Question about Pioneer Car Audio & Video
Need a manual . the led doesnt light up so i dont know what is happening to the unit when i push the various buttons
    Novelist:
  • 110 Answers
Check out
www.mobileinformationlab.com
that should be able to help.
first can you clarify what led you would be speaking of? is it the main display of the unit or the buttons are not illuminating? let me know and ill try to help you.
Posted on Mar 07, 2009
Turned on led tv and screen went black with sound only.took TV apart suspecting LED lights. How can I tell if it is LED light or power board failure before ordering. Seller will not give tech support
Sound only state may happen due to various situations. Be sure about yourself before proceeding anything further. One bad move can ruin the entire thing. I advice you to hand over the unit to a skilled person. But, if you prefer you can, go ahead
The sound only thing can happen due to various reasons. For example,
Bad connections,
Corrosion
Unit faileure (IC,active component..etc..)
So, a skilled personnel needs to check all the possibilities and rectify if any.
First of all, find the service manual/schematics diagram when you're into this type of "Operation". Find the signal pathways from mainboard to LCD first referring the service manual and the actual unit. Then Unplug the connector(In most cases, there will be a plug and socket type connection). Disconnect, clean and re connect it.
If that data link is soldered, re heat using a hot air soldering iron. Please note that this is a very dangerous thing if you do not know what you're doing..
If those things does not fix, refer to the LCD model number and find the datasheet for the LCD itself. Then check for the wires for the LED if you are sure the problem is with the LED lamps, check it with a multi meter.
Even though I have given you these instructions, you better hand over the job to a skilled professional.
Jun 07, 2017 | LG Cell Phones
Rpn 479v p x
Here is something you can try to see if it is transmitting out from the handset
Put your new battery in and push and hold down the button and look at the transmitter LED through a digital camera, a phone camera works fine. you don't need to take a picture, just look at the LED trough the camera.
If its transmitting you will see the LED light up.
Test this on your TV remote as you know this one is working so you know what to look out for.
If its not transmitting you know its the handset at fault, if it is transmitting its probably the recever.
Hope this helps a bit.
Feb 09, 2014 | Vehicle Parts & Accessories
Car garrage door opener
smart or learn button is located on the back of the garage door opener. (the machine that is over your head) on most units such as liftmaster, craftsman, chamberlin. its on back or side by the light bulb and is green, yellow, orange/red, purple. genie units are black button behind light cover. or external on old units. push and hold your cars homelink button will blink slow, at the same time push and hold the remote for the garage door. led light in car will blink fast. let both go. now go to the garage door head unit, (overhead) and push the learn button. button will blink and you have 30 sec. to go to car and push the cars garage door button. head unit should flash its light, letting you know that it is programed succesfully. genie units push 3 times
Dec 10, 2013 | Building Materials
I have hussmann 5-door with LED light two are not working i changed ballast but still not working any advise?
When LED lights refuse to come on most times it happens as a result of the light being burnt or one of the fuses which powers up the light has burnt up.Usually the LED lights are indicators of various conditions which the unit might be going through at various times. Best way out is to get an expert to check the control board for any inconsistencies. Once this is checked it should identify the real cause of the problem.
Hope this solution has been helpful?
Feb 09, 2011 | Refrigerators
Wired unit asper instructions. try to program unit, starting with transmitter. cycled key as says ,then with in 15 seconds bushed progrm button twice holding in on 2nd time, parklights flash and led...
you need to push it 3 times and then hold, to program the unit for tach, voltage or timer. It will not work until you actually program the unit on HOW YOU WANT IT TO START.
Jan 30, 2011 | RS60 Stand Alone Remote Car Starter System...
06 infiniti m45 wont start
You need to get codes before any recommendations can be made.
Aug 15, 2009 | 2006 Infiniti M45
Dont have book...dont know how to clean unit
The manual doesnt give much insight. Vacuum/wash(no dishwasher) the filter(remove by pushing down and away from the unit. Its right on top on the back. As alway unplug before. Wipe the outside. thats it in the manual.
Jul 07, 2009 | Amana Portable Air Conditioner
Xbox 360 wireless pc controller reciever not working??
My receiver died two days ago, i opened it up, and the Fuse was damaged, dont know how it could happen, not that much of current going thru that receiver, well the thing is all you have to do is get a solderer, and soldering iron, remove the fuse and solder a little cable so that you have a close circuit, The fuse is on the down side of the PCB (Printed Circuit Board), its named after F1
Jul 03, 2009 | Microsoft Xbox 360 Controller
Remote not working
you will need to train (link) the remote to the garage door opener. to do this you will need to find the remote "train" button on the operator.
If you have the manual for the garge door opener this will show you where it is located.
push the train button on the operator, an LED light will start blinking. Then push one of the buttons on the remote. the LED light on the operator will stay on. push the button on the remote again and the light on the operator will turn off.
try the remote it should work now.
Apr 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Blinking small red light.
I had that problem, it is the filetr reminder. I used Reverse Osmosis water so I dont use a =fileter, but the machine doesn't know that. If I recall the manual was wrong on which button to push an hold. I dont remember which was was right (could be the steam button). but one of them does make the light go out in about 5-10 sec.
Feb 20, 2008 | Saeco Easy Espresso Machine
Car Audio & Video Logo
41 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
