Question about LSI Logic MegaRAID® SAS 8344ELP (5 Pack) (LSI00058) Storage Controller
LSI Web BIOS won't start?
I've installed a LSI MegaRAID SAS 8344ELP controller into a Windows VISTA PC. Following POST, after pressing CTRL H the Web BIOS utility should launch. Instead I have a black screen for a couple of seconds then Windows launches normally.
Web BIOS configuration utility is supposed to the operating system independent?
Does anyone have a resolution to this?
  • 1 more comment
  • Anonymous Mar 20, 2009
    I encounter the very same problem... did you find a solution ?
    Best regards,
    Alexandre
  • sgrinavi Apr 11, 2009
    Vista 64 - I can not start the Web BIOS with CTRL-H.
    Rampage 2 Extreme
    i7-920
    BFG 800ES PSU
    LSI Logic MegaRAID® SAS 8344ELP Storage Controller
    4x Vertex 120 SSD
    4x WD 640 AAKS
    ATI FirePRO V8700
  • richtig Apr 16, 2009
    I got the same problem, with my LSI SAS HBA 8708 ELP.
    When I press CTRL-H it shortly states that WebBIOS will be shown after BIOS Post, but then start as usual, or does nothing, if there's no alternate OS available.
    Could you post, which mainboards you have, because I suspect that it's caused by improper handling of the PCIe X16 Ports on ASUS Mainboards. (I got P5WDG2-WS Pro)
I have a LSI 8888ELP on a Asus P5Q Deluxe and had the same problem with not being able to access the Web BIOS.
What I found was I could access the Web BIOS if I disconnected the hard drive that plugged into the onboard controller.
Posted on Oct 28, 2010
Install dell sco
did you try to take out the battery and replace it with a new one yet?
Jul 11, 2013 | MPC Computers Netframe 620 Server
Asus p5q deluxe not detecting lsi megaraid
Hello i suggest you download a manual from here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5Q_Deluxe/#download
The manual can be found by selecting the windows system.
Click global for download.
Any files has to be unziped before use.
My guees is that the screen card or other pci-e
card has a defect and must be renewed.
One of your harddrives could also have a fault.
Try to boot with only one drive.
The power supply could have a fault also.
Please install any missing drivers.
A bios upgrade can sometimes solve this.
Good luck
Nov 13, 2012 | Computers & Internet
Windows 2003 OS installation problem on LSI MegaRAID 320 SCSI CARD so how to install windows. pls advise
use floppydrive to select driver / dump server media & drivers into on folder.use windows unattended cdcreator to create media with drivers
Mar 25, 2011 | LSI Logic MegaRaid SCSI320-4X (320x4128t)...
I have an asus dsbf-d server motherboard installed with two Intel Xeon E5410 Harpertown 2.33GHz processors and 16G ram. I have four 1 TB WD hard drives I want to set in raid 10. I want to install xp 64 bit...
http://support.asus.com/download/download.aspx?modelname=DSBF-D&SLanguage=en-us
Select Windows XP 64 from drop down box. Check for files under SATA (click the plus sign). Have you already tried the LSI MegaRAID?
Nov 25, 2009 | ASUS DSBF-D/SAS Motherboard
Boot Manager
You will want to do a Windows Recovery Environment Startup Repair, follow the instructions below to fix this issue:
To access the WinRE using the Vista install disk:
  1. Boot from the Vista install disk
  2. Choose your language settings and click "Next"
  3. On the bottom of the screen click the link "Repair Your Computer"
  4. Select the Vista installation to repair and click "Next" and it will launch WinRE
The following options are available in WinRE:
  • Startup Repair - It will repair the boot manager files and restore critical files required for booting Windows Vista.
    After attempting to repair the system it will display a Startup Repair diagnosis and repair log with the different Test Performed and the probably root cause.
Dec 16, 2008 | HP Pavilion dv9000z Notebook
LSI Logic MegaRAID® SAS 8344ELP (5 Pack) (LSI00058) Storage Controller Logo
4,548 people viewed this question
Top LSI Logic Computers & Internet Experts
David Payne
David Payne
Are you a LSI Logic Computer and Internet Expert? Answer questions, earn points and help others
