Question about Acer Aspire 5500 5570-2609 Laptop
System not working properly - Acer Aspire 5500 5570-2609 Laptop
  • TinaTech May 11, 2010
    What is not working correctly? Please be specific.
Thank you for your supported.actually the problem has been corrected by my own last 3 or 4 days before where i solved it the problem by installation back system recovery the day before my laptop was affected to that problem.
Any way, i wish to thank you once again about your initial respond to resolved my problem.
Thank You.
Regards;
Asrul Halim.
Posted on Mar 10, 2009
Where do I put a.c. refrigerant in a 1996 mercury mystique 16 valve zetec 4 cylinder?
If you are doing a do it yourself recharge at home, chances are the system will not work properly. The system needs to be properly evacuated/vacuumed and then recharged for proper operation. Just filling it will not make the system operate properly. Have it done proffessionaly if you want it to work
Mar 01, 2016 | Mercury Cars & Trucks
Not working properly i want to download again
If your operating system is not working properly, try using the disc that came with it to revert back to factory settings. If you no longer have a disc, I would suggest going out to wal-mart or an equivalent store and buy a copy of the operating system.
Jul 21, 2011 | Computers & Internet
I have installed windows 7in my system but it's not work properly and in my system i'hvp5g-mx mother board
if windows 7 is not working properly, try to perform a clean install of it again then check it will have the same problem.
if the issue still reoccuring give me atlist any error message so that i could further troubleshoot for you.
Jul 03, 2011 | Computers & Internet
Recently tried to open Google but I keep getting this message - driver Components mis-match. Exit is the only option. It was working fine a couple of days ago??
try to do a system restore going back to the time when its working properly,click on start> then on the search bar type system restore,then you will see there different restore point,choose the time when its working properly
Jun 28, 2010 | Computers & Internet
Speed indicater not working,heads up display ok,trip odometer ok, all other systems work properly
All systems working, Started car this morning and speedometer worked
properly,
Thanks
Jerry
Oct 26, 2009 | 2005 Buick Rendezvous
I need to re charge my air conditioner in my 2003 Yukon XL. How do I do this?
well first question is
1. does it have a leak in the system?
2. was the system open for any leanth of time?
3. did the compressor lock up causing the system to fail?
4. if the compressor did fail, then the system will require a rebuild....compoints replaced and flushing of the no replaced parts.
if you answered no to thies questions then
if the system is empty....
1. to properly charge a system it need to have a vacum drawn on it to 30lb for min of 15 mins.
2. then there ststem ( depending on the last service it receved or miles on the system) i might require sever ounces of pag oil
3. once these requirements are met, the proper amount of 134a need to be charged to the system.
this is done thru a scale or other mesurement device....just adding cans of 134 will not work properly ( back in the age of R12 a system could be severl ounces off and still work properly, 134 require an almost exact amount to work )
4. once the system is charged,,,cycle the a/c on and off severl times to flow the pag oil into the system.
this should do the trick. but it require specility tools.
if the system is low ( only from a leak in the system some where)
you MIGHT try the auto parts answer to a/c charging and place a do it your self charge up kit to it....
1.it will have a guge and proper attachments....
2.follow the directions and hope for the best...... but again.,...this might buy you a little time....
3. a problem still is with the system and will run low again causing it to shut down due to lack of proper presures.......
with people hunting to fix what they have try a local reputable A/C / Radatior shop with the proper equipement....but ask for prices and if there are any deals to be had....a smart shoper is always better then a poor consumer...... i hope i helped...good luck :)
Jun 25, 2009 | 2001 GMC Yukon XL
The calendar and weather gadgets don't work properly
Try to restore your system to an earlier restore point, and if it wont work try re installing your operating system.
Apr 23, 2009 | Microsoft Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
