Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
TV powers up, but the picture won't come up. TV then trips back off.
  • clmolhusen Mar 15, 2009
    TV powers up, but the picture won't come up. TV powersoff again. I checked the fuse on the circuit board and it is fine. I noticed one component on the board looked to be over heating - labeled R7013. Can someone tell me what it will take to repair this and how to do it myself? Does the whole board have to be replaced? I don't see myself soddering on parts? What would a ballpark cost be?
    Sergeant:
  • 300 Answers
Check out the fuse on the main boasrd of the tv.if that is perfect then its the problem of  ic number 432 on the main board thats getting overheated. it needs replacement.
Posted on Mar 07, 2009
Why wont my sharp lcd LC-32D44U turn on?
Well, there could a be few issues. First thing is to verify the breaker that gives power to that wall has not tripped off in the home's break power panel. If it is not tripped then verify the wall outlet that the TV is plugged into has a reset button, like a GFI (ground fault interrupt) If it does then verify that it has not tripped. If the GFI on the wall plug is tripped simply push the reset button back in and then try plugging in your TV power plug again. Then if that checks out or does not have a GFI outlet, verify that the power plug going into the back of the TV is not loose. Unplug and replug power plug that plugs into the back of the TV in and verify it is securely connected. Lastly, the power supply in the TV might have gone out.
Aug 22, 2014 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Power surge tv won't turn back on
Check and replace its main power regulator board. Before replacing it, check the fuse, can be located on this board itself.
May 08, 2013 | Panasonic Viera TH-42PX80U Plasma TV
The light won't go on and there is no power going though the tv
Have you checked your fuse box for a tripped breaker? Resetting
breakers usually does the trick. The breaker box is usually in the basement or garage. If not, check your closets.
Apr 09, 2013 | Televison & Video
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
I have a 1 1/2 year old Panasonic TC-P42U1 plasma tv. While watching a show, it suddenly shut off and won't come back on. What do you think caused this and how can i fix it? Thanks.
Try unplugging it completely for 30 seconds to 1 minute. Plug it back in. If it still won't come on, it's likely taken a power surge and popped a fuse or power supply, which means a trip to the service center.
Jun 18, 2011 | Panasonic TC-P42U1 42 in. Plasma HDTV
My kid put a plug from the computer no power to it and it just went off it was pluged into the serivce port
It's probably just a fuse.
I don't have a physical layout of that TV inside though so if it's blown, I'd need pics.
Here's the possible good news though.
He may have simply tripped the power supplys' protection circuit.
Unplug the TV for 5 minutes and plug it back in, it may be fine!
It takes a while being unplugged to reset the power supply when that sort of thing happens.
If the TV still won't come on, you'll need to open it up and get some good shots on the power supply board and the board that the service port is on, and of the cable that connects the 2 of them together.
If the pictures are good enough, I can point out where the fuses are.
If the photos are necessary, post a comment or reply here and I'll give you an address to send the photos to.
Apr 11, 2011 | Vizio GV52LF 52 in. LCD TV
DLCD2602, TV SWITCHES ON BUT TRIPS AFTER A FEW SECONDS
It's like the power supply section problem. Please check all electrolytic capacitor inside the power section. Their ESR value also need to check to. Below is some good lcd repair site you can reference:
http://www.lcd-television-repair.com
http://www.fastrepairguide.com
Nov 20, 2008 | Televison & Video
No Picture, Menu screens or anything video - Sound still working!
Yes... Look for F851 and replace it with a slow blow 3.15A fuse per Toshiba. Bill
Jul 01, 2007 | Toshiba 43AX60 43" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
80 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
