Question about PNY Technologies GeForce 6200 128MB AGP Graphic Card
PNY 7130 630i VGA port doesn't work
I bought barebone system that came with PNY motherboard. I put up the system and powered-up but not VGA output. PNY documentation is very vague. Does this motherboard require video card ?
  • 408 Answers
If it has a vga connector on the motherboard, it does not need a secondary video card.  If the vga doesn't work and you have no display at all, not even on boot up, then you have a bad motherboard.
Posted on Mar 07, 2009
I need to replace my nVidia GeForce FX 5700-VTD256 graphics card
get a different monitor that can handle it or get a better motherboard ram etc
May 08, 2015 | PNY Computers & Internet
I am having a Problem with my video card not letting me run an addition monitor off the vga output on the motherboard. I know it works because I can go to the bios and change it and it works but they want...
When using a PCI or PCI-E graphics card, it will disable your standard VGA output port because the up-dated graphics card and your factory VGA port require different display drivers. Usually, the drivers are conflicting and will make your system unstable and cause it to crash. In short, you can't use both at the same time. I have a Radeon HD 5450 graphics card installed on my PC and it too has disabled my standard VGA port. If you are trying to use more than one monitor, you have to install a graphics card that supports a multiple display output. The graphics card will either have 2 VGA ports, 2 DVI-D ports or 2 HDMI ports or even any combination of the 3. My card, for example, has 1 VGA, 1 DVI-D & 1 HDMI. I can run up to 3 monitors at a time via my graphics card, but I cannot run a 4th monitor from my factory VGA port. My graphics card uses ATI/AMD drivers while my VGA port requires the use of Nvidia drivers.
I hope that you find this useful.
Mar 26, 2015 | Lenovo ThinkCentre Computers & Internet
Vga onboard
you may have encountered a VGA cable not properly installed to the VGA ports....try to reconnect the VGA cable,properly installed from the VGA port of the LCD to the onboard VGA port of the motherboard and restart computer... less pressure applied to each and every end of VGA connectors to VGA ports may sometimes affect the display of the screen causing to red, pink blue screen output....hope this help...
Dec 30, 2013 | Intel DH55HC Motherboard
On board hdmi will not recognize my monitor
You may need to update your bios while plugged into a vga monitor http://www.intel.com/support/motherboards/desktop/sb/CS-022312.htm <info there IF that doesn't help let me know, Respond with the tv/monitor information and bios version.
Dec 03, 2011 | Gigabyte Z68MAD2HB3 Intel Z68 LGA1155 MB...
Video worked fine till the power black out last week. The machine was off when the power came back on. I tried a different monitor that I know works, I re-seated the ram, and bought a new video card but...
hello
You should try first the onboard VGA output of your motherboard to be sure if the Video Card is damaged. And to be sure f your motherboard is working. Keep on touch
Aug 28, 2011 | Computers & Internet
Hi I recently bought a Biostar A880G+ motherboard which supports VGA, HDMI and DVI video outputs. I cannot get a second monitor to run on this board. The only output wich seems active is the VGA?
The manual says
  • NOTE: The HDMI and DVI-D ports both can provide digital video signals output function, but these two interfaces cannot work at the same time. The chipset uses the same channel to control HDMI and DVI-D, so these ports cannot transmit video signal to different display panels simultaneously.
so you should be able to use one of them as well as the VGA. Maybe you need to change something in the BIOS settings? I don't have this motherboard myself, just found the manual online at
http://www.biostar.com.tw/upload/Manual/A88PC-M3S%20&%20A88GC-M3S_100519_B.zip
Apr 20, 2011 | Biostar A880G+ AMD 880G Socket AM3 mATX...
VGA Port not giving output
Go into the Bios of your desktop's motherboard. Go to video settings and make sure that video is enabled.
Aug 21, 2008 | Intel Motherboard
Nvidia GeForce 7200 GS PCIE - Multi-Display does not work
This card does not allow you to Multi-Display with the VGA port and the S-video port. If you put a DVI to VGA port adaptor (not supplied) on the DVI port, you can Mulit-Display two VGA monitors and (presumably) a VGA (from the DVI port) and S-video monitor.
This is not explained anywhere and the card does not come with a DVI to VGA port adaptor, so I wa only able to work this out after I bought the DVI to VGA port adaptor.
May 21, 2008 | Nvidia GeForce 7200 Graphic Card
Vga problem
There is a problem with your VGA internaly, try to buy a VGA card to replace it. And your mouse not might work beacuse of your BIOS
(Basic Input Output System).
Mar 07, 2008 | Asrock K7S41GX Motherboard
Computers & Internet Logo
110 people viewed this question
Top PNY Computers & Internet Experts
Brian Sullivan
Brian Sullivan
laikexpert
laikexpert
David
David
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
