Question about Thermador C301U Electric Single Oven
Oven not working after power outage
We had a power outage 2 days ago; since then the oven does NOT working. The lights for HEATING and OVEN flash intermitently. We plugged/unplugged but stil not working. We have the unit working for the past 5 years with NO PROBLEM until now.
textonor
  • 130 Answers
SOURCE: Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Posted on Feb 03, 2008
captaynkyrk
  • 170 Answers
SOURCE: Kenmore Ultra Bake GAs oven
Here's a link: http://www3.sears.com/ put in your make and model and you can order a manual. Good luck!
Posted on Jul 21, 2008
SOURCE: THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Posted on Dec 08, 2008
barkencoa
  • 3463 Answers
SOURCE: oven does not heat
I would suggest that you check the oven element, it sounds as though it is faulty to me.
Posted on Dec 14, 2008
barkencoa
  • 3463 Answers
SOURCE: bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Posted on Dec 17, 2008
My ge oven stopped working after power surged code coming up on front panel: LCDBoard 'T_PP_Profile_V_3_35' Main relay V3.2, Aux Relay V3.2 EEPROM PARAMETER PAGE CRC 15 OEBC Initalization in progress
How to repair an oven: resetting the power - YouTube
? 3:13
https://www.youtube.com/watch?v=HenawxpSYow
Feb 14, 2011 - Uploaded by VideoJoeKnows
How to repair an oven: resetting the power might be the only thing you have to do....can you imagine? "You mean it ... My ovendoesn't work: what do I do now? ... How to Fix an F1 Error On a Kenmore or GE Range - Duration: 11:41. ... Oven Repair-Not heating after self clean-Kitchenaid,Whirlpool,Maytag ...
GE Oven quit working, after power outage - DoItYourself.com ...
www.doityourself.com/.../363632-ge-oven-quit-working-after-power-ou...
Oct 14, 2008 - Hi, our GE Glass Top Stove/Oven stopped working after a power outage ... My guess: the circuit board on the oven (behind the digital display) ...
Dec 29, 2015 | GE Ovens
How do I restart my stove after a F9E0 code flashes?
The control thinks thinks the heating circuit is open was the oven in use when power went out possible one of the leads may have come off or burned off one of the elements I have seen outages damage a lot of controls with oven off try cancel/off, cancel/off then start to go into diagnostic press the 3 or ^ key till you get to errors follow the prompt to reset this my help
Apr 03, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Neither oven or broiler work. Upper elements work well. Why is the bake light flashing / blinking?
if it is not coming on then you may have the same problem again with the ignitor.
May 04, 2014 | Ovens
The bottom oven on my zanussi zuq 875 has stopped working. No power indications of any kind.Top oven works fine. Followed instructions in manual but no power at all.ie; indicator lights, fan ,oven light....
Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
Hope this helps.
Jun 13, 2010 | Zanussi Ovens
Oven does not heat
Dec 14, 2008 | Ovens
Ge double oven - both ovens stopped heating gradually
My first thought is the power supply to the unit.  Cut the breakers and inspect all connections from the fuse box to the oven.  You will likely find open connections or corrosion.  One breaker could also be bad.  Check the voltage with appropriate caution and a voltmeter.  Breakers should respond with a snap when turned on.
Note: there are two breakers which control the oven: one with a red wire, the other is black.  Each provides 110 volts to the oven in combination with the white neutral.  Together, the black and red give you 220.  If one of the circuits is out or in poor condition, the bulbs might not work and the oven won't either.
Dec 04, 2008 | GE JKP28 Electric Double Oven
WHIRLPOOL SUPER CAPACITY 465 (ELECTRIC) MODEL RF366PXGQ - F3 E0
Same thing happened to me about 1 month ago... Did you get some kind of power outage or lightning strike??? I am pretty sure the stove part works but the oven doesn't right?!?! It might be 2 things.. Either the temperature sensor inside the oven doesn't work or it's the control board (where the clock is). I tried to chaned teh temp sensor but it did not work. I then changed the Control Board and oven works again...
Sep 24, 2008 | Gaggenau EB 270/271 Electric Single Oven
Thermador C301U Electric Single Oven Logo
172 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
