Question about Visonik Dual Bass Box with Amplifier Car Audio Amplifier
Amps Power and Protect LEDs Both on But No Sound
My system was working fine until one day I noticed the lack of bass and realized that my amp was stuck in protect mode but the green power led is lit as well...ive changed the amps fuse and the line fuse but neither made a difference...ive checked the ground as well and its fine...what could be the issue?
  • jayhenny Mar 07, 2009
    is that the only explanation? i just got it back from being repaired too! =[
  • 3 Answers
Its fried
Posted on Mar 07, 2009
SOURCE:
I have a Jackson bass guitar bought almost two years ago. We had a gig and I noticed that the sound is not good enough. I was thinking that it was cause maybe of electric low voltage. Until i lost the...
I would say, that it probably needs a new 9V battery. It had some time to gain some juice after the gig. If a fresh one doesn't help, then the problem could've been the equipment or power outlet distribution at the gig site.
Jul 26, 2017 | Jackson Music
Amp on but no sound
Double check all of your fuses and make sure they are the corrects AMP. Other than that it sounds like the speaker wires came loose somewhere along the line. check on the subs and behind the deck. hope this helps
Apr 22, 2013 | Pyle PLA2678 POWER SERIES BRIDGED MOSFET...
Amplifier causes subwoofer to emit super high pitched sound
YOU NEED NO CHACK THE GROUND CABLE SOMETIMES WITH THE SAME POWER THAT THE AMP NEED START TO BURN THE CABLES AND IF THE GAUGE OF THE CABLE IS NOT THE CORRECT CAUSES THAT PROBLEM TRY TO PUT 2 GROUND CABLES (GREY) IN DIFERENT PLACES AND IT MUST WORK!
Feb 10, 2010 | Sony XM-475GSX Car Audio Amplifier
Alpine amplifiers fade in and out durring high volume bass hits
main problem i think you are having is your loosing power when it kicks a note.. get a power cap! power caps feed your amps constant power! this will solve your problem :)
Jan 06, 2009 | Alpine MRP-M450 Car Audio Amplifier
Bass tone problem
Both of your problem amps were made in the '70's or earlier. It is entirely possible that the coupling capacitors are failing. This is an issue for a service center whether it is caps or something else, like failing tubes.
The good news is that installing metalized polypropelene capacitors will make those classic amps sound incredible.
Nov 04, 2008 | 3Com SuperStack II advanced RPS...
Amp went into protect, but front speakers sound distorted too
If the amp still goes into protect mode, the easiest thing to do is disconnect the RCA cables from the amp and see if still goes into protect mode (after turning off/on). If it does, the issue lies in the amp or the wiring to/from the amp (most likely case). Check to make sure no speaker wires came loose and touched +12V or ground (car body). From the sound of it, my guess is something internal to the amp died and will need repair.
Mar 22, 2008 | Car Audio & Video
No response from amp
it sounds like you have a bad ground make sure its on the froame or body and make sure any rust or paint is sanded or scraped off
Feb 09, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Bass amp for guitar?
i say it can! u would get a nice clean sound! acoustic guitar sounds nice through a bass amp!
you probably wouldnt get distortion out of bass amp though! depends on the bass amp! some bass amps have built in effects! e.g distortion
Oct 15, 2007 | 3Com SuperStack II advanced RPS...
SubWoofer
Sounds like your original and this sub have bad amps. The amp for the sub is not the same as the amp for the other speakers. The old unit has a dead amp and this new one is on the way out. (Pulling too much current on high bass)
Mar 30, 2007 | JVC TH-M505 System
Protect light
Set your Filter Switch to LPF.  Turn the Bass Gain/ level all the way down temporarily. Set your Crossover to below 100HZ.  Then Turn on the system with a Bass test sound.  Turn up your bass Gain/level until you get distortion.  Then turn it back till you just get the distortion out. Then do not warn everyone that you will De-nad them if they touch your settings.
Oct 23, 2006 | Jensen JXP680 Car Audio Amplifier
Visonik Dual Bass Box with Amplifier Car Audio Amplifier Logo
155 people viewed this question
Top Visonik Car Audio & Video Experts
Mike Duncan
Mike Duncan
Dalynn Turner
Pierre Laplante
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
