Epson Stylus Photo R2400 InkJet Printer
Problem for Epson Stylus Photo R2400 InkJet Printer
Epson 2400 paper red light and ink red light
By debsteve54 on Mar 07, 2009
epson 2400 paper red light and ink red light flashing power light off. How can I fix this?
Same Problem
May 18, 2009
-   how do you resett counter chip after ink pads are full
-   fothering
Best Solution
posted on Mar 08, 2009
Very Helpful)
jacklee366
Rank: Wiz  Epson Expert
Rating: 84%, 232 votes
you need to reset the printer download the ssc and it will reset it for you or add me to msn and i will send it you jacklee366@hotmail.com
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Mar 09, 2009
Very Helpful)
websnail
Rank: Guru  Epson Expert
Rating: 92%, 217 votes
It sounds like your printer has reached what is often called the "service required" stage...
To solve this you need to handle two things.
1. Get the printer protection counter (or waste-ink as it's sometimes called) reset.
2. Replace the waste ink pads OR redirect your waste ink flow to an external tank
It's important to note that Epson will encourage you to do a waste pad replacement through one of their service centers, but if you're out of warranty this will cost a significant amount of money (approx: $100 - 200)
To solve these as a DIY you can do the following:
1. Resetting the counter...
Get a resetter, either the SSC utility (google: epson SSC utility) or the IPR utility that Epson have now made available via their website here
The latter is only available to North American printer owners so the SSC is a safer bet.
2. Redirecting waste ink to an external container.
This is something I'd heartily recommend instead of trying to change the waste pads yourself... It's simple enough to do and a little googling using keywords "Epson R2400 waste ink tank" should get you all the info you need.
There are simple kits available that offer everything you need or you can easily go for a DIY with bits you have to hand.
Hope that helps...
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #3
posted on May 05, 2009
Not Rated)
jfj2
Rank: Apprentice
Rating: 0%, 0 votes
Trying fix you posted on www.fixya.com:epson 2400 paper red light and ink red light flashing power light off. I have installed external ink waste container. Am running Cone Color CIS. When I run either the Epson utility or SSC Service utility I get message: A supported model could not be found connected to this computer. Have powered down and up; powerd down, disconnect pronter from computer, reconnect and power up with no luck. What am I doing wrong
Was this helpful?
Yes
No
Popular Solutions for Epson Stylus Photo R2400
Questions and Unsolved Problems for Epson Stylus Photo R2400
Do you recommend Epson Stylus Photo R2400 InkJet Printer?
Answer
Answer
can we print 300 gsm papper on hp inkjet f735 oll in one printer
Answer
mac updated software automatically, then printer (lexmark x4850) will no longer respond. Error... (More)
Answer
Hello, I have an Epson R2400 printer that was working just fine on My 2 year old Imac running OS... (More)
Answer
My Photo R2400 is suddenly now printing everything with too much magenta. Faces come out reddish and... (More)
Answer
Lexmark P700 (Vista) says printer ready but does not print
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in Van Nuys, CA
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
