Question about Whirlpool ED0GTQXMQ Side by Side Refrigerator
Ice maker was hot and could hear water dripping on
Ice maker was hot and I could hear water dripping on a hot item in the wall of the freezer compartment. Back wall of freezer was hot. The sound was like water dripping on a hot iron and creating steam. I shut off he water and turned off the ice maker. The back of the freezer wall is now cold and the freezer works fine. Do I need to replace the ice maker. The model number of the Refrigerator is ET18ZK
    Sergeant:
  • 300 Answers
Yes.you will have to replace the ice maker.if further used without replaceing the compressor will get damaged and you will completely loose cooling in your unit.
Posted on Mar 07, 2009
Intermittant ice making
When you see this happen can you feel the bottom of the ice maker to see if hot? What is the correct model number? I am trying to understand if it is the ice maker heating element is stuck on while heating the ice maker to release the cubes or if the water control valve is allowing the water to come in through the fill tube like a leaking faucet. Thanks, John Tripp Appliance 911
6aa070b8-d84c-4116-a3d3-21bc4d340b93.jpg PSS26MSRSS)?
Jan 27, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
My Samsung RF265ABWP French door refrigerator has suddenly stopped making ice. I hear the old familiar noise it used to make just before I heard the ice drop in the bucket, only no ice drops. It sounds...
Is it getting water? If not, Most likely water valve is faulty and not letting water through, or feed tube through back freezer wall to ice maker is frozen which would be caused by dripping valve. It's either the valve or the ice maker not sending voltage to valve.
Nov 12, 2017 | Samsung RF265AA Bottom Freezer French Door...
Water leak on back wall of my freezer and a hell of noise from my icemaker when on
Water leak and noise are due to wrong temp setting or malfunction of defrost cycking.Keep temp setting between 3 and 5 degree centigrade. Due to over frosting, the freezer fan fan hits over the ice and working to cool fridge compartment.And also check defrost timer, and heaterworking properly to defrost in time. And if your ice maker is making sound, due to:
  • You will hear a buzzing sound when the water valve opens to fill the water reservoir for each cycle.
  • Rattling noises may come from the flow of the refrigerant or water line. Items stored on top of the ice maker can also make noises.
  • The high-efficiency compressor may make a pulsating or high-pitched sound.
  • Water running over the evaporator plate may make a splashing sound.
  • Water running from the evaporator plate to the water reservoir may make a splashing sound.
  • As each cycle ends, you may hear a gurgling sound due to the refrigerant flowing in your ice maker.
  • You may hear air being forced over the condenser by the condenser fan.
  • During the harvest cycle, you may hear a "thud" when the ice sheet slides from the evaporator onto the cutter grid.
  • When you first start the ice maker, you may hear water running continuously. The ice maker is programmed to run a rinse cycle before it begins to make ice.
Hope, it's helpful>
Feb 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer door started dripping water when opened and item in freezer are defrosting. Also refrigerator not staying cool. Help
Hi and welcome to FixYa. I am Kelly.
In the fresh food compartment center overhead within about 6 inches of the front of the unit there is a circular hole. Inside that hole you will see a dial with 2 tabs on it. Use your thumb or a squared off utensil and rotate the tabbed dial slowly until you hear an audible "CLICK" The refrigerator should stop running and the defrost cycle begins.
After 45 minutes (+ or - 10 mins) the compressor should start again. Once the compressor starts, check both the evaporator fan in the freezer compartment and the condenser fan in the bottom rear of the unit to make sure they are turning at full speed.
If the compressor does NOT after 90 minutes re-start, rotate the defrost timer tabs of the dial in the overhead of the fresh food compartment until you hear it start again. The fact that the compressor did not start in under 90 minutes indicates a defrost circuit problem.
A slow running evaporator fan or condenser fan will cause poor cooling. Also in the back of the unit, check the right side of the condenser coils for lint / hair build up. If it is blocked the front outside chassis of the freezer section will be very warm almost hot to the touch. Clean as needed with a vacuum if you do find any lint buildup.
Once more thing is to check the ice maker. Quickly touch the bottom of the ice maker. If it is VERY hot to the touch then there is a problem with the ice maker itself and the mold heater can cause your freezer to warm up and overall unit performance to degrade.
A complete checkout of the ice maker can be found here: http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
Your parts can be found here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48360
Scrolling the left side of the page will access all sections of the unit.
Thanks for using FixYa.
Kelly
It sounds as if you have an automatic defrost problem.
