Question about Jandy Lite2 175,000 Btu Propane Gas Electronic Pool Heater
Flame sensor will not let the boiler run - Jandy Lite2 175,000 Btu Propane Gas Electronic Pool Heater
I too had intermittant problems with the flame sensor. After cleaning it worked (for a while), I also did the dielectric grease & it worked (for a while). then as I was looking at it in search of a part# I noticed the wire would slide in and out of the sensor 1/16" to 1/8" and found that if I pushed it inward it worked. So I removed it again slid the wire out that little bit applied a drop of super glue, pushed it in and held it in place for a minute. It works. I ordered the new part but when I install it this one will be hanging on a nail on the wall behind the boiler just in case.
Posted on Nov 30, 2009
I just had the same problem. The sensor is a simple device so there's not much that can go wrong with it. My solution was simple. Put some dielectric grease on the wire connection (black wire from sensor to control panel connector). This will stop further corrosion and improve the electrical connectivity. Also, I noticed my sensor wire was sitting too low over the flame probably keeping it from getting hot enough. I pushed the wire up 1/8" - 1/4" to place it higher in the flame. When I fired it up, the sensor worked fine and the burner kept running. Most electrical problems occur at the connections so make sure yours is clean and get some dielectric grease from Radio Shack. This is a 5 minute fix for anyone with fingers, over the age of 18.
* Please use common sense and set the heater to off before you do anything with the door removed. Unless you would like to remove all of the hair on your head in a fraction of a second.
Cheers.
Posted on May 31, 2009
Slant fin boiler galaxy natural gas, pump starts and runs. Igniter comes on . Pilot lights. Burner lights. Runs for seconds. Burn shuts down. Igniter starts pilot light, pilot goes out and on and on
The flame sensor, which is located in front of one of the burner flames is probably oxidized and needs cleaning or replacement. If the unit can't "sense" the flame, it will continue to cycle.
Jan 22, 2017 | Slant Fin Heating & Cooling
My furnace turns on and runs for a short time then shuts off. It will not bring the temperature to the thermos setting. I don't see a flame sensor any where?
Flame sensor is a small rod sitting on the opposite side from ignitor. It is on the "flame" side of the gas tubes and usually to the far left or right, whichever is opposite your ignitor. Held in place by one 1/4 inch screw.
Dec 17, 2016 | Heating & Cooling
Boiler won't fire the pilot is lit.
Flame sensor not picking up flame and won't release /open gas valve
Mar 16, 2016 | Hydrotherm Gas Fired Boiler Hvx-105 Power...
I have a honeywell S8600f ignition control on my Crown Boiler after ignition it will run for three to four minutes and then start to short cycle
Sounds like the flame sensor may not sending a signal back to the controller. clean the sensor with a non abrasive like scotch bright.
Jan 10, 2015 | Heating & Cooling
Sime boiler pilot light
Sounds like an old boiler. It is not on timer and has to be lit manually. Push in the gas button and hold and push the sprung ingnition button to greate spark. Continue to hold in gas button 1-2 mins and release. The pilot light should then stay on. The flame will have heated the sensor in the combustion chamber and the boiler thinks that there is a flame and will allow the main gas jets to light when demanded . If the flame does not stay on clean the sensor prongs with emery cloth but do wait until they are cooled. You have open up the combustion chamber for access
The 1-2 mins above varies
Apr 07, 2014 | Water Heaters
Boiler without flame sensor
Sounds like the hot surface igniter is also a local sensor. If you unplug the molex 2 wire plug of the igniter, and turn your meter to resistance, I found that it should read under 110 Ohms. If it is over that amount, the igniter may not sense the flame. Replace the hot surface igniter.
Dec 03, 2013 | Bryant Heating & Cooling
Boiler ignition is loud, boiler runs for a few seconds then goes out
flame sensor, air flow restriction or blower not producing enough pressure. clean the flame sensor to start. inspect venting, etc
May 13, 2013 | Jandy Lx Pool & Spa Heater - Electronic...
Noritz Boiler NH-1501-DV-NG Shuts off at radom times with blinking error code 123
error code 123 is a flame rod sensor problem. Chances are the flame rod is sending a weak signal to the control unit. Check for a loose flame rod electrical connector. Peek in the flame inspection windows to ensure there is a proper flame on that side of the burner. If non of the above then try removing the flame rod and cleaning with 400 grit sandpaper or replace it with part order # SKC7448 (called an Ignition plug ELV & Packing EHK SETV)
Dec 16, 2012 | Noritz NH150-DV-NG Indoor Direct Vent...
Hi, im having problems with my hydroline b24 boiler, it will fire up but only for a short time then it stops and a fault light come on (flame or gas failure) i dont think its the gas pressure as the burner...
Switch off the boiler at the mains, remove the front panel and 'lower' the display unit/pcb. Locate the (blue) sensor in the condensate trap (rear left hand corner of the boiler). Remove the sensor and dry the area around the probes which are on the end of the sensor which enters the trap. Restart the boiler - if it runs correctly you have a problem with your condensate overflow (as did I). Good luck.
Dec 19, 2009 | Water Heaters
My oil boiler is a Danesmoor SLPJ 20-25 with an Electro Oil Inter 2011 burner. The oil tank ran out and after refilling the burner ran ok for approximately 6 minutes, the control box chattered and the...
you could have a problem with a temperature sensor.
it would not be the flame sensor since it could not wait 6 mins to sense that there is flame in the unit.
could be a temperature sensor problem where it is sensing a temperature which could be correct but it is sending a wrong signal to the controller to turn off the flame and start another cycle.
tnx 4 using fixya,
drcool
Oct 04, 2008 | Heating & Cooling
Jandy Lite2 175,000 Btu Propane Gas Electronic Pool Heater Logo
355 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Craig Butler
Craig Butler
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
