Question about HP Compaq Presario 6370US PC Desktop
1 Long Beep accompanied by Monitor not Turning on...
I recently bought two new sticks of 512 MB RAM to replace the old two sticks of 256 MB's. Both sets of RAM were the same type... PC 2100 DDR. When I finished up replacing the RAM, I went to turn on my computer, but the monitor would not turn on. After a few tries of taking the new RAM out and putting it back in I went to install the old 256 MB's of RAM. But this time I heard a long beep coming from my Computer (about 5-7 seconds estimated.)
I checked online and found out that it had something to do with my RAM or my Video Card. But to me that does not make any sense, because I put the old ram back into the computer, and the same result occurred.
Is there something wrong with my Motherboard? Or some other problem that I do not know about? Any assistance is greatly appreciated.
  • natili_micha Mar 07, 2009
    Hey tbirdfan1, I tried all that you said and still my monitor will not turn on and that long beep is still occurring. Do you have any other advice, that you can give me? Thanks in advance... Mike
  • 101 Answers
Good Day ! I exactly know why can not work your aging memory since meet often with such situation in my operation. Do Not worry this easy solved problem. You must to clean from dust ALL contacts on motherboard and memory modules, use pressured air, ore vacuum cleanser, be carefull.
After that you must to clean yelloy "pins" ("contacts" ) on the both sides of the each modules. Use for it fabrics ed by alcohol. then contacts will shine, put it back to you mother board. I recommend also remove and install 5-6 times in slot for better results. Same procedure you can do with video card, it be very useful.1 Long Beep accompanied by Monitor not Turning on. - 75851e2.jpg
Posted on Mar 07, 2009
  • HP Master
  • 3,051 Answers
Hi there
what you can do is to power down the computer and remove the power supply cord and open the case, now find the power supply cord that goes to the motherbord and unplug it now press the computers on button and also a reset if you have it. than plug in the cord back into the mother board and doublecheck that your memory modules are inserted all of the way i would try only 1 at a time and see if the the computer will now boot if so than try to add the second one and see what happnes you should get a memory change message ok. please try this and let me know how this goes for you , there is more that can be done but this is the easiest thing first
best regards mike
  • Michael Thomas
    Michael Thomas Mar 07, 2009
    Hi there again
    can u tell me if you have a built in video card or a pci slotted card i have a gateway here i just recieved today from a friend with the same issue and i was able to get this one going by removing the card and reinserting it into a different slot and i know it is wierd but it now works so you may want to try this also
    best regards mike
  • Michael Thomas
    Michael Thomas Mar 24, 2009
    Hello again i dont know ifn your problem is solved but if you can uninstall all of the memory and reinstall 1 at a time ,,and reboot and see if you still have the same long beep after each memory stick installation
I have a Packard Bell desk top PC In 2006 I Installed windows vista I noticed I needed a 512 ram as I had 256.I bought a 512 ram I knew were to install It ,I took the 256 ram out and carefully put In...
You put in the wrong type of memory. Put the old 256 back in the computer should power on with no beep code(or all good beep). If this is correct make sure to obtain the same type of memory as the 256. Also both slots must have the same RAM. You cannot have a 128 with a 512. They should both be either 128 or 512.
If you are using Vista you should have a minimum of 1g RAM.
Jun 08, 2011 | Computers & Internet
How to do jumper setting on RAM upgrade from 2 x 256 MB to 2 x 512 MB.
Good day,
Theres no need to jumper anything in upgrading your Ram, Just remove the 256 mb rams and replace it with your 512mb ram. Then try turning your PC on.
Feb 01, 2011 | Acer Aspire SA20 PC Desktop
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. http://www.memorystock.com/memory/Gateway838GM.html Rob
Dec 01, 2010 | Computers & Internet
Computer beeps six times after installing new game. Precision workstation 670. Ram sticks are a 1GB each. My old ram works fine with the computer.
You need the EXACT speed rated RAM.
Your support page states it needs.....
400-MHz DDR2 SDRAM
NOTE: Your computer supports only registered memory
Memory capacities
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC modules to a max of 16GB
more info here
http://support.dell.com/support/edocs/systems/ws470/en/ug_en/about.htm
Jul 26, 2010 | Dell Precision Workstation 670 PC Desktop
I have a Fujitsu Lifebook E2010 with one 256 MB RAM module. When I try to upgrade to one (or two) 512 MB standard Kingston memory (266MHz Pc2100), the notebook won't boot, I only get 1-3-3-1 beeps which is...
Make sure that you got the right memory module with this specs:
Memory
  • DDR266 (266 MHz) so-DIMM 200 pin
  • 2 DIMM slots; upgradable to 1 GB total memory (512 MB x 2)
or better go to this link http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=GUIDES
there's a step by step troubleshooting for memory modules. Also make sure you purchase memory module from Fujitsu or Authorized Fujitsu Dealers .
You can also find us over the web, visit us at www.fujitsu.com or for Around-the-Clock Expert Technical Support you may contact us at :
Phone Support (Direct to Service Desk)
1-800-8FUJITS (1-800-838-5487)
Available 24 hours, 7 days a week.
Consumer Sales - 1-800-FUJITSU
Corporate Sales - 1-800-831-3183
Tech Support - 1-800-8FUJITS /1-800 8385487 or 1- 888 -3854212
-ERNZ
Feb 03, 2010 | Fujitsu LIFEBOOK E2010 PC Notebook
Problems with 3 brand new PC 133 512 MB RAM in Netvista 6794
That last RAM probably is good. Many motherboards have problems using many different memory. All of the memory you have should be at least identical to ensure that they work. When RAM run at different speed or require a little more voltage, they will not let your motherboard boot. You can try mixing up the order you put the RAM in. Try putting the last RAM in the first slot by itself, the motherboard should boot. Then try the rest.
Also, whenever you add or change hardwares, you should clear the CMOS/BIOS settings.
Jan 06, 2010 | IBM (49P1599) Motherboard
Change ram from 512 to 1 gig bios cannot read added ram
The original 2 sticks of 256 Mb of RAM gives you a total of 512
Mb of RAM. Two 512 Mb of RAM gives you a total of 1 Gb of RAM.
With two sticks of 512 Mb of RAM are you sure you got a total of 192 Mb of RAM, this is a lot less than the original RAM total of 512 Mb?
Should this be 1920 Mb of RAM?
If this 192 Mb is correct then the RAM modules are either not compatible with the laptop or if the RAM modules are not from the same manufacturer then they may not work together.
Most laptops have video cards that use part of the main RAM for video RAM, that is why the available RAM is less than the installed RAM modules. The amount of RAM the video card grabs depends upon the type of video card and in some cases the amount of video RAM can controlled in the BIOS setting.
Nov 07, 2009 | Sony VAIO PCG-K25 Notebook
E machine T1150 wont start up
Make sure you have the memory installed correctly. Those beep codes identify it as bad memory. Try the old RAM.
Good luck with this.
Mar 19, 2009 | E-Machines T6420 PC Desktop
PC RAM
This refers to the data width and chip configuration. 64*8 is an 8 chip 512MB module. (8 components @ 64MB each) 32*8 is an 8-chip 256MB module. (8 components @ 32MB each), etc.
Mar 03, 2009 | Kingston 1GB PC2700 DDR DIMM Memory
512 MB memory boards do not work in my Fujitsu Lifebook S2020
frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
HP Compaq Presario 6370US PC Desktop Logo
74 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
