Question about Dell OptiPlex GX280 PC Desktop
I think my HD went out, so I bought a new one, gx280 compatible
When I plugged in the new HD, its a Western 250 SATA, and turned it on, ... with the OS Disk from DELL in the machine, when it gets to the part where I am supposed to install Windows Xp.. it says Setup did not find any hard disk drives installed in this computer. ????
  • 2 more comments
  • Jackie Mar 07, 2009
    How do I get to that area, to set the SATA Operations to RAID/AUTODETECT in bios. How to I get there?
    Ok, I went back and went into the f2 section, and turned one of the HD choices to ON, and so far its trying to load a fresh copy of windows, keep your fingers crossed Thanks! , so I should have clicked Helpful and FixYa when I am done, again, TY sorose4u and gymowner for your quick responses and help!
  • Stephen Scheneman
    Stephen Scheneman May 11, 2010
    Hmmm...good question! I have two GX280s, and neither of them have an integrated RAID controller...Press F2 (not F10) on power up to get to bios setup screen...From there you can select SATA Hard Drive, or there is a Hard Drive Diagnostic option...explore these options and post the outcome and information gathered.
  • Stephen Scheneman
    Interesting...when you boot the PC, go into the bios setup, and see if the drive is reported there. (Go into setup by pressing F10, I think, immediately after powering on the machine.)
  • 217 Answers
Set the SATA OPERATIONS to RAID/AUTODETECT in bios...and then do the reinstallation
you may have to even install the raid drivers which is available on the dell resource cd...when u start setup at one point it gives you an option to press F6 to install third party drivers opt for it and install the raid drivers using resource cd if the first option doesn't help
Posted on Mar 07, 2009
  • Saroj Sharma
    Saroj Sharma Mar 07, 2009
    The first option ()SATA OPERATIONS SETTING applies to other computers shipped at that time.
    The XP disk that you have is an earlier version (earlier than sp2) of windows which does not not have the AHCI drivers required under the default setting of the SATA controller...
    please follow this.(This problem will ot come up if the operating system would be windows xp sp2)
    http://support.dell.com/support/topics/g...
  • 679 Answers
Check the settings on the back of the Drrive, just make sure you have both the sata cable and power plugged in. And you may need to change the jumper and the bios setting to master/slave depending on how you have it hooked up. Make sure the sata drive is on it's own line if possible, and it should populate in the bios. If it's not populating in the bios, then something isn't right. More than likelly its the master/slave thing. Also clear the cmos, just take out the battery for a few minutes to clear the old settings. Try it again and you should see the new drive. You need to set it to boot from cd/dvd, then it is pretty simple, do a quick format, and partition the new drive, once you get that done it should just start the install of the OS
What replacement soiled state hard drive for WD1200BEVS-22LATO
Examine the interface specifications for the what the HD is connected to. Most 120 MD SSD's are backwards compatible with SATA-150. Usually the specification with say SATA-II (3MB transfer speed) or SATA-III (6MB transfer speed). A SATA-III SSD will work on a SATA-II connecction.
Jul 08, 2014 | Western Digital WD1200BEVS-22LATO Scorpio...
WD2500BPVT Western Digital 250 GB Scorpio Blue is not recognized in pc. Tried 2 different computers already. I want to be able to get the data from it.
Sounds like the drive has croaked. You can get the data but expect to spend upwards of $1000 or more to a data recovery company.
Jun 06, 2012 | Western Digital 250 GB Scorpio Blue SATA...
I bought a new Western Digital Caviar Blue 1TB SATA 3.5" Desktop Hard Drive 6Gb/s It dosent work for me, I can see it in the CMOS Setup under Sata 1. My MSI K9N8PGM2 motherboard only support...
you need hard drive formatter this is in disk manager, windows 7 press windows key and then X go to disc manager, in the menu you will find your hard drive and make sure its the right one. and click on format drive, on the folder of the drive.
Jul 08, 2017 | Western Digital Caviar Blue 1TB SATA 3.5"...
SATA Hard Drive Type The Dell Optiplex GX280 Takes?
It makes no difference providing the computer motherboards support SATA interface.
SATA 1 and 2 drivers are in the BIOS. If all the computers have SATA 1 you can upgrade the BIOS to latest version via Dell's support website.
Regards.
Jul 08, 2010 | Dell OptiPlex GX280 PC Desktop
Found my old HD (Western Digital WD1200JD) and decided to use it as a secondary to my much smaller HD. I've plugged in the SATA port, heard it turn on with its unique noise, and I've gone to see if it was...
You need to configure first on your BIOS that it will detect 2 SATA Hard Disks so and set you Primary and Slave. If this doesn't work, basically your HD does not work anymore.
Mar 09, 2010 | Western Digital Caviar SE WD1200JD 120 GB...
Installing new sata drive in HP pc
a clean xp installation does not recognize sata drives at all. you can either use nlite to build a custom install cd, press f6 during setup to load additional drivers, try to change your sata mode from native to compatible in your bios or use your restore cds.
Mar 18, 2009 | Western Digital WD2500BEVSRTL Scorpio...
Can't boot my Dell Optiplex GX280 from the
Hi there
hey if you boot into bios and you need to make sure that the computer will recognize the hard drive and that the jumper that is on the hard drive is set as either master or slave depending on what you want than make sure that of the parameters are right and apply it. than restart the computer and than see if the cd will now boot and you should be able to continue from here ok
best regards mike
Mar 07, 2009 | Dell OptiPlex GX280 PC Desktop
Miss match hd on a dell gx280
Hi, I have had lots of experience installing hard drives. You never get exactly 80gb when it is partioned. Some space is utilized for other things that cannot be used. So you aren't doing anything wrong. Just another way companies can make you think your getting more then you really are.
Dec 30, 2008 | Dell OptiPlex GX280 PC Desktop
Computer fails to recognise my external hard drive
I would suggest the external casing of the harddisk that contains its power supply is busted, so you need to change the casing or remive the harddisk from the casing and connect in inside
Feb 16, 2008 | Western Digital Caviar WD2500BB 250 GB...
Dell OptiPlex GX280 PC Desktop Logo
259 people viewed this question
Alun Cox
