Question about GE WSXH208A Front Load Washer
Detergent will not dispense
I have tried to use powder detergent, and I noticed that it doesnt dispense like the liquid. Is there another section to put the powder? I am not really familiar with this washer, it came in the house I bought.
  • 360 Answers
Generaly the detergent tray has a "gate" that needs to be moved to the top position for powder. (up for powder, down for liquid). This is the generic answer. if you verify the model number or list the model of your unit I will attempt to locate a users guide for you.
Please take the time to give this solution a fix ya rating
clarkco
Posted on Mar 07, 2009
  • 158 Answers
Hello, you should just add the powder before you start the washer. The powder was not intended to be dispensed like the liquid detergent. Please rate my answer, Thank you.
Fabric Softener Does Not Drain
compartment 1: Detergent for pre-wash
(powder)
Before pouring in the detergent, make sure that extra compartment 4 has been removed.
compartment 2: Detergent for the wash cycle
(powder or liquid)
Liquid detergent should only be poured in immediately prior to the wash cycle start.
compartment 3: Additives (fabric softeners, etc.)
The fabric softener should not overflow from the grid.
extra compartment 4: Bleach
! Do not use Hand Wash Detergent because it may form too much foam.
Cleaning the detergent dispenser
Remove the dispenser by raising it and pulling it out (see figure).
Wash it under running water; this operation should be repeated
frequently.
25569074-ineink0kisfnom0atbkujjcx-3-1.jpg 25569074-ineink0kisfnom0atbkujjcx-3-3.jpg 25569074-ineink0kisfnom0atbkujjcx-3-6.jpg
Dado
Mar 14, 2015 | Ariston Technologies AW125NA 13 lbs. Load...
Gltf1670as1can you use powder detergent in ?
Good Morning Friend,
I understand that you want to know if you can use powder detergent in your Frigidaire washer, model# GLTF1670AS1. Below are the advised steps for the detergent dispenser of your washer.
• Add measured detergent to the detergent compartment of the dispenser drawer.
• Detergent is flushed from the dispenser at the beginning of the cycle. Either powdered or liquid detergent can be used. Note: Liquid detergent will drain into the washer drum as it is added.
• Low sudsing detergent is recommended for this washer. Use the manufacturer's recommended amount.
• If low sudsing detergent is not available, a reduced amount of regular detergent may be used. Because
reducing the amount of detergent may reduce cleaning, it is important to pretreat stains, sort carefully by color and soil level, and avoid overloading.
• Detergent usage may need to be adjusted for water temperature, water hardness, size and soil level of the load.
• For best results, avoid oversudsing.
Hope this is helpful.
-Best Regards-
WP
Jun 05, 2014 | Frigidaire Washing Machines
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Is powder or liqued detergent better for front
They are trying to make money off you!!!!!!! LIQUID!!!! Dont ever!!! use powder soap in your front loader. Powder soap doesnt dissolve all the way and then gets into the bearings of the washer and eats them away! This caused about a 450 dollar repair for your repairman. Never use powder soap.
Feb 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Duet dispenser problem
this is joyce
You need to call who ever you bought it from and tell them the problem that you are having, I have the same set and I am not having that problem at all. I love my set, just be sure to use the he detergent, or you will have problems that the manufactr will not help with.
thanks,
Dont overload machine the clothes wont smell clean.
joyce
Feb 06, 2009 | Whirlpool Washing Machines
Creda Washing Machine Detergent Dispenser not emptying
does the detergent get wet?
may be the blue trap door that is behind the detergent in the drawer is set for liquid detergent ie 'closed' and needs to be set to open to allow the powder past. or the holes above the detergent section where the waster comes out are blocked so water goes in another route.
you could always put the powder straight in with the wash to get yourself out of trouble.
Feb 03, 2009 | Washing Machines
How to add liquid detergent and powder booster at the same time?
any booster would go in the detergent dispenser,should not be a problem if you are doing warm washes.if you do alot of cold washes,check for build up and clean from time to time.
Sep 28, 2008 | Frigidaire Affinity ATF7000E Front Load...
SOAP DISPENSING
The soap dispenser is intended for both liquid and powder detergents. If you have a problem with mildew, then you may need to clean it occasionally with bleach water.
Aug 07, 2008 | Hotpoint WMA50 Front Load Washer
Can I use color safe bleach in my new cabrio, and if so where do I put it?
According to the manual on pages 12 & 13.
1.
Place a load of sorted clothes into the washer. See “Laundry
Tips.”
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
water.
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
cycle.
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
Please rate this solution
Aug 03, 2008 | Whirlpool Washing Machines
GE WSXH208A Front Load Washer Logo
418 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
