Question about Kenmore Dishwashers
Trying to take apart a Kenmore Ultra Wash 665
I've taken off the spray arm and cap (held in with 8 screws) and find a black plastic disk with a 1 inch ''nut shape'' held in by a metal screw. The disk rotates with the screw. Can anyone tell me if it's a 'righty-tighty' or vice-versa. sometimes spinning parts are done backward to keep the screw tight. Is there any other info I need to know about this dis-assembly?
I'm trying to take it apart to clean the debris from the pump and grinder.
    President:
  • Kenmore Master
  • 2,651 Answers
Normal threading on the screw, trick is totry to hold the impellar, while trying to loosenthe bolt, sometine placing a screwdriver in form the side, allows you to hold it
Posted on Mar 07, 2009
Thanks for the info. I bought a 15/16 crowfoot hex head for my wrench. Had to pound it onto the plastic nut, but that gave me the ability to hold the impeller without damaging it.
Kenmore ultra wash III portable dishwasher. Model #1765991. Lower wash arm came off. How do I re-attach?
Hello. The lower spray arm screws down onto the center, round, plastic part (spinner) that has threads on the center portion. It's very loose and spins easily because it uses the water spray to drive it. At the top of the threads, there will be a flat piece of plastic. Set the spray arm down onto the threads. Hold the flat plastic area that sticks out above the arm with pliers. Spin the spray arm counter-clockwise while holding the spinner. It will thread itself down about a turn or so. Snug firmly--DON'T OVER-TIGHTEN the spray arm onto the spinner. Remember, it only uses water pressure to spin so it doesn't have to be "gorilla tight"! I hope this helps you!
Oct 14, 2015 | Kenmore Dishwashers
How to remove the bottom spray arm on my kenmore ultra dishwasher?
Grab the squarish plastic piece just below the wash arm and turn it counter-clockwise 1/8 of a turn, and it should come right off.
Jul 05, 2014 | Kenmore Dishwashers
Kenmore model 665
Power off, check for clogs and if water supply to arm ok. Remove any build ups and reconnect. Good Luck.
Jul 23, 2013 | Dishwashers
How do you remove the lower spray arm on a Kenmore Ultra Wash (665.17019.402)? I was told to hold on to the plastic screw and spin the arm counterclockwise to remove, but I've been spinning and...
Hi, In the center of the spray arm is a threaded piece of plastic/bolt.
Use pliers and turn that tab on the bolt. If it doesn't turn easy. Holt the bolt and try to turn the spray arm with you hand.
It will release the spray arm so you can remove it.
Please let me know if I can assist you further.
Vic
Jul 03, 2009 | Dishwashers
How do i remove cover on food chopper? kenmore 665 the problem is top shelf dishes not getting clean. looking to clean out bottom area,thanks
Hold the lower spray arm hub (plastic bolt spray arm connects to) and turn the lower spray arm counter clockwise to remove it.
Using a torx bit, remove the 4 screws and the top cover. Remove the screws for the lower cover and the chopper cover. Insert a flat screwdriver it into the clip of the chopper cover to pull it up easier.
Unless there are alot of "foreign objects" in that area, be prepared to replace the chopper, the motor and/or sump assembly.
Feb 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
I have a kenmore 665 dishwasher where the spary arms do not spin.
  • First, check water level. Start machine, wait until the machine begins main wash. Open the door, the water level should be just below the heater element. If too low replace inlet valve.
  • If you can't hear the wash motor running or is just humming, the motor may be bad.
  • To check if the food chopper is blocked or broken;
  1. Remove lower spray arm by holding the arm and rotating the spray arm retainer.
  2. In the back of the tub, unclip or remove the screw from the upper spray arm supply tube.
  3. Rotate the lower spray arm support to the right while disconnecting the supply tube from it.
  4. Remove the four torx screws from the sump cover, remove assembly.
  5. There may be a primary filter in the left side of the sump, if so, remove the torx screw and the filter.
  6. On the right side there is the chopper assembly cover. Remove the torx screw and cover to expose the chopper.
Hope everything goes well for you,
Regards
Richard
Feb 02, 2009 | Dishwashers
Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Jan 17, 2009 | Dishwashers
Cleaning out debri in pump
if youve acess below the filter screen ther is only 2 more screws holding down 2 more covers giving you acess to the chopper assy, this is where youll find broken glass and stuff hitting against hte chopper try to break up.. the first of 2 covers lifts right off,,, the second will require sorta prying up and off, beyond this no real acess to any more
Apr 03, 2008 | Kenmore 24 in. 17032 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher Model 15882
It most likely belongs in the center of the dishwasher’s ceiling and is usually held in by a plastic pin. It is used to spray water on the dishes in the upper rack. I would need your full model number (including the part that comes before 15882, like 665. or 110. for example) to know the part number for that pin, since it is probably broken. Hope this helps!
Mar 08, 2008 | Dishwashers
Kenmore Ultra Wash 3 Leaking
Got a possible solution from a brilliant guy named Jake on another website and thought I would post it back here.
"Check the door vent on the inner side of the door, that should just snap out, I have seen those clog and start making more pressure inside to make it leak from the bottom. Jake"
I checked mine and got a nasty surprise. Who knew it could get so dirty.
Nov 01, 2007 | Kenmore 15129 Built-in Dishwasher
Dishwashers Logo
1,177 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
