Question about Jl Audio 1000/1 Car Audio Amplifier
Low ohm light comes on and loud humming sound comes from amp and sub have a j1000 and 13 w7
  • 1 more comment
  • Anonymous Mar 09, 2009
    i have a problem with my jl 1000/1 amp the low ohm light comes on
    i HAVE A PROBLEMS WITH MY JL AMP.ALSO MY LOW OHM LIGHT COMES ON.DID YOU FIND OUT WHY THIS IS HAPPENING.WHEN I TURN DOWN MY VOLUME DOWN I HERE A LOUD HUMMING.
  • hmidv57 Mar 09, 2009
    I have 2  13w7 and 2 J1000 amps only on one amp gives me
    a loud humming sound and it seems when only the remote wire
    is tied in ,when i disconnect it it goes away!! =(
    Novelist:
  • 110 Answers
Nice set up, how many speakers are you running? you have something wired up weird causing the ohm level to drop to low. we can fix this let me know and ill help you.
Posted on Mar 07, 2009
Low independence light comes on and a humming sound what is causing this?
Humming from subs? If from inside amp, your experiencing a problem with a driver board. It makes transistors latch on and loads down the transformer, causing light to come on. And vibrations "hum" from transformer.
Oct 16, 2012 | Jl Audio 500/1V2 Car Amp
I looked up the correct way to wire my JL 13.5W7 1.5. Therefore it said to wire it in parrallel. I understand this will put it at .75 ohm. As I start to turn it up it sounds great, very loud but once the...
1000/1v2 Class D Monoblock Subwoofer Amplifier Specifications:
  1000/1v2
Rated Power:
1000 W RMS @ 1.5 ohm - 4 ohm (11V-14.5V)
THD at Rated Power:
<0.05% @ 4 ohm
S/N Ratio:
>95dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
Frequency Response:
5 Hz - 250 Hz (+0, -1dB)
Damping Factor:
>500 @ 4 ohm / 50 Hz
According to the chart your amp is only stable down to 1.5 Ohms, so running at .75 Ohms the noise you are hearing is the amp clipping (running more power than it can handle at low ohms)
I would suggest wiring it in series, or you could adjust the gain on the amp until the popping goes away.
Hope this helps.
Nov 10, 2010 | Jl Audio 13W7 Car Subwoofer
1300a, no sound, protect light
if u have the amp bridged un bridge it. chack an see wat the ohms are on the subs an make sure the amp is stable to carry the ohm load..if u have 4ohm subs one sub per channel then u shud be fine that wud make the amp see 4ohms but if u have dual voice coil subs it cud be the configuration of the subs..here's a link on how to wire subs hope this help..http://mobile.jlaudio.com/support_pages.php?page_id=145
Jan 12, 2010 | Car Audio & Video
Help with amp
BOX HAD TO HAVE CORRECT AIR SPACE FOR SUBS TO SOUND RIGHT . CHECK MANAUL FOR SUBS FOR QTS FS, HZ SPECS ,BUILD BOX ACCORDINLY USE MDF(MEDIUM DENSITY FIBEROARD ) OHMS MUST MATCH AMPS TOLERANCE, 2 OHMS ECT ....
Nov 12, 2009 | Car Audio & Video
I have two Jl 13.5s w7 they only pop
There should be no need for a series connection. The outputs on the amp are parallel inside the amp, requiring you to only connect the speakers separately to the amp. With two 4 ohm speakers, you will achieve a 2 ohm output [(4x4)/(4+4)] and be within tolerance.
The Low Ohm light will also illuminate in the event of a short. Check your speaker wiring, looking for any positive leads touching negative leads or for any leads that may be grounded to the chassis of the vehicle.
Feb 10, 2009 | Jl Audio 13W7 Car Subwoofer
Jl audio 500/1 amp low ohm light at high volume
I would try running the subs in parallel. Pos to Pos Dual Voice, Neg to Neg Dual Voice. Then Run + to + stereo - to - stereo on both channels.
So you have + and - running to one channel and + and - running to the other channel.
Also your LPF filter could be set too high.
Feb 07, 2009 | Jl Audio 500/1 Car Audio Amplifier
Sunfire Mk II hum (different from greekboy post)
I had this issue a few years ago and the power cable from one of the inner terminals had come loose. It was still touching but whenever the sub would really pound it would jump off the connection and then reconnect causing it to hum. It was the most annoying thing ever so I finally pulled off the amp plate (super easy) and you could clearly see the loose wire. I had to use a good soldering iron to put it back on since it's a pretty fat wire. If you're not under warranty anymore then pop the back off and see if that's the issue.
-Dylan
Aug 17, 2008 | Sunfire True Sub MK II Subwoofer
JBL d110 /w no sound output
There is a standby indication that activates after 10-15 minutes without any input signal. I suspect that might be what the red light is telling you - no signal.
Loud hum from a loosened cable is normal as hum usually means there's an ungrounded connection somewhere acting as an antenna and the amp is doing its job to amplify what it thinks is a signal, in this case 60hz stray ac current is being sensed nearby. It's a good sign that you get hum from the sub because that means the amp is alive.
Avoid manipulating cable connections with the Sub or Receiver turned on as you could introduce a static spike that could harm any connected equipment.
Are you certain a bass signal is making it into the sub? The complexities of modern AV receivers vary in how you configure them to direct LFE to a sub. Bone up on that end of the chain.
Or, just hang a CD player on the Inputs of the sub and play something with a reassonable amount of Low Frequencies.
>>>> Be advised that this way of testing has NO VOLUME CONTROL because amps without volume controls always operate at maximum gain, relying on your external controls to attentuate it (hence, the loud hum from a loose cable); so choose a track that eases into the loud parts with some quiet parts up front and BE READY TO PAUSE THE PROGRAM AT ANY SIGNS OF STRESS. <<<<
A living sub will produce only muffled rumble in the absence of other speakers producing the higher frequencies which carry the intelligence of the signal. If that works, back to the receiver for settings. If not... sigh.
For hum problems, even those you cause yourself:
Disconnect all inputs to see if that helps. If it goes away start with the signal cables and add in things until it comes back.
Sometimes the reversing the orientation of the AC plug can help with hum. Or it could be something like a loose or high resistance connection internal to the sub. Good luck.
Jun 17, 2008 | JBL PSW-D110 Speaker
Fusion sub..
check the impedenc on amp and speakers.if speakers have lower ohm the amp cant push them also can cause damage to amp.how do you have everything wired must be specific.high level inputs,rca,.how is the radio and amp wired together,where are you getting power sup[ply from and how?
chriszambrotta@yahoo.com
Jan 09, 2008 | Fusion FEW12PK Car Subwoofer
Amp heats up and goes into protect mode
Hi Saint108. You're describing it well, and i know what the problem is already. The MA audio amp, can't hold with a 2 ohm load. It's too low for that amp, that's for sure. Those are budget amps and they are not well built enough to handle low ohm setups like that. It's overheating and there's no ways around it.. Other than wiring your subs differently ! Just wire your sub directly (not in parallel) in a 4 ohm load, you will notice it will stop overheating that much. Do it quick, you'll most likely fry your amp giving it such hard work !! The HUM you're hearing could be related to it also. Try that, and keep me posted on the status. Thanks ! Cheebster.
Jul 02, 2007 | MA Audio Hard Kore HK-898 Car Audio...
Jl Audio 1000/1 Car Audio Amplifier Logo
504 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
