Question about Microsoft Xbox 360 Console
Mine 2 i can only play 007 cus it on the hard drive but i still have 2 open tray like 3 or 4 times 2 get it 2 work this is my 3rd xbox in 5 years ms are realy getting on my nerves i cant put hard drive on othere xbox cus of the drm so all my downloads are lost untill i get it fixed even dvd cleaner dont work and i dont want 2 take it apart 2 clean and void the value microsoft i hate u im gonna download some pirate software just 2 p#ss u off catch me u c#nt like £500 just 2 have xbox 4 5 years and £40 a year 4 xbox live and all my downloads with ms points u robbing b#stards and the £60 2 fix xbox 3 times 2 times free 4 red ring of death im off 2 get ps3 i had it wid xbox and if i ever c u face 2 face u better call 999 f#cking c#nts
  • 48 Answers
Wow... um... $23 and you'd get a Brand New BenQ DVD Drive for your 360. If you see M$ face to face? Whatever....hit me up if you want a legit person to fix your 360
Posted on Jun 22, 2009
GAMES GOT STUCK IN THE XBOX 360 HALO EDITION THE 3RD TIME i USED IT
It needs a new drive chassis, you will have broken the little plastic tabs that hold the tray level and straight! you can replace the drive but the new drive will need either the old logic board off the broken drive fitted to the new drive or the dvd key dumped off the old drive and flashed to the new one to make it work.
Dec 23, 2012 | Microsoft Xbox 360 Halo 3 Special Edition...
Xbox will not load keeps going back to open tray
Hi,Clear the system cache:
1. On the console, go to My Xbox, and then select System Settings.
2. Select Memory.
3. Highlight any storage device, and then press Y on your controller.
4. Select Clear System Cache. If Clear System Cache is not available, use the following controller button sequence to clear the system cache: X, X, left bumper,right bumper, X, X Note If you don't see a system maintenance prompt on the screen, try pressing the button sequence again.
Try playing discs without the hard drive in:
1. Turn off your console.
2. Locate the hard drive on your console.
Press the release button on the hard drive and lift the hard drive from the console.
Turn on your console.
3. Try to play a game disc.
If this resolves the problem, you will need to replace the hard drive.If not, do the same thing for your memory units. If it works without them, the they may be bad.
Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
Won't load games. Just says open tray. Have to open and close lots of times to get to work
2. Select Memory.
Apr 03, 2010 | Microsoft Xbox 360 Console
XBOX 360 Elite won't play disc; says "reading" then "open tray".
If the console has never been opened to change the dvd drive then eather your laser lens or one of the 2 motors in the drive needs to be changed. 90% of the time its the laser lens. You cant just use any laser for the xbox 360. There are 3 different drives. Toshiba, BenQ, Samsung, so you have to see what drive model you have before you try to order one yourself. I repair these often with 99% success.
Jan 24, 2010 | Microsoft Xbox 360 Elite Console - Black
Brand new 360 elite will not play nba live 09 ONLY
ok , if it is giving u the open tay error , every time u try and load it , it could be a number of reasons behind it , i had the same problom , most games will play but i had 1 game that no matter how many new copys of the game i got , when i put it in my xbox the game spun 3 times and then said , open tray , like trhere was no game in the xbox, so i went 2 you tube and typed in open tray error xbox 360 and there r loads of examples on how 2 fix it , if u keep opening and closing the tray each time after it says open tray after about 6 to 7 times , it should play , but i would go 2 you tube , becase u need 2 open your disc drive 2 fix the problom.
Jan 13, 2010 | Microsoft Xbox Console
When i place a disk in my Xbox 360 console it
I have had this happen about 3 times. The first time was when i figured out how to fix it. The 2nd and 3rd were temporary.(Just needed to be turned off for a moment) You need to shut the console off for atleast 15 minutes 10 at the lowest with everthing unplugged. I mean the hard drive, memory unit, and all cables, and adapters. Then after 10-15 minutes plug everything in and DON'T PRESS the BUTTONS ON THE XBOX OR THE CONTROLLERS. Press the button to open the tray and take out the game or dvd and put in a different one. If this doesn't work do it all over again and then put in a different game or dvd not the previous ones and turn on the console the same but then a soon as you get the disc in and closed in shut it off then open the tray and wait till you are at the main menu go into any program so you can't see it is reading and close the tray. If that doesn't work contact the xbox support line. Really hope this works for you.
Jun 22, 2009 | Microsoft Xbox 360 Console
When i put an xobx 360 disc in it says to open tray
Follow the steps below, Hope this helps
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Remove the hard drive, turn on your xbox 360 without the hard drive.
3. Re attach the hard drive and turn on your xbox 360
4. If the steps wont resolve the issue, your console needs to be serviced. Contact Xbox Customer Support to check the warranty status of your xbox 360.. Good Luck!
This issue occurs when there is a problem with the lens on your 360 disc tray..
Apr 05, 2009 | Microsoft Xbox 360 Console
My xbox says open tray when there is a disc in it
common xbox flaw mine does the same ,just keep opening and closeing the tray till it reads the disk,this can be very annoying .your dvd tray is probally on the way out
Feb 26, 2009 | Microsoft Xbox 360 Console
Xbox 360 doesn't read games properly
3 Simple Steps to Fixing this problem :1.Take out and disks in the tray and turn it off. 2.Lay the XBOX 360 Horizontally and give the xbox 5-10 medium bangs with your palm or fist (top Left of the XBOX). 3.Turn it on, Put in a Game ! SUCCESS ! Hope it Helps There is a vid, Hope this helped. =D
Jul 10, 2008 | Microsoft Xbox 360 Console
My xbox 360 disk draw keeps opening and wont let me play games?
My problem was the magnet that is supposed to be in the black rotator that the DVD is placed had come out and was sticking to the top of the DVD drive lid... I opened up the XBOX 360 by removing the hard drive on the top first then on the sides of the XBOS you will notice air holes but if you look closer looking from the front of the box on the right hand side you will notice there are more holes then the left and side. I will try to put everything in steps and hope you understand them
1 - Removed the hard drive from the top
2 - Starting from the back pushing a pen in the side holes on the right hand side to unclip the Gray cover
3 - Do the same on the bottom to remove that Gray cover as well.
4 - Unclip the front white face cover and remove it
5 - you will see 4 cover clips on the front holding both side of the case together "unclip them BUT don’t force apart" there is more on the back
6 - Unclip the back by pushing the pen point in all the 7 small holes in the back THEN you can pull the cases apart
7 - Remove 6 long screws from the bottom then take the othe side of, Unplug the cables from the back of the DVD drive and lift it out away from the XBOX
8 - Unscrew the 4 side screws of the DVD drive and take the top cover off.
9 - Take the magnet of the top cover from the white plastic
10 - Use some very good adhesive glue on the black rotator wheel (not to much) wait for the glue to part dry for 3 or so minutes then place the magnet in where it belongs
11 - Leave overnight to dry (don’t try and hurry the glue or you will be doing this again.
-- ** now revers all the steps from 6 till 1 to put everything back together ** --
Mine is fixed now and I hope this worked for you (I did get it working sometimes by just keep opening and closing the draw) but this fixed it for good and now all is working well again
Sep 23, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
111 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
