Normally you can plug it in the computer then go to start then My comptuer then you should see it under removable media then you just drag the songs into the player
You can't use Limewire directly to transfer songs to the Nextar. You will need to transfer the songs to the Nextar using Windows Media Player. Limewire puts the songs in a folder called "Limewire Downloads" usually. You will need to open Windows Media Player, run the mouse over the "Library" tab, and select "Add to Library." Once the window pops up you will need to add the folder called "Limewire Downloads" - it may take several minutes, but Windows Media Player is going to add all of those Limewire downloads to its own library. Then, you can use Windows Media Player to transfer the songs to the Nextar.
check the file types from you music the shaker only plays MP3 and PCM WAV file types. You may have WMA (if u used windows media player) which will not play on the shaker (i had this same ploblem btw) you can easly find free music file converter software to change these files to mp3 or wav types (which i did), or you could rerip to songs from a cd and tell the windows media player to rip the files as mp3 types instead of the default wma format
from the windows media player widow :
tools >> options >> Rip Music >> under format select mp3 (theres a wav option but i used the mp3 option to be safe)
do not use the sync feature it will automatically convert your files to to wma (why? i dont know) instead copy the files directly from the folder that contains them :
right click the file you need to put on the player select open file location drag and drop to the player (or copy/paste if you want).
hope this helped =P
Hi, you can try to upgrade the player's firmware, you can download it from the RCA Website (http://support.rcaaudiovideo.com/).
If your computer doesn't recognize the player, you'll have to turn it
off and keep "PLAY" pressed for 10 seconds while connecting it to the
USB port, then update the firmware.
i'm having a similar problem. every time i sync new music my computer tells me its on, but the tracks aren't on the player. it also refreshes every time i turn it on, which takes forever amd is getting really annoying. could this have something to do with my new microSD card?
i had a similar problem with my mp3 player because i had put songs on it from a different computer. i had to go back to that other computer and sync it up to media player to be able to see the files and remove them.
