Question about Apple iPod nano MP3 Player
Ipod wont turn on. ive tried everything! none worked! HELP!
Ok so i have the Ipod nano chromatic. the yellow one. one day I was listening to music and my ipod just went black. i mean i could still hear the music but then i shut my ipod off and tried to turn it back on but it wouldnt. i tried charging my ipod in my ipod dock but that didnt work so i connected it to my computer. yes, itunes did pop-up but it told me my ipod was going through recovery and would need to be restored. so i restored it. after the restoring procedure is finished it tells me the same thing over and over and over again what do i do now? ive already tried the menu and centre button thing and switching the hold button on and off and charging my ipod and restoring it, none of those solutions worked. is there another solution in fixing my ipod!??!
  • MorganTaylor Mar 07, 2009
    well specifically this is my problem: ok so one day i was listening to my ipod (the ipod nano chromatic 8GB yellow) then all of a sudden it turned off. So i used the Technique that usually works for me, holding the centre button and menu button at the same times making sure im holding the menu button on the outside. and toggle with the hold button. it didnt work. then i thought it died. but i rememebered it had a full battery and just to make sure i connected it to my dock. nothing happened.so i connected it to the computer and itunes popped up and it told me "iTunes has detected an ipod in recovery mode. You must restore this ipod before it can be used with iTunes." so then i click ok and then click on restore and it says "Are you sure you want to restore the iPod to its factory settings? All of your media and other data will be erased. and the newest version of the iPod software will be installed." so i clicked Restore and Update and it said "extracting software" and it loaded then it said "restoring ipod" and it loaded then it said "your ipod has been restored to factory settings. please leave ipod connected and iTunes will connect." so i clicked "ok" then it said iTunes needs to prepare your iPod for recovery. please leave your ipod connected" so i clicked continue and it said "preparing ipod for recovery" and it loaded then my ipod started beeping twice then it said "iTunes has detected an ipod in recovery mode. you must restore this iPod before it can be used with itunes" and thats exactly what it said at the beginning! my iPod is like my best friend and i cant lose it!
  • MorganTaylor May 03, 2009
    thanks so much!! i sent it in for warrenty and got a new one! tyhanks you!!
  • 342 Answers
You will want to attempt to force the iPod into disc mode before restoring. This should solve your issue.
Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Please let me know if this did not resolve your issue. :)
Posted on Jun 24, 2009
    Problem Solver:
  • 13 Answers
Send it in for warrenty? if not, then you could try reformatting the whole ipod itself then factory restore it?
Plug your ipod in the computer > my computer > Right click on your ipod > Reformat. This will clear your WHOLE ipod, keep the the settings recommended selected, then factory restore it.
Posted on May 01, 2009
  • Yawdim May 13, 2009
    reformat your ipod, but before you do, copy all your songs off of it via Mycomputer>*Ipod name*>Task:Unhiding files>Music>all folders
    You will have to filter through all the folders to get all your music out, but its worth it if you have music from other sources other than your own computer.
    hope all works out
    hope all works out
  • 89 Answers
Hmmmm have you tried going online to the apple website to see what they have to say about it? but my best guess would be taking it to an apple store and ask them there, that way they will tell u exactly what to do. and you just might get hooked up with a new one!
Posted on Jul 09, 2009
    President:
  • Apple Master
  • 688 Answers
Your ipod is toast, either the flash drive is bad or the motherboard is bad. it should still be under warranty.
send it in to apple for repair. if you bought the apple care warranty you can go into a store and they will replace it.
either way, it's worth sending it in, go to apple.com and click on support and look up service
Posted on May 19, 2009
    Problem Solver:
  • 8 Answers
Maybe the screen blew out
Posted on Jun 22, 2009
5 Suggested Answers
SOURCE: unsupported docking for Nano Chromatic
Your docking stations support the previous generation nanos but not current. If you can, return the docks otherwise you'll have to fork over the cash for a new one.
Posted on Jan 12, 2009
  • 3 Answers
SOURCE: Frozen ipod chromatic
give me suggestation about same modle soft ware
Posted on Jan 24, 2009
  • 10 Answers
SOURCE: ipod nano (4gb) - need to restore in itunes but won't restore
Hello, I've had exactly the same problem, and I got a bit bad news for you. Don't know how much you can call this a "Solution" but it worked for me. Get back to the shop were you bought it and show them you problem, I'm sure you'll get a new one back, because as they said on the shop to me: This is a critical error, which only can be fixed by going manually inside the iPod, and there's really nothing you can do by restoring it, or trying to restart it.
I know it sucks, but thats the thruth, but as I said before, you'll probably get a new one back, or at the worst case they will send it to fixing, and you have to wait like 2-3 weeks before you get it back, fine as new.
Hope it helps :)
Posted on Feb 17, 2009
SOURCE: My green Apple Nano Chromatic iPod's batter life & other problems
turn the backlight down or maybe let it charge even when the battery says its fully charged!
Posted on Dec 15, 2009
How to fix ipod nano chromatic 4th generation? the battery is charged but once iI unplug the ipod it wont turn on. ive tried to fix it with the reset and nothing happpens. how can i fix it?
Connect it to your PC, run iTunes, click on your iPod displayed on the left within iTunes, then click on the Restore button to the right. Wait for it to finish restoring, then resync your music it, unplug it and try it again.
Jan 01, 2010 | Apple iPod nano MP3 Player
Dec 15, 2009 | Apple iPod nano MP3 Player
Dropped My Chromatic!
Sounds like you damaged the backlight. A LCD replacement will fix that.
Try either http://www.ipodrefresh.com or http://www.ipodrecharge.com. They specialize in ipod repairs.
Mar 26, 2009 | Apple iPod nano MP3 Player
My ipod wont switch on
I would suggest you take it in to the apple store for repair already. Most often this type of problem is hardware related already.
Mar 07, 2009 | Apple iPod nano MP3 Player
Charging or plugging in my Ipod chromatic
i have the SAME problem but i bought mine 5 days ago so its suppsd to be brand new!! ='[ *sob* it just got 'stuck' all of a sudden and wont respond to anything! :S
Jan 30, 2009 | Apple iPod nano MP3 Player
:D! Okay, you unplug it and hold the middle button and menu button at the same time for a couple seconds until the apple sign comes up, Uhh then you just turn it on C:
Jan 21, 2009 | Apple iPod nano MP3 Player
My ipod nano chromatic ha water damage from the washer
Sometimes if you leave it sit for several days or so it will dry out completely and start to work again. I don't recommend charging it or plugging it in for several days or so as if there is still water in it, it may fry some of the chips. It may be beyond repair though.
Dec 29, 2008 | Apple iPod nano MP3 Player
WE BOUGHT A NANO CHROMATIC SEVERAL WEEKS AGO FOR A 7 YEAR OLDS XMAS PRESENT WE CONNECTED AND SYNCHED TO ITUNES AND PRELOADED MUSIC AND PHOTOS ON THERE, IT WAS FULLY CHARGED WHEN WE WRAPPED IT IT WAS OPENED...
Have you also tried this:
  • Turn on then off the Hold switch
  • with the ipod connected to the pc press and hold the Select AND Menu buttons together till the apple symbol appears.
  • If that doesnt work try holding Select and Play (this loads up disk mode). If that loads it will say something like Disconnect on the ipod screen. Now press Select and menu.
If none of these work then there is something more serious wrong with the device and it needs taking back to the Apple Store. Tip: Book an appointment with a 'Genius' online before you go.
All the best
Sean
PiDigital
Dec 26, 2008 | Apple iPod nano MP3 Player
Apple iPod nano MP3 Player Logo
3,921 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
