I am preparing to use a Western Digital WD800JB-00JJC0 hard drive for the first time. I will be using the unit as an external drive back up after loading acronis software on my PC. I see on the unit sticker a digram showing "Standard Settings" 'slave'; 'master w/ slave present'; and 'single or master'. Q. Are these diagrams alternative representaions of the J8 jumper settings, which currently has a jumper across pin #1 and pin #2 of the J8 jumper? Q. Do I need to remove or change the current jumper on pins #1 and #2? Thanks for your help. Bob
  • bobbru Mar 07, 2009
    Does your answer mean that I should leave the existing jumper in place across pins #1 and #2?
  • bobbru Mar 09, 2009
    I decided to use the HD as a replacement for the old HD instead of an external back up drive. I cloned the current HD to the new HD after removing the jumper on pins #1 and #2. I used Acronis software to do the cloning. I reinstalled the jumper on pins #1 and #2 before installing the HD back into my Dell 8200 booted back up and is working fine.
    Bob
  • 191 Answers
Please see picture show what you need to setting, is there helpful?
Posted on Mar 07, 2009
  • 679 Answers
I just picked one of those up a 1 Terabite Elements . It was plug and play, just used a usb cable on it, and it shows up in "my computer" as a drive H. Yours should be similar. I used "snapshot" similar to acronis. You should be good to go. try a backup to the new drive. You should see it as soon as you plug it in. If you want to be super careful, shut down and plug it in then reboot. You shouldn't need to mess with anything. It's similar to the way a flash drive shows up, it should just appear in with your other drives. Just try it the way it came first It should be fine.
  • George Bill
    George Bill Mar 07, 2009
    yes, just the way it came
    Genius:
  • 2,120 Answers
WD hard drives come MASTER as the default. The horizontal jumper across pins 1 & 2 is just a way to store an extra jumper in case you need it. There is no connection beween pins 1 & 2
  • 19,396 Answers
If you are installing the drive inside a pc , then check the other disk setting , set primary hard drive to maste and the new one to slave.
  • Ginko
    Ginko Mar 07, 2009
    See the picture below, if you mount the two drives on a single cable, with flat IDE/PATA cable, then set the disk with the system to dual master, and the new disk dual slave.
    See below:
    If instead you are using SATA cable , then you do not need to set jumpers.
  • 583 Answers
Yes try first with the exact jumper setting that will only suppport.
I HAD Western Digital My Book Essential 1TB External USB 2.0 Hard Drive ON M PC AND I CONECT WESTERN DIGITAL MY PASSPORT AND RUN THE AUTO FROM THIS SOMETHING LIKE WD SMART.... AND NOW MY Western Digital My...
Your WD HDD have been attacted by viruses for your computer or outside computer where you used it last. Make sure that you have an up to date antivirus software, scan your computer or the external hard drive, explore your computer, go to tools - folder options under view files & folders select show hidden files and folders apply and ok it.
May 18, 2011 | Western Digital My Book Essential 1TB...
Unit downloaded fine ad the did the back up of the drive fine.started the updates and the firmware stopped and then the drive locked up how to access the drive again after reboot nothing shows G: F:
  1. To restore the Western Digital icon to the drive letter for the external drive in "My Computer".
  2. Please go to the Western Digital Download Library and download the WD Logo Icon which has a file name of External Icon.zip when you download it.
  3. Save the file to your desktop and use a file compression software like Winzip to extract the files inside the .zip file to your desktop. When it's unzipped, it will create a folder named "ExternalIcon" on your desktop.
  4. Double-click on the ExternalIcon folder. It will open a Windows Explorer showing a folder named, Autorun, and a file named, Autorun.inf.Double-click on My Computer and it will open.
  5. Double-click on the driver letter that represents the Western Digital drive you want the icon on and it will open.
  6. Highlight the Autorun folder and the Autorun.inf file. Right-click on them, and left-click on Cut when the Menu appears.
  7. Right-click in the open space of the drive that you opened in the new Explorer window, and then left-click on Paste.
  8. Close both Explorer windows, safely remove the external hard drive by using the Safely Remove icon in the system tray, shut down the computer, and unplug the external drive from the computer.
  9. After you reboot into Windows, reconnect the external drive to the computer again, and the Western Digital Icon should now be displayed with the drive letter in My Computer.
If these steps do not correct the problem, you will need to re-format your External Hard Drive ***WARNING*** FORMATTING A HARD DRIVE WILL ERASE, YOU WILL LOSE, ALL DATA
Mar 18, 2011 | Western Digital My Book Essential 500GB...
Western Digital WD800JB internal hard drive. I install it, it is listed in device manager, but not on "My Computer". I have unistalled the device and drivers (IDE primary & secondary),...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
Dec 11, 2010 | Western Digital Caviar SE WD800JB 80 GB...
How do I back up my laptop I have installed the western digital external hard drive but do not know where to find the infor to back up my laptop
If the external drive does not have it's own backup software you can use windows backup by clicking START-ACCESSORIES-SYSTEM TOOLS-BACKUP.
Regards
Aug 24, 2010 | Western Digital Elements powered by WD 320...
Western Digital 1 TB External Hard Drive and BSOD
perhaps the new hard drive is bad western digital software is junk take it back and get seagate external w/freeagent on it
Dec 31, 2009 | Western Digital My Book Essential Edition...
Western digital passport i/o device error
90% of the time this is a power problem. The USB port on the computer can not supply enough watts. Use an external USB hub that has a 5V power supply.
Oct 14, 2009 | Western Digital 250GB MyBook External USB...
Disk Read Error, nothing fixes it. Even when putting it into known working pc it fails.
sounds like a bad read head.. inside the hard disk.. you are better off to replace the product.
Jan 09, 2009 | Western Digital Caviar WD800JB Special...
Broken Western Digital Elements 320gb external hard drive
hello,
there is nothing to do. you should brought new one. there is no other way.
thanks
ramesh
Nov 14, 2008 | Western Digital Elements powered by WD 320...
External Hard drives
I will recommend you to use Western Digital I my self alos using a western Digital and its very reliable to use , So I will go for buying that one and it will be a big help for you...
Hope that helps.......
Aug 18, 2008 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
