Question about Maytag Neptune MDG5500AW Gas Dryer
Maytag MDG5500 - heat goes off after several minutes
Heat goes on within a few seconds of starting the dryer, but then goes off and doesn't seem to go back on. Dryer keeps tumbling, but clothes don't dry due to no heat. I already cleaned the vent and replaced the cycling thermostat, hi limit thermostat, thermal fuse on blower housing, and temp control thermistor. None of that worked? What else could it be? Thank you.
  • 1 more comment
  • Anonymous Apr 13, 2009
    this dryer takes hours to dry a load of laundry
  • gjacono Apr 25, 2009
    I have the same problem except with a Whirlpool gas dryer
    are not dry.
  • johnnyphuho May 09, 2009
    I have the same problem here. Google around and see some suggestion said that I should change the board. The board will cost around $175 and make me think, and it doen't make sense to me. Finally I stopped by the local appliance part supplier and the salewoman told me it 99.9% the problem with the gas valve coil. I check the coil and found out one of those is openned. Bought the set for $31 and it work like a charm for me.
    Sergeant:
  • 300 Answers
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Posted on Mar 07, 2009
My Maytag gas dryer won't heat
Hello Todd,
Their are several things that could cause the dryer to not heat, i have posted a tip i wrote what to check whena gas dryer doesn't heat
http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Nov 12, 2011 | Maytag Dryers
My maytag mdg5500 dryer isnt heating up. It all works but no heat.
Thier are several things that could cause a gas dryer to not heat, i have written a tip covering the most common ones http://www1.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Oct 11, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Gas Dryer. Heating element works. Flame ingnites but goes out after several seconds
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Mar 21, 2011 | Maytag Dryers
I have a Maytag Neptune gas dryer (MDG5500). The dryer overall seems to be working fine, but there is NO heat (Just a very recent problem). I have removed the front access panel but I am unsure exactly...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 06, 2010 | Dryers
When my mdg 6000bww is turn on heating element glows, flame ignites, then flames goes off within 5 minutes. After waiting approximately 15 to 20 minutes, until it seems to cool down can restart and goes...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag dryer lites then goes back out after a few seconds. It will lite again then goes out again. Model MDG7600AWW
heatman101
Aug 21, 2010 | Maytag MDG7600AW Gas Dryer
Maytag Gas Dryer, heats for a few minutes, then flame goes out
Service Manual for Dryer similar to yours will cover disassembly and troubleshooting:
MDG5500
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The number for the coil kit, which will replace ALL the coils, for your machine is 12001349
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires, explosion or death by asphyxiation.
Sep 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag atlantis gas dry is not heating up its about 6 years old
heatman101
Mar 28, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer heat shuts off after a few minutes.
replace the 2 black solenoids on the gas valve ..after heat up they sometimes will go bad and burner will not reignite even though the ignitor glows
Sep 23, 2008 | Dryers
Maytag Neptune MDG5500AW Gas Dryer Logo
1,242 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
