Question about Maximatic ERC-003ST Elite Gourmet 3-Cup Rice Cooker
My rice cooker is scorching on the bottom.
I am wanting to not need to turn off the rice cooker manualy. I am wondering if there is a way to shorten the cooking time so that I am not burning my rice on the bottom. I have noticed that other people are wanting to know how to have it cook longer too. How do you adjust the time it takes before the rice cooker turns off?
    Problem Solver:
  • 11 Answers
You need to make sure you have enough water in there. When the rice is cooking, it is sucking up all that water so it can cook and expand. If you don't put enough water in the rice cooker, the rice will use up all the water and then if there is no water left, it will start burning the bottom of the rice because there is no more water.
Hope that helps :)
Posted on Mar 07, 2009
Hi I was wondering if there's been any known problems with the rice cooker type "Tiger JAE-A18U 10-Cup Rice Cooker" and not being able to cook rice? I have this model and it only seems to be...
Have you tried scrubbing the inside (heating surface). Make sure there is no burnt on stuff on it and on the middle sensor (CENTER OF THE UNIT). I usually use a green scrubber with Comet. Also make sure that the bottom of the rice insert (outside) is clean.
Apr 20, 2011 | Tiger JAE-A18U 10-Cup Rice Cooker
How to use steamer
Do you mean how to use the steamer plate in a rice cooker?
If so put it in bottom of pan so the holes are uppermost and add water to barely cover the plate and then place whatever you want to steam on the plate. Turn rice cooker on.
Dec 15, 2010 | Kitchen Appliances - Others
Does my Aroma rice cooker have a fuse?
You have a bad connection because the wiring has been bent around too much and has failed...this will not be repairable and you need to replace the cooker...
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
May 27, 2010 | Aroma ARC830 6Cup Rice Cooker
Does steam tray/lid go on top or bottom of rice cooker?
The steam tray as you call it goes on the inside bottom of the cooker. It's purpose is to keep the cooking rice separated from the heating element during the steaming process. The basic measurement is 2 parts water to 1 part rice. Add a quarter cup more water for brown rice. The automatic shut-off won't turn off until the water is gone. It's magic! Cleaning; soak the cook pot and perforated plate to remove rice goo DO NOT USE STEEL WOOL PADS or abrasive cleanser. I use a nylon dish cleaning brush to remove the stuck on brown material.
Mar 14, 2010 | Panasonic SR-W06NA 3-Cup Rice Cooker
Need directions for Comet stove top rice cooker
Fill the bottom to the line with water. Put two cups of rice in the top and two cups of water. Put on stove top on high until lower water is boiling, turn to medium heat. For white rice check after about 20 minutes, if water is assorbed and rice is tender, fluff with a fork...eat. If it needs a few more minutes of cooking, no problem.
Brown rice will take about 45 minutes.
I have used my stove top cooker for at least 35 years...ordered it with box top and some money from Comet Rice.
Pat
Mar 09, 2009 | Kitchen Appliances - Others
Rice cooker keep feature turns rice crispy
This sounds like the thermostat inside the unit has went out and is overheating whitch in turn is cooking your rice too fast and too hot! if the thermostat is replaced it will cook the rice even again!
Please rate my response to your question
Thank You!
Jan 07, 2009 | Sanyo ECJ-PX50S 5-Cup Rice Cooker
Rice burning at bottom of cooker
Your cooker, along with mine, cooks very hot. If it is new then you can take it back, but if you want to cook with it then you need to stir the rice often. About every 5 minutes should be good. As soon as it is done you need to remove it from the cooker. Let's see how that works.
Aug 30, 2007 | Oster 4724 Rice Cooker
Sanyo ECJ-AC4E 4-Cup Rice Cooker
I need a replacement pot for the Sanyo rice cooker ECJ-AC4E. If the pot is in excellent condition, do you want to sell it?
Jun 13, 2007 | Sanyo ECJ-AC4E 4-Cup Rice Cooker
Maximatic ERC-003ST Elite Gourmet 3-Cup Rice Cooker Logo
405 people viewed this question
Top Maximatic Kitchen Appliances - Others Experts
George Merkley
George Merkley
raysaw
Irene Tulloch
Are you a Maximatic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
