Monitor not seeming to work when computer is powered up.
Computer is powered up and monitor says:'' No Input signal go to power save'' all connection have ben plugged and unplugged numerous times. computer shut down and repowered. same problem occurs.no image on screen? can you help I am thinking the monitor is done.
    Problem Solver:
  • 8 Answers
Hi there!
Try reseatting the video card and clean the video card if needed and the memory module.
Posted on Mar 07, 2009
No input signal on monitor-not connected to tv-computer works fine except for the no input signal
no input or signal means that the monitor is not receiving any signal from the CPU and if the power light is amber then and the cpu works fine then there could be a problem with the cable connecting the CPU and the monitor ...check the cable.
Mar 03, 2014 | Dell Computers & Internet
Computer monitor when powered on screen says"saving power" and shuts down?
Try to connect the monitor on other source for signal -laptop or other known working computer.if it posible.
Try with other rgb cable.Moust of monitor go tu stand by or power saving mode when is not presence of signal from computer(h-sync )
If monitor works ok on other source,than problem is in your computer(vga card probably)
Feb 08, 2014 | Computers & Internet
My desktop monitor direct go in power save mode.so please solve it as soon as possible its urgent
power save mode indicates no input signal. Check the input signal with a known good monitor. if the signal is good then dell monitor is faulty. Power cycle (unplug the power then plug it back in) the monitor to reset to factory and if it still goes directly into power save mode the unit is faulty.
May 01, 2011 | Dell E1709W Monitor
Samsung Monitor 192N light turns green when powered on then goes out after few seconds
this usually means the monitor is not getting a signal
  • i would check the hdmi/dvi/vga cable connections dirk_s.jpg
    both on the back of the pc and on the back of the monitor.
  • if the connections are tight, and plugged in well, maybe try and connect it to a second computer or laptop.
    • If it works the problem probably lies with your gfx card in your computer (verify this by trying another monitor on it)
  • If it doesn't work on those i would try and replace the aforementioned cable (usually pretty cheap)
  • if the problem still persists the monitor would probably need to be replaced as its defective.
Feb 28, 2011 | Samsung Syncmaster 192N 19" LCD Monitor
My computer is on.. but my screen wont turn on . The red light on the botton of screen is blinking and it says DIGITAL POWER SAVING MODE on the screen. how do i make my monitor work ! (:
When the monitor detects no input "signal", it goes to "sleep", to consume less power.
Check that the "data" cable is securely connected to both the monitor and the VGA-output on the back of your computer.
Or, try connecting the monitor to a different computer, to see if the monitor works at all.
Or, try connecting a different monitor to your computer, to see if your computer's video-card is working correctly.
Oct 24, 2010 | LG Computers & Internet
Computer is powered up and monitor says:'' No Input signal go to power save'' all connection have ben plugged and unplugged numerous times. computer shut down and repowered. same problem occurs.no image on...
You could be righ. Before we confirm that have you tried plugging in another monitor. See if that works. If its does then we will know its your monitor, if not then it could be your graphics card on the machine.
Apr 12, 2010 | Computers & Internet
My Dell monitor is stuck in Power Save Mode. Any
The monitor is not receiving signal from the computer. Verify the computer is on and the monitor input is set to the correct mode or auto. Try another monitor if possible.
Aug 10, 2009 | Computers & Internet
Entering power save
The reason why your secondary monitor is showing no input from computer is because of the display resolution of your graphics card, which is higher than what the Monitor can handle.
What you can try is, when your system is powered up, just go to your display settings, then reduce the systems display resolution to--preferably 800x600, then go to where you normally select the output, and select 'Output to external monitor"...this should send the signal input to the monitor.
I have actually dealt with a no input signal before, and this was what I did.
Hope this helps.
Jul 14, 2009 | HP ATI FireGL V3350, PCI Express Graphic...
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
The screen will not come up but gave this message 'No input signal, go to power save
To isolate the problem, you need a friend with another computer since right now, we don't really know if the video section (or card) of the PC is at fault or the monitor.
You need to swap displays with someone so you can be certain what is actually not working.
The monitor is obviously capable of scanning inputs for a signal and not finding one.
Oct 26, 2008 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
Computers & Internet Logo
327 people viewed this question
David Payne
David Payne
