Question about Maytag 21 cu.ft. Top Mount Refrigerator, MTF2172HR
Problems with Maytag 21 cu.ft. Top Mount Refrigerator, MTF2172HR
Purchased new 3 years ago and cooling appears to be functioning normaly. However a noise has recently started (2 to 3 times an hour) that sounds like the ice maker is attempting to start (i.e. buzzing for several seconds followed by an "electronic" sound similar to what I would imagine to be an overload device triping).
6 months ago the refrigerator was moved to a new house that has no water hookup (yet) for the ice maker. To this date the ice maker has been disconnected with the trip lever set in the "ice tray full" position with no problems (other than no ice :>)
The sound at the end of the buzzing is rather ominous and has us concerned about potential electrical fire.
Any ideas? (And thank you in advance).
John
  • jdleuck Mar 09, 2009
    Thank you for your detailed response. What I failed to clarify in my initial post is that the buzzing/tripping sound will occur both when the compressor is not running AND at times when it is already running. (In the latter case it doesn't seem to change the sound of the compressor/cooling cycle at all). If I put the ice maker activation arm into the "make ice" position the same buzzing/triping noise will occur repeatedly with a several minute delay in between occurances. That is why I thought the noise was the result of the ice maker attempting to operate even though the ice maker is not hooked up to a water source. For some reason (it appears) the ice maker is attempting to activate even with switch off and no water available.
    President:
  • Maytag Master
  • 2,651 Answers
Not nessecarily an electrical fire, but sounds as if the compressor is struggling to start, it is indeed "tripping off" on overload. so yo may start ot see a decline in refrigeration. check your manual for "sealed system" coverage. adn check that against our date of purchase, you should have 5 yr manufactuere warr, but that all changed Jan '06 coverage was reduced to one year! yo ucan try replacing teh overlaod relay, atached ot the side of the compressor if youd like
Posted on Mar 07, 2009
  • Ron Coons
    Ron Coons Mar 09, 2009
    ok that is quite possible as well, if youllook closesly at the ice maker, its only held in by 2 screws ontop of ice cavity, and 1 below the unit, you can simply unscrew and unplug the unit stopping the noise and adding to the usable space in your freezer, you can always reinstall when your ready for it
Refridgerator isn't cooling, but freezer is cooling more than it should
Some fridges use the same air fridge gets its cold from freezer the duct could be frozen closed a good defrost could do the trick
Jun 30, 2012 | Maytag Appliances Magic Chef 18 cu. ft....
Condensation is running down the back of the refrigerator and laying in the bottom. How do I fix?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 23, 2011 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
There is a awful smell coming from what seems to be underneath my fridge. There is a plastic tray underneath but I don't seem to be able to pull it out.
USE A FLASHLIGHT TO SEE UP IN THERE, YOU WILL NEED TO PICK UP ON THE FRONT OF THE TRAY , THESE ARE DESIGNED TO EMPTY THEM SELVES, BUT SOMETIMES WHEN THE DOOR GETS LEFT OPEN, IT IS OVERCOME WITH WATER AFTER THE AROMATIC DEFROST CYCLE, DOES IT'S THING.. A WET DRY VAC IS NICE WHEN CLEANING OUT ONE OF THESE WITH A FULL TRAY= LESS SPLASHING .. JAY
Jun 27, 2011 | Maytag 21 cu.ft. Top Mount Refrigerator,...
Ice build up in freezer
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 27, 2010 | Maytag MTB1891ARW 18 cu. ft. Top Mount...
My Maytag side by side refrigerator [mod. #MSD2656KES, Serial #50518503JL] is freezing everything on the frig side on the two top shelves. Coils have been cleaned. Temp set:Freez=3, Frig=2. One week ago...
I have this same refrigerator, also purchased in 2006. Same exact problem. Fridge freezes, starting actually in the water line, you will notice water on door does not work, then top two shelves start to freeze. Lasts for a few days, then prob does not happen again for 6 months almost to the day. I've had this problem for almost 3 years!!! My service tech said to buy another, glitch in this system he can't figure out. Replaced damper x2, control board, and thermostat x2. Not sure what else to do. I hate the thought of more food lost to spoilage!
Aug 09, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Freezer not defrosting
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 25, 2010 | Maytag 18.9 Cu. Ft. Top-Mount Refrigerator...
Frezer not freezin fridge not cooling
try to change the clickson and relay on the compressor and if it still doing that there are two problems to look for or a blokage in the system or the compressor are broken
May 13, 2009 | Maytag Appliances Magic Chef 18 cu. ft....
Stopped cooling
Hello cpuklutz
Welcome
You said, Kenmore; 21 cu ft; 10-years old; just stopped cooling; wondering if it even makes any financial sense to get estimate to repair, or is 10 years about it's trouble free length of service
Here is an article that you may find useful and interesting related to your situation.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thank You, HUUUM
Please remember to enter a rating before you sign off!
Sep 29, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My Maytag MTF2172HR* keeps blowing the fuse
You guys are gonna LOVE this one.
I called a local appliance repair man, who said it sounds like the compressor.
He went on to tell me if it was the compressor, I would have forked over $75.00 to him, and, now need a new fridge, as it's probably not worth to replace.
I was a bit angry, so, deciding what to do, I started snooping around the back of the fridge.
Everything back there looks brand new, and clean, so I was starting to think it wasn't the compressor.
I put in a new breaker in the circuit panel, and, still blew.
As I was behind the fridge, I grabbed the power cord, and felt something strange- looked down, the power cord was cut through and twisted, exposing the little wires inside, and, visibly crossing them.
So, I'm going to go to the appliance store, and see if they have a replacement power cord.
Thanks,
Sep 27, 2008 | Maytag 21 cu.ft. Top Mount Refrigerator,...
Freezer staying cold but defrosting on Kenmore Refrigerator dripping into bottom frig
I bought kenmore refigerator 21 cu.ft. year ago, but recently on top of freeze door side produces ice would you please tell me what's happen and how to prevent.
Sincerely,
Tim Kao
Jul 09, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
187 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
