Question about LG Washing Machines
It doesn't let me choose a cycle - doesn't work
I have a LG Intellowasher 7kg WD-8013F. Just moved house & when I have turned it on ALL the lights for each cycle are on (not flashing how it use to) & when I press the button to select - it doesn't do anything. Can you help?
  • dianaprinces Mar 07, 2009
    Is the clear button the on/off button? if so, when I press the pause & on/off button - the cotton cycle light is only one on & the spin light & temp light comes on
    Sergeant:
  • 300 Answers
The control pannel faulty needs replace ment. press the cancel/pause button and clean button together to reset the board.check it if gets reset then it will work orther wise replace control board.
Posted on Mar 07, 2009
LG intellowasher 7kg wd-8015c
SURE VINEGER IS VERY GOOD ON CLEANING WASHER
May 02, 2014 | Washing Machines
My washing machine turns on but will not start. It will only make a click sound then another click sound. Please help
Your timer swicth is defective or fuse inside but check first the cord if it not broken before you go to fuse and timer
Jun 15, 2012 | LG Washing Machines
Lg intellowasher wd-8013f is very noisy
it will definitely be the bearings and possibly the spider as well. the spider is attached to the bowl. the spider is made of aluminum and they corrode all the time. open the door to the machine and grab hold of the steel bowl, has it got movement on it. if it has then the spider and bearings are faulty, also the main shaft seal will need replacing.nearly every time i went to an LG 8013f that was noisy it was the bearings and or spider. hope this helps. please reply 4 more help. good luck.
May 09, 2010 | Washing Machines
LG Intellowasher 7kg, Model WD-8074FHB - noisy spin cycle
You are right!
Bearings have to be replaced. Replace with the same type and design. All the bearings connected to the washer center shaft has to be replaced at the same time with new set.
Replace the water seals also connected to this. Check the shaft where the bearing sits, for any abrasions or metal damage.
Check the bearing housing also. While carrying out these repairs check the drive belt also. If needed replace it.
If you are happy with the machine outer body and other aspects repair it and re-use it.
Apr 07, 2010 | Washing Machines
You suspect right.
It is a complete strip down job. I have just finished mine.
taking apart and reassembling is not too dificult.but you need to make up a tool to remove and replace the bearings which are two different sizes. It consists of a lenghth of studding, bolts and washers.
Download the manual from LG.
Good Luck
Mar 17, 2010 | Washing Machines
HOW DO i REPLACE THE LARGER RUBBER SEAL ON A lg INTELLOWASHER 7KG WD 8013f . The seal is mildewed
I have this problem and have been told the following.
You have to take 2 Cir clips off. one on the front which is achievable by opening up the spring that holds it in place. The second one is behind the front panel.
You need to take the top off first. Undo two screws on the back top. Then you can take the top off. Then take any detergent tray our and also the front control panel. Then you gain access to some screws which hold the front panel onto the chassis.
After you take the front panel off you can apparently access the rear cir clip and spring.
once this is removed you can remove the front seal for replacement.
Jun 15, 2009 | LG Washing Machines
Washing Machines Logo
657 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
