Question about Kenmore 62622 Microwave Oven
The latch on kenmore micro #721-62622200 is broken at bottom
I ordered a new latch and spring (just in case) from Sears, it arrived today but I can't figure out how to take the door apart. I can't even figure out how to get it off the hindge. The door closes with top latch, but the bottom latch is what makes the microwave work and turn off the light. The light has been on for 3 days now. Can you help me?
    Sergeant:
  • 300 Answers
In order to have the correct operation of the door latch mechanism and latch switches.
  1. Ensure correct adjustment of the Door and the Latch switches.
  2. Wipe off any dirt or grease around the door key where it touches the latch switched and door hooks with a soft cloth. Maintaining the smooth movement of the latch mechanism and switches etc�
  3. After replacement of the latch mechanism and/or Latch switches. Make sure to confirm a smooth operation of these parts are in order.
to view the exact diagram of how to do this manually just click the link http://www.applianceaid.com/micro8.html
Posted on Mar 07, 2009
Door does not stay closed
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
The service manual for the R-408LS (the model you posted it under) is here.
You can order parts from the Sears Parts Direct Web site.
Oct 26, 2013 | Sharp R408LS Stainless Steel 1100 Watts...
Microwave door does not shut. Model#1481-1998
The full service manual is here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can order parts from Encompass here or the Sears Parts Direct Web site.
Jan 16, 2011 | Sharp Microwave Ovens
I have a frigidaire model fmv156dbf and the door latch will no longer operate. when i opened up the door i saw that the spring that is supposed to operate the latch was no longer attached. where the spring...
We have the service manual and have uploaded it to our site here to help you.
You can order parts here if needed.
May 26, 2010 | Frigidaire Microwave Microwave Oven
Kenmore Mod. 721.80524500 microwave door will not lock.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Mar 06, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Panosonic NN-S525BF Latch Spring Broken
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In most cases, the spring mount on the inner door panel breaks off, and while the ideal way to fix it is to replace that whole panel, the time, cost and labor are considerable.
It's usually easier and cheaper and just as effective to use epoxy and some kind of hardware to fashion a new spring mount.
Or if there is enough material to drill a hole for the spring, do that, install the spring, then add a dab of epoxy to cover the bottom loop of the spring where it goes through the hole you drilled.
Let the epoxy dry overnight before you close the door or use the oven.
Jan 24, 2009 | Panasonic NN-S254BF Microwave Oven
Broken door latch on Model 63679 Kenmore Elite Microwave.
You can find helpful exploded views by entering your full Kenmore model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Please be aware that you may have a broken spring mounting tab on the inner door panel.
In such cases, the best way to fix that is to drill a hole in the remaining material, insert the spring, then add a dab of epoxy where they spring attaches to the panel.
Jan 18, 2009 | Kenmore 63672 Convection/Microwave Oven
We have an old Sharp Carousel R-1440 that works great, except for the door latch broke (i.e. doesn't work at all now). Can we replace just the door?
Actually, the door latch head (hooklike device) is pretty easy to replace or repair if that's the issue.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
We have critical safety & disassembly info at our site, linked here.
Sep 27, 2008 | Sharp Microwave Ovens
The safety door latches no longer latch.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
Aug 11, 2008 | Sharp Microwave Ovens
Sharp Carousel Microwave door latch stopped working door won't stay closed
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 18, 2008 | Sharp R-1480 Microwave Oven
Panasonic inverter door won't shut, light stays on.
Thanks for the tips - here is what I did (my wife calls me the Canadian McGuyver!) After taking off the plastic frame (using instructions in Solutions noted above) I used the metal part of a key ring and hooked one end to the spring and looped it around the thick finger/protrusion at the bottom. _197.jpg
Jan 28, 2008 | Microwave Ovens
Kenmore 62622 Microwave Oven Logo
529 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
