oct 07, 2009 | GE Heating & Cooling
Linear equations
This question is strangely worded and does not pertain to floppy drives. However, taking all information here as given and sufficient enough to form the equations, you arrive at the following:
60(3.25) = 195 One tenant must pay $195 more for his extra 60square ft.
(975-195)/2=390 The remaining rent (assuming the given info is all that is needed to solve)
390/3.25=120 is divided between the two and represents the rent of the smaller bedroom.
y=120 sq ft The rent of the smaller room holder is divided by $3.25 to reach the sq ft.
x=180 sq ft
Sep 17, 2008 | Computers & Internet
50 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
Jim Keysor
Level 1 Expert
Level 1 Expert
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