Jun 13, 2010 | Maytag MTB2156GES Top Freezer Refrigerator
Water dripping from freezer into refrigerator area and frozen water in freezer
The defrost cycle is melting ice that will not go down the drain tube in the rear of the freezer. This can be a clogged tube due to debris, organic growths or ice blocking flow. What doesn't end up dripping into the fridge ends up freezing in the freezer compartment. Make sure the fridge is level or tilted back slightly.
Unplug the fridge from power. Remove the contents of the freezer and remove the ice maker, back wall plate and floor plate in the freezer section. Remove ice build up on the floor and tray in the freezer by thawing and soaking up water. Flush hot water (use a turkey baster to get at it) at the opening of the drain hose that is connected to the tray to thaw any ice.. once flowing to the evapraor tray under the fridge, mix up 1/2 oz of bleach and 4 oz of water and pour down the tube to kill any bacteria.
Reassemble and restock the freezer. Monitor the temperature of the fresh food (34 deg) and freezer (0 deg) compartments. If you notice the temperatures start to climb, there may be a problem with the defrost timer, terminator, etc. and may require a pro's help.
Mar 12, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is leaking from top part of freezer down to bottom of inside of the frig. Frost is on the top of the frig in the frigerator.
FIRST STEP: UNPLUG THE REFRIGERATOR. AFTER IT'S UNPLUGGED, DO THE FOLLOWING:
Remove the food from the freezer compartment and place inside the refrigerator temporarily.
Remove the bottom panel and back panel from inside the freezer compartment. You will probably notice that the bottom of the inside of the freezer is covered in ice. Use hot water (not boiling) from the tap and pour it on to the ice that is formed on the inside of the freezer compartment to melt the ice.
CAUTION: DO NOT USE A HEAT GUN TO MELT THE ICE AS IT WILL MELT THE INSIDE OF THE FREEZER COMPARTMENT. ALSO DO NOT CHOP AT THE ICE WITH A SHARP INSTRUMENT OF ANY KIND AS THIS WILL PUNCTURE AND DESTROY THE INSIDE OF THE FREEZER.
If you have a wet vac, you can remove the melted water using the wet vac. Or you can use a towel to mop up the excess water. You will still have to pour hot water onto the ice until all of the ice in the freezer is melted. Patience is key as it takes time to defrost all of this ice.
You will see a drain hole in the back of the freezer compartment that is still clogged with ice. You will need to continue to apply hot water until the ice has completely melted.
Note: When the ice in the drain breaks free, you will see all of the water disappear as it empties out.
In Whirlpool refrigerators, the water runs to a tray underneath the refrigerator. You will hear the water empty out into that tray. Then you will know that you have completely cleared the ice from the drain pipe in the freezer. To double-check this, take a small cup of warm water and dump it into the drain hole and you will see it visibly disappear and run into that tray underneath the refrigerator.
Replace the freezer panels back into the freezer compartment and plug it back in and return your freezer items back in to the freezer and you should be all set.
Oct 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
GE adora side by side refrigerator DTL181C5RRBS
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water coming from ice maker freezing down back wall of freezer
check for levelness of the ice maker also make sure that the fill tube is inserted all the way into the unit
Apr 25, 2009 | GE GSS20IEP Side by Side Refrigerator
Whirlpool Fridge makes a loud dripping sound all the time G56SHE
Erin,
The water you hear sounds like it's coming from the automatic defroster in the freezer compartment. It runs down a drain tube into the pan you describe under the fridge. The pan is heated and evaporates the water.
Just some possible explanations if you are hearing "lots" of water"
* You may be in a warmer, more humid climate
* The temperature and humidity in your dwelling is elevated
* The door gasket on the freezer may be leaking
* The freezer is too full
* The freezer door is not closing properly
* The freezer door is being left open for extended periods
* There is a problem with the defrost cycle
If you are hearing water running all the time, check the ice maker water line and fill valve (if you have an ice maker) - there could be a leak or other malfunction.
Apr 15, 2009 | Whirlpool ED5VHGXM Side by Side...
Water dripping inside refrigerator
the defoost drain is cloged the drain inlet is located in the freezer behind the back wall under the coils. to clear the drain remove the back wall in the freezer and clear the ice underneth the coils then use hot water to clear the drain inlet, I use a garden sprayer to spray hot water.
Dec 24, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Whirlpool ED0GTQXMQ Side by Side Refrigerator Logo
170 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
