Question about RIM BlackBerry 8700g Cellular Phone
BLACKBERRY 8700 HOURGLASS HELP
BLACKBERRY 8700 HOURGLASS I'VE REBOOTED THE PHONE BY REMOVING THE BATTERY AND NOTHING THIS HAPPEN THIS MORNING
  • Anonymous Mar 15, 2009
    what is the alternative button for sending a text message if wheel doesn't work
  • 407 Answers
If your hourglass of death is occuring after a hard reset - Battery pull. It suggests a software issue.
You will need to reload your software, using desktop manager.
Posted on Jun 03, 2009
It will not turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 18, 2012 | RIM BlackBerry Curve 8520 Smartphone
App error 523 on blackberry curve i cant fix
Hello
App Error 523 usually happens after loading incompatible 3rd party software. Did you load anything lately? You should be able to connect to the device while it's rebooting (spinning hourglass) with application loader and remove the offending 3rd party application.
Good Luck, and do rate the solution if got help
Dec 11, 2010 | RIM BlackBerry Curve 8520 Smartphone
Blackberry curve 8310 fatal error during backup
I would connect the device to a PC and update the OS using Desktop Manager. If you recently installed any application, I would uninstall it as this may cause this type of behavior.
Jul 21, 2009 | RIM BlackBerry Curve 8310 Smartphone
Seeing the rotating hourglass of death frequently. Often have to remove the battery and reboot. Ideas?
reload handheld software might fix it...you can download from blackberry.com and follow the instructions there to install it on the phone. that doesn't work, it may need to be replaced.
Jul 13, 2009 | Sprint BlackBerry 8703e Phone
My Blackberry Curve is basically dead. First I tried unsuccessfully to answer a cal using the answer button. I then realized my phone was frozen...I couldn't even turn it off. I removed the battery and...
Best and easiest way is to just re-flash the phone with the latest software. However this will cause all your data to be wiped clean from the phone. If you can not afford to loose your data, then connect it to Blackberry desktop with a usb cable and play around with the phone to see if you get luck and it connect to your computer. If so then make a backup before reflashing the phone
Apr 26, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
The hourglass on my blackberry pearl stays on..phone won't boot
I would download the latest Blackberry OS from Blackberry.com and install it via the Desktop Manager. You can get the latest OS from this URL:
https://www.blackberry.com/Downloads/entry.do?code=577BCC914F9E55D5E4E4F82F9F00E7D4
You can find the model by removing the battery and it should be on a sticker.
Mar 15, 2009 | RIM BlackBerry Pearl 8100
My blackberry 8700 will not come on completely. first - white screen comes up, following with the hourglass., then black screen comes up and LED ligt flashes red and then shuts off and then...
Hi Sam,
It is normal for Blackberry to load all its applications which takes few mins. However in your case the BB shuts off. I would suggest downloading the latest Device Firmware from www.Blackberry.com, and update your device with that firmware to your Device using the Desktop manager on your PC.
If not firmware then, check your device battery..
I hope this helps,
Thanks.
Jan 31, 2009 | RIM BlackBerry 8700c Cellular Phone
My blackberry pearl keeps showing a hourglass
Try removing your Facebook app from the phone. Had the same issue and I stopped receiving emails. Once I removed the Facebook app from the phone - it rebooted and all my emails showed up.
Jan 31, 2009 | RIM BlackBerry Pearl 8100
Blackberry 8100 screen wont work
check your display! i think display is problem in your mobile! IC fault in display!
Jul 10, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry 8700g Cellular Phone Logo
592 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
