Question about GE Dryers
When our dryer is turned on it has a very high pitched noise as if some metal is rubbing on the drum. It is model number DBXR453GVOWW.
    Sergeant:
  • 300 Answers
It's noisy If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Posted on Mar 07, 2009
Dryer makes a squeaking/high pitch rubbing noise
bad drum bearing, bad drum teflon pads or both possibly
or both possibly or in combination the belt could need replacing
& if your not sure get a service tech so you dont do more damage
Apr 06, 2014 | GE DVLR223 Dryers
Hi, I have a frigidaire front load washer, model FTF2140ESO, that is making a high pitched screeching noise when it enters into the final spin cycle. The noise ramps up in volume as the drum spins faster....
Some times screws can work their way out near the drum and rub against the drum causing the squeak. You might have to take off the back of the washer and see if there is anything loose contacting the drum.
Oct 16, 2013 | Washing Machines
Dryer was making high pitched squealing noise and now won't run
Please supply the model number so we can help further.
May 20, 2012 | Hotpoint Dryers
Why is my dryer is making a high pitch screaching noise?
frigidaire dryers have a rear bearing that the drum rides on,usually when you hear metal on metal sounds it will be the rear bearing
Feb 22, 2012 | Frigidaire FER641FS Electric Dryer
My dryer is a model number GLER341AS2 and when I turn it on it makes a sreeching noise. Now the screeching has turned into a louder noise almost like a rubbing thud.
The symptoms you describe indicate that your dryer drum bearings are faulty: there is usually a large 'felt' bearing around the opening which support the drum and prevent metal to metal contact (screeching noises)- The drum must be removed to get to this front bearing (which is normally glue to the dryer front panel at the drum opening): it is not a trivial job and is not normally replaceable by end-users.
Hope the explanation helps.
Sep 23, 2011 | Frigidaire Dryers
DRYER MODEL DE7400P FRIGIDAIRE IS MAKE NOISE LIKE RUBBING METAL HOW DO I FIX?
Hi martyski39...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your dryer drum is mounted in the rear with a bearing, most likely the bearing is faulty and making the grinding noise, or maybe two conditions exist.
1...Bad drum bearing noisy
2...Bad drum bearing noisy, and with play in the bearing allowing the drum to rub the felt seal away at the door making metal to metal contact.Check your door for obvious rub signs...
I will include a parts house webpage link where you can look at you "exploded" view of your dryer and order parts also.
Please take time to rate me
http://www.partselect.com/MultiModels.aspx?ModelNum=de7400p&searchTerm=&RefineSearch=0
Aug 30, 2011 | Frigidaire Dryers
SQUEAKY DRUM!
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Jun 07, 2010 | Fisher and Paykel DE08 Gas Dryer
Noise in dryer Frigidaire model fde336res1 when running
Could be the drum bearings are worn. These are what the dryer drum turns on and when they wear out the drum and frame rub together (metal to metal). Also could be the belt idler which keps the belt tight around the drum. In either case the dryer would have to be internally accessed to determine failure.
Feb 17, 2010 | Dryers
Dryers Logo
267 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
